Question about Dometic RM2452 Refrigerator
What causes ice to build-up in refrigerator? - Dometic RM2452 Refrigerator
  • 999 Answers
Condensation from moist food items and air entering every time the door is opened.
Eric
Posted on May 10, 2010
Water in drawers of refrigerator
This is usually caused by Ice building up and then melting. If you have a unit where there is ice building up you may have to leave the unit to completely defrost.
Feb 12, 2015 | Roper RT21AKXKQ Top Freezer Refrigerator
What causes ice build up in bottom of freezer with french doors and then leaks out
sounds to me like a bad door seals causing condensation and leakage
Aug 23, 2014 | Whirlpool Refrigerators
Icemaker stopped producing ice so I removed. It had a burnt electrical smell. Two days later I opened the freezer door and it looked as though everything was thawing. Now the refrigerator portion is not...
ice mker may have not been the problem . there are heaters in the back and they may have been causing the smell and if they overheated due to a failed defrost therm. ck for ice build up in back of freezer . this would also cause ice build and a blocked evap coil .. and thus no cold to the fresh food . mm
Oct 14, 2010 | Kenmore 53632 / 53634 Side by Side...
Model No IK 458 -4-4T; Product No 925 780 652 02 Ser No 14100010. I get ice build-up on floor of fast freezer comp which jams pull-out basket.
If the defroster coil is not working, then ice will build up on the coils inside the back of the refrigerator.
But, you're saying that it's accumulating on the floor of the freezer jamming the pull out basket.
I would say that the timer or overflow valve is bad on this refrigerator causing ice to build up on the floor of the fast freezer compartment causing the jamming.
Jul 19, 2010 | Freezers
Ice maker quit working and is causing ice build up on the back of the freezer
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
May 20, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice build-up around the fan making a noise.
Drain line froze.
Used hair dryer to thaw frozen line, works OK now. 01/07/09
Think the frozen drain line was caused by the light in the refrigerator not shutting off when the door closes, causing excess cooling in the freezer. Poor design on the light shutoff switch, corrected design to make permanent repair
chestnutlee.
Dec 27, 2008 | GE Refrigerators
Ice build up
HELLO AND THANK YOU FOR YOUR QUESTION.WITH REGARDS TO THE ICE BUILD UP IN THE BOTTOM OF THE FREEZER THAT COULD BE CAUSED BY ONE OF THREE THINGS.YOU NEED TO CHECK THAT YOUR HEATER ELEMENT IS WORKING OK AS THIS WILL CAUSE THE ICE NOT TO DEFROST FAST ENOUGH BEFOR THE FRIDGE COMES BACK ON.SECONDLY THE FAN NEEDS TO BE CHECKED IF ITS WORKING OK THAT CAN ALSO CAUSE IT.LASTLY YOU DEFROST CLIQSANS NEED TO BE CHECKED TO SEE IF THEY ARE SENSING THE TEMP CORRECTLY.GOODLUCK.MOHAMED
Sep 15, 2008 | Whirlpool GD2SHGX Refrigerator
Kenmore refrigerator model 46-66812 ice build up on the bottom shelf of freezer
Had the same problem. I noticed that the fan in the freezer never shut off so I suspected the thermostat. I ordered and installed a new thermostat (about $30 and 15 minutes to install), the fan now cycles correctly and the ice build up is gone.
Mar 21, 2008 | Refrigerators
Dometic RM2452 Refrigerator Logo
123 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
4stevetaylor
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
