Question about Nokia 7373 Cellular Phone
My nokia 7373
Hiya my nokia 7373 has locked, and wont accept my code. Which is the default 12345.
i have tried it over 5 times
so i am scared that i have locked it permantly pleaseeee could u help me
by emailing me at
[email protected]
thanks
please get back to me asap
  • Anonymous Jun 20, 2008
    I have exactly the same issue that the phone does not accept the standard security code can you still help.
    Thanks
    j
  • 4,102 Answers
Hi becky i can help you but the problem is if you have entered the wrong code more than 5 times then the only way too unlock it is by using flash lead and unlocking software and equipment witch would cost more than the phone new ok.
If you want your master code then i need your imei number its located on back if phone under the battery and looks like 1234/1234/`1234567 its 15 numbers long ok i need this as every phone has a different master code based on the imei number so if you want this code then let me know ok speak soon
Posted on Mar 29, 2008
SOURCE:
How to unlock a nokia 7373
Hello My Dear::":"::"
defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Jan 19, 2013 | Nokia 7373 Cellular Phone
Nokia e71 lock code
press the keey on the left side of shift key. it will change the entry into num mode. press 112 and press dial button (green phone button). It will show connecting press end call button. Now the set should be in normal mode.
Nov 18, 2008 | Nokia E71 Smartphone
Nokia 7373 Frozen screen!
what is the imei number of the phone if you do not know you can take the battery out of the phone it is located to the back of the phone or you can press #06#
Jun 22, 2008 | Nokia 7373 Cellular Phone
Nokia 7373 how to umlock my memory card
hey sally
have you tried using the default password or passcode? i think its 12345 for security code right?
anyway, you need a passcode in order for you to use the card and only the card.. if you still cant carack the code, you might as well reformat the card using a card reader/writer on a pc.
Apr 08, 2008 | Nokia 7373 Cellular Phone
Nokia unlock code
hi i can get you a master code for the nokia but the codes only work if you have not entered the code wrong more than 5 times if you have then the phones hard locked and can only be unlocked using flash lead and unlocking software.
If you want the master code for your phone then you need to give me your imei number its on back of the phone under the battery looks like 123456/1234/12345 its 15 numbers long i need this as every phone has different master code ok
Mar 26, 2008 | Cell Phones
Nokia 6265i
There's a Security Code and Lock Code.
Resetting the Lock Code:
Remove the battery and replace it after 1 hour or more. The default Lock Code should reset to "1234". If that doesn't work try the last four of your phone number.
Resetting the Security Code:
The default Security Code is 12345. If this doesn't work go to your normal interface and type in "#3001*12345*. Go to the Security option, write down the number, then press "Ok". Back out of it all and it should take you back to your normal phone interface. The number your found should be your security code.
Feb 16, 2008 | Cell Phones
I cannot understand why my phone does not accept the default security code 12345
Try to remove battery for few hours and try again if it wont work so just flash it in cellshop!
Nov 15, 2007 | Nokia 2600
Security code
security code on a nokia is 5 digits try 12345
Nov 04, 2007 | Nokia 7373 Cellular Phone
Nokia 7373 Cellular Phone Logo
70 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Ekse
