Question about Panasonic DMR-EZ47V DVD Recorder/VCR
Bet ya can't solve this one(VCR to computer problems
Ok, my old VCR will go through my ADVC-55 capture device and into the computer via firewire and be viewed in my softare. So why does my brand new panasonic DMR-ES47V not do it? I have all the in put and output jacks connected correctly. I am using S-video out. I have been stumped on this for three weeks now and yes it is driving me nuts.
Thanks very much.
Ray
gjourney1@yahoo.com
  • rayray444 Mar 28, 2008
    I just tried detaching the s-video cable from the DVD/VCR and now i am capturing something. I thought that s-video would be preferrerd over RCA cables. It never dawned on me that by not using the s video cable it would work now. But the video is a little out of sync maybe by a half second with the audio.
    The tapes I am transfering are older VHS and VHS-C type. Is VHS-S for use with s-video only???
    Thanks
  • Stuart
    Stuart May 11, 2010
    Is that the correct model number of the panasonic, it does'nt even come up in Google.
  • 807 Answers
Just realized it's EZ47, not ES47.
Will have a look around, maybe just need to switch the output to an external device with the remote. Have you read the manual properly.
Posted on Mar 28, 2008
My problem is windows 8 can't recognize advc-55
imy win 10 computer cannot reconised the advc.
The green led is burning but i see no video.
Can you repair mij advc 55?
Mar 29, 2013 | Canopus ADVC-55 Video Capture
Macbook pro does not find canopus acdv110
How did You connect Canopus? Canopus has 2 Firewire slots - on the back and on the front. If You connect FW cable to a front slot, then, Canopus will not work. Only with external power supply. I´m offering the next proceeding:
1. Connect ADVC with FW cable 6 to 4 to Your macbook via back FW slot. The ADVC lights will now on. On front panel by default light is on mode "digital". If the light don't work - it's a Canopus problem. If light is up and working, then next step.
2. Go to apple menu-about this mac - more info - firewire. You MUST see here Your Canopus a a device. If so, go to the next step.
3. Connect Your VCR to analog inputs, on the front panel of Canopus.
4. Run FCE. If it says "apple firewire device is missing" then is something wrong with Canopus. If not, proceed to next step.
5. On the top of the front panel of Canopus, press button. The light changes from digital to analogue.
6. Press apple+8, then capture settings. Set the firewire device as uncontrollable device. Make sure that in capture window is "vtr ok". Turn the VCR on
7. Press the play button on capture window. In the window appears the screen of Your VCR. Then press play on VCR and then "capture now" on capture panel. Voila! Must to work.
Aug 30, 2009 | Televison & Video
I can capture video into FINAL CUT from VHS deck via ADVC-300, but there is no audio. Is this common?
it should not be. Are you getting audio signal levels on the ADVC-300? I think it may be a connection problem. I always get audio from vhs, even through a camera or hdv deck. Never mind a converter box.
May 21, 2009 | Canopus ADVC-300 A/D Converter Video...
Cant capture video
Not having camcorder control is normal, as the ADVC110 doesn't translate DV (AV/C) control to anything else. It just accepts and replies to deck control commands so the capture application doesn't get stuck waiting for a response.
First off, make sure you only have the ADVC110, your VCR, and your computer connected. No other Firewire devices.
Be sure your have the output from your VCR connected to the ADVC's input. Connect your VCR's output to your TV. You should see in iMovie the same image you see on your TV, slightly delayed.
Jul 04, 2008 | Canopus ADVC-110 A/D Converter...
Firewire Won't Work
Check in the back of your deck and see for small switch that would Change Fire wire or Usb input
May 21, 2008 | Sony GV-D1000 Mini DV VCR
Can the Canopus ADVC-110 be reset
May i suggest that if the Canopus is stuck and both lights are on it may well be faulty but try this first.
slowly insert the fire wire into the back of the Canopus slowly does it when one light comes on stop inserting the fire wire and press input select till the lighth moves to the other side in my experiance digital to anolog,this may take a fiew goes and seem primative but it has worked for me and then eventialy the canopus corrects its self if this has been helpful please put a pound in the charity box of your choice and email hayden@hayprofilms.com just to let me know good luck bye.
May 07, 2008 | Canopus ADVC-110 A/D Converter...
IMac and ADVC 110 via firewire = Nothing
this just happened to me tonight...whats going on?? is this some recent leopard related error?
Oct 09, 2007 | Canopus ADVC-110 A/D Converter...
Canopus ADVC-110
Hi! You must use a firewire in order to receive power - if you're going to use composite cables (red, white, yellow) you will have to purchase an AC adapter.
ADVC110
I'm guessing that you have it connected via a 6pin firewire on the ADVC100 to a 4pin firewire on your macpro. The device needs to be connected via 6pin to 6pin in order for the device to get power, otherwise you'll have to buy a AC adapter (which is not included). Otherwise it's a great device for DV conversion on multiple platforms!
Mar 23, 2007 | Canopus ADVC-110 (77010150100) Video...
Panasonic DMR-EZ47V DVD Recorder/VCR Logo
56 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
