I purshased Ad-Aware order no element 5 187935175. I have had to re-enstall my hard drive. I tried to re-install using the disk supplied but it keeps rejecting it
    Scholar:
  • 105 Answers
Software makers will typically allow reinstalls on your hard drive without problems. Is the hard drive brand new? If you "re-installed" your hard drive, do you mean you replaced it or just moved it?
You may have to completely uninstall the previous installation before beginning a new installation. If this does not work, please provide more information regarding your troubleshooting steps already taken.
Posted on Mar 28, 2008
  • 19,396 Answers
You need to contact Ad Aware again, your download was defective, I will find the contact
  • 2 more comments
  • Ginko
    Ginko Mar 28, 2008
    when you purchased ADAware you entered an email address and chose a password. Enter those details here to contact Lavasoft, and ask a new download.
  • Ginko
    Ginko Mar 28, 2008
    If you bought disk version use same as above and ask a replacement disk.
  • Ginko
    Ginko Mar 28, 2008
    Alternatively you can email Lavasoft Sales here ( [email protected] ), and ask a replacement disk, they should send it straight away.
  • Ginko
    Ginko Mar 28, 2008
    I forgot, If you purchased the copy from a shop go back to local retailer and ask replacement or do the following register online support, and then contact Lavasoft
SOURCE:
How do I get my computer to work faster ?
If you are only able to change software settings, there are different settings you can try, but just what settings depends on exactly what operating system you are using (what version of Windows).
If it is a late version of Windows, you may be able to use a USB flash memory drive as a type of cache to speed up the computer. You should be prompted to do this the first time you install the thumb drive.
Make sure there is no malware installed (malware slows down computers considerably). Install free versions of malwarebytes, superantispyware, and/or Ad-aware, and run one at a time, and allow them to remove any malware they find.
If you can upgrade hardware, replace the hard disk drive with a Solid State Drive, and/or as much memory as the computer's motherboard supports. Most PCs have a bottleneck in the disk drive for most uses, and this speeds up this part of the computer considerably. More memory gives the computer the ability to run more stuff at one time without having to shuffle things between the hard drive and the memory all the time.
Dec 24, 2014 | Computers & Internet
NEC VERSA M540 - Performing slow
Try downloading ad-aware. Run it and see if that speeds it up. It is a spyware killer (pop-ups), also clean your hard drive up with a disk clean up option and a degragmentation. If it is still running slow, try a ram up grade.
Feb 13, 2008 | Computers & Internet
How to briefly disconnect ad aware (anti-virus) and download adobe flash drive to my computer
hi terrye, i am happy to help you , just follow these steps you can able to remove ad aware anti viurs
Manual Removal of AD AWARE
1. Click on "Start," then choose "Programs." Click "Uninstall ad-aware." Allow the computer to uninstall the software. If the program does not successfully uninstall, uninstall the program using the control panel.
2. Click on "Start," then choose "Control Panel." Click on "Add/remove programs." The programs that are listed on your PC will be displayed. Choose "ad-aware se." You will be asked if you want to remove the application and all of its components. Choose "Yes," and allow the program to uninstall.
3. Locate the ad-aware program folder and un-register it by clicking on "Start" then "Cy computer." Double-click on "Local Disk." Locate the "Program Files" folder and double-click on it. Locate the "Lavasoft" folder and double-click on it. Locate the "ad-aware" folder and double-click on it. Next, double-click the file "unregaaw.exe" to un-register the file. Next, delete the entire Lavasoft folder.
4.Delete any Ad-Aware SE program icons that may be present on your desktop. Remove the Lavasoft folder located in your documents and settings folder. Navigate to the folder by clicking on "Start," then "My Computer." Double-click on "Local Disk." Locate the "Documents and Settings" folder and double-click on it. Locate the folder labeled with your computer user name and double-click on it. Double-click the "Application Data" folder, choose the Lavasoft folder and delete it. Reboot your PC.
ADOBE FLASH PLAYER
its not much hard to install adobe flash player , just copy and paste the link below
http://get.adobe.com/flashplayer/
after page got loaded click this button Download now
your flashpalyer will start to download, to make it more easy i will add video just check it out
utube.png You-Tube video "dxxYHlJ-7W8" placeholder Good luck ! if you think your problem solved don't forget to rate
Jan 01, 2011 | Dell Inspiron 530s Desktop Computer...
WD elements SE 1TB Portable hard drive will power up and disk will spin but not showing up in my computer....
