Question about Dayton (1UM44) Fan
Motor won't run
Replaced the switch on a Dayton 1C154C motor and can't get it to run. It is a capacitor start motor and there are 5 wires out of the switch. 3 to the motor and 2 from the power cord. I have rewired the switch as follows.
L - black from the power cord
Green from the power cord to the case of the motor
White from the power cord to the neutral on the switch.
The other 3 wires are blue, white, and orange and were all placed back in the new switch as original. I suspect the winding is open but I do not have a schematic to chase it out. Any help?
22yooper
  • 828 Answers
SOURCE: Dayton 1/2 hp dual voltage
Wiring would be for low voltage 1-3, 4-2. L1 feeds 1-3 and L2 feeds
4-2. For high voltage L1 feeds 1 and L2 feeds 4 with the 2-3 terminals linked by wire or bus bar.
Posted on Jul 23, 2008
  • 2976 Answers
SOURCE: how to connect the Dayton Capacitor Start Motor to 230 volts ?
In the **********, the screws will be market L1 & L2. There will also be a jumper that needs to be connected between the 2 terminals for 230V.
Posted on Aug 28, 2009
jumptrout51
  • 3361 Answers
SOURCE: "i'm replacing my Rheem RBGC
There should be a wiring diagram on the side of the new motor.
The brown and the brown w/ white go to the new capacitor you should have bought with the motor.
The black and white go to your L1 & L2 power source. The remaining wires must be capped off.
Posted on Feb 25, 2010
Testimonial: "Thanks for the info. although a day late it confirmed what a friend had told me also. Didn't see any wiring diagram on the new motor."
SOURCE: internal wiring
http://farm1.static.flickr.com/114/253735324_c7d4920bc5.jpg
Posted on Mar 15, 2010
MOTORWIZJ
  • 1363 Answers
SOURCE: I have a Dayton 36
GRAINGER.COM THEY HAVE A TECH LINE, BUT ON THE MOTOR LABEL IT SHOULD HAVE THE WIRING DIAGRAM .. GOOD LUCK AND I'FN I WAS ANY HELP PRAISE IS APPRECIATED .. SO VOTE JAY MOTORWIZJ
Posted on May 28, 2010
Could sure use a wiring diagram for a Dayton 5k961c motor.
Electric Motors: dayton motor, Electric motor repair Kansas ...
en.allexperts.com > Industry > Machine Tools > Electric Motors
Aug 24, 2010 - Electric motor repair Kansas City MEAR Service 816-650-4030: Tyler, it is ... i have a dayton motor with no wiring diagram. i need a wiring diagram for a dayton motor with a model # 5k961c and a reference # r67745ck733 ... 1992 Dodge Dynasty Blower Motor Wiring Diagram · 1998 Ford Escort Blower ...
wiring diagram (ideally color) for Dayton belt drive motor Model ...
www.electro-tech-online.com > ... > General Electronics Chat
Apr 29, 2012 - 9 posts - ‎3 authors
There is a sticker on motor indicating wiring, but seems only an. ... This is a motor for vented - big blade ceiling fan -- a belt driven Dayton Motor ...
DAYTON 1/4 HP Condenser Fan Motor,Permanent Split ...
https://www.grainger.com/.../DAYTON-1-4-HP-Condens...
W. W. Grainger
Rating: 3.8 - ‎6 reviews
Shop DAYTON 1/4 HP Condenser Fan Motor,Permanent Split Capacitor,1075 Nameplate RPM,208-230 ... Typical HVAC Condenser Fan Motor Wiring Diagram ...
DAYTON 1/3 HP Direct Drive Blower Motor, Permanent Split ...
https://www.grainger.com/.../DAYTON-1-3-HP-Direct-D...
W. W. Grainger
Jan 23, 2016 | Dayton Dryers
How do you change speeds on a dayton 3lu87j motor?
did you install the proper motor run capacitor . any time you change a motor you must replace the capacitor
Nov 24, 2012 | Heating & Cooling
I installed a Dayton 4m205j condenser fan motor. It comes on but turns the wrong way. I switched the wires and it still turns the wrong way.
From what I can find on the internet, there should be a plug very close to the motor body that can be reversed to reverse the rotation of the motor. It should be a small rubber plug on the wires leading into the motor.
Also, check inside the wiring compartment for a sketch or notes.
Gary
Aug 15, 2011 | Dayton Permanent Split Capacitor Motor Fan
Dayton model 5k117u compressor motor turns the wrong direction
Open up the electrical box on the side of the motor...if the wires are numbered switch the #5 and the #8 wire...
If the wires are color coded then switch the red and the black wires and the motor will run the other way...
heatman101
Jun 29, 2011 | Air Tools & Compressors
I need a wiring diagram for a dayton 120/230 v capacity start motor model 6k157 or equivalent
I have dayton motor 3/4 hp 120-240v it has 3 contacts 1-2& 4 it has 5 wires 2 white 2 red 1 blue. I want forward rotation! what do I do?
Jan 14, 2011 | Dayton Permanent Split Capacitor Motor Fan
How to connect the Dayton Capacitor Start Motor to 230 volts ?
Aug 28, 2009 | Dayton Permanent Split Capacitor Motor Fan
Electric motor is not functioning properly
Sounds like its wired for 220v and the start capacitor is shot.
Mar 24, 2009 | Saws
Wiring diagram for dayton ac electric motor
i need wiring diagram for a dayton electric motor 4mb22
Dec 13, 2008 | Dayton Permanent Split Capacitor Motor Fan
Dayton Motor and capacitors for Carrier AC Unit (model # 38ck030300)
The 2 brown wires to the cap in first legend is how they are wired electrically,inside that motor the run winding is common to that brown one they cappped off in the 2nd option, but the powers still going to Run.ommon and run get the juice either way, its just another way to do it, but electrically as to sides of power and where they go is no different, just different way to do it.you can run power in on the Run terminal on the run cap, the run winding and run cap and start cap if equipped are Run to Run to Run.So the hot leg for the run winding also goes to run on the caps, run to run to run.,run winding to run cap to run on start cap.
Apr 07, 2008 | Carrier 38CKC036 Air Conditioner
Dayton (1UM44) Fan Logo
27 people viewed this question
Top Dayton Dryers Experts
Jay Finke
Jay Finke
AZBen
AZBen
Piyal Perera
Piyal Perera
Are you a Dayton Dryer Expert? Answer questions, earn points and help others
