Question about DCS RDS-364GD-SS Dual Fuel Kitchen Range
Oven slow to heat
My electric oven in the duel fuel DCS range is very slow to heat and usually refuses to get above 375 which is inconvenient since I need higher temperatures for some breads and other baking. The electric coil doesn't even turn red as it should when the oven is turned on. It then heats slowly. The problem has been somewhat intermittent. When I've called repair person, the oven seems to heat of fine for him. Once in a while it has a slow start then suddenly starts heating full blast.
  • DCS Master
  • 43,501 Answers
If your electricOven slow to heat - 2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Posted on May 14, 2010
Wolf gourmet gas range/oven 36"--oven lights and
is this a duel fuel unit if so the the electric bake element is open
Sep 19, 2011 | Wolf Range KFS-0-27-SCB-36 Gas Kitchen...
Oven temperature in main oven does not reach above 200 degrees. Is this a coil problem or a themostat problem?
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Sep 05, 2010 | Kenmore 75503 Stainless Steel Dual Fuel...
I'm looking at a KitchenAide KDDT207B duel-fuel used stove to purchase used from a private party I don't know. Are there reliability concerns?
I have this same oven. It began to intermittently fail when using the oven. The error code suggested it was a problem with the keypad. I suspected it was because the electronics was overheating. The electronics for this model is approximately underneath the right front gas top range. What I found was that the failure occured when both the oven and the right front gas range were being used simultaneously. This caused overheating since the electronics has not fan in this model and the heat radiating down from the pan above the gas range is added to the heat coming from the oven below. The electronics is sandwiched between these two heat sources.
Nov 16, 2009 | KitchenAid KDRP467KSS Dual Fuel (Electric...
I have a Wolf DF484CG Dual fuel electric oven that doesn't heat. Ideas on problem? Where can I get assembly drawings to see how to get to the heating element? Thanks for your help. Howard Gandelot
I HAVE A WOLF DUEL FUEL RANGE/OVEN. THE OVEN STOPS HEATING AT-TIMES , THEN RESUMES WHEN-IT-WANTS-TO !!
IS THIS A TIMER/THERMOSTAT/SENSOR ISSUE ? THANKS, JEFF
Sep 29, 2009 | Wolf Range Kitchen Ranges
Oven is not heating properly
Could you find the completer mode number because the number listed above your post is for a gas oven.
Look at following areas for the model number
  • Under Right Front Burner
  • Under Left Top Burner Front Or Rear
  • Under Main Top Left, Rear Or Center Front
  • Under Left Rear Or Right Front Element
  • On Nameplate Inside Burner Box
  • On Front On Burner Box Bottom
  • On Nameplate On Oven Door Liner
  • On Main Front Behind Oven Or Compartment Door
  • On Front, Center Bottom Of Burner Box
  • On Thermostat Cover Under Main Top
  • Thank You, Sea Breeze
Mar 25, 2009 | DCS RGS-484GG Gas Kitchen Range
DCS 4 burner plus griddle Range..oven doesn't heat
This happened to my DCS when the Hot Wire Relay went out. It isn't an expensive part, but finding someone that knows what needs to be replaced, and then can replace it is hard. My oven also did the opposite and continued to heat without shutting off, and it was once again the hot wire relay.
Jan 11, 2009 | DCS RDS-364GD-SS Dual Fuel Kitchen Range
ERD36 Oven over heats
If the oven stays off when turned off then it is definitely a controller board problem. - that would mean the element is coming on and there is no control - changed the controller
Regards
Sep 11, 2008 | Dacor Epicure ERD30 Dual Fuel (Electric...
Thermador PDR30 4ZS/05 duel fuel
It's the motherboard. You must have had a power surge. I just replaced mine. Motherboard + shipping 200.00. its not easy to replace but not so difficult.
Mar 11, 2007 | Thermador PDR304ZS Dual Fuel (Electric and...
DCS RDS-364GD-SS Dual Fuel Kitchen Range Logo
1,822 people viewed this question
Top DCS Kitchen Ranges Experts
John Tripp
John Tripp
paulcarew
Sal DeAngelo
Are you a DCS Kitchen Range Expert? Answer questions, earn points and help others