The external storage device has several major components:
* USB cable
* external power-supply
* disk-drive inside the enclosure
* USB-to-disk-drive adapter inside the enclosure.
Try a different USB cable.
Try a different USB port on your computer.
Try a USB port on a different computer.
Take a multi-meter, and measure the output voltage/amperage of the power-supply,
and compare with the specifications on the label of the power-supply.
Open the enclosure, and remove the disk-drive, and attach it as a "slave" drive in a desktop computer, to see if bypassing the USB-to-disk-drive adapter bypasses the problem.
Look at the label on the disk-drive, for manufacturer, product-number, serial-number, and manufacture date. Access the manufacturer's web-site, and use "check warranty status" to see if the warranty still is valid. If so, the drive can be replaced, at minimal cost to you.
Buy a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Search online for a professional "data recovery service". For a significant fee, they can repair your disk-drive, just long-enough to copy your files to a new disk-drive.
Note that W.D. has a "Customer Loyalty" program. Buy a new W.D. disk-drive through the W.D. web-site, and you'll get a significant discount.
Nov 04, 2010 | Western Digital 500GB ELEMENTS 500 GB USB...
DELL Optiplex GX110 freezing
Check the settings of the internal setups. This is using the BIOS itself and hitting a particular key before anything happens. On some machines it is F1 or the DEL key. In the basic setup there are settings for the boot order and floppy drives and HD type. Make sure these are set correctely.
ALSO on one of mine I have to use a formatting/partitioning program supplied by the HD manufacturer (in this case Maxtor) to pre-prepare the drive beofre trying to install WIndows.
Sep 08, 2009 | Western Digital Elements powered by WD 320...
Anti Virus
Here is what I would do.
First I would start off by downloading the free trial of ESET NOD32 Anti-Virus. Afterward I would scan my system (In-Depth Scan) with the free trial of NOD32 (It doesn't use a lot of system resources). Next I would download the free version of Ad-Aware 2008. After the anti-virus scan finished I would scan my system with Ad-Aware (Full Scan). Next I would download and install Spybot Search & Destroy. After Ad-Aware finishes scanning I would start a scan with Spybot. Next I would download and install AVG Anti-Rootkit Free. After Spybot finishes scanning I would run an in-depth search on all hard-drives with the use of AVG Anti-Rootkit Free.
If that doesn't whack it, fighting this thing might not be worth it. Reinstall the windows operating system after you back up any files which you absolutely HAVE to keep.
Feb 02, 2009 | Computers & Internet
Help!
You have not yet formatted the drive to work with you MAC. You will need to use your MAC's Disk Utility to format the drive in order to write to the drive, but be aware that formatting will erase everything already on the external drive, so back up anything on the drive you want to keep first.
May 29, 2008 | Seagate 400GB 7200rpm External HDD Retail...
No mouse cursor visible on monitor
Could be spyware, virus or a failing hard drive.
Download Ad-Aware® SE Personal Edition, a free program that you can download at:
http://www.lavasoftusa.com/support/download/
Check for updates before running program. Then follow the directions here to do a full scan:
The following explains how to set Ad-aware's settings to perform a "Full Scan."
In Ad-aware click the Gear to go to the Settings area.
The following items should be on a green check, not on a red X.
Under the Scanning button:
Scan within archives
Under Memory & Registry, Check EVERYTHING
In Check Drives & Folders, make sure all of your hard drives are selected
Under the Advanced button, check ALL under Log detail level (this makes it easier for visitors to the Lavasoft Support Forums to see what options you have selected should you require assistance.)
Under the Tweak button...
Some of these may not be an available option, depending on your version of Ad-aware and your version of Windows. Do not be concerned if you cannot select a certain item.
In Scanning Engine:
Unload recognized processes during scanning
Include info about ignored objects in logfile, if detected in scan
Include basic Ad-aware settings in logfile
Include additional Ad-aware settings in logfile
Include used command line parameters in logfile
In Cleaning Engine:
XP/2000: Allow unloading explorer to unload shell extensions prior to deletion
Let Windows remove files in use at next reboot
UNCHECK: Automatically try to unregister objects prior to deletion
Click Proceed to save these settings. When you would like to perform a "Full Scan," switch the scan mode from SmartScan to Custom.
After running Ad-aware, you must reboot your computer. It may be necessary to run Ad-aware two or three times if you have a lot of spyware, rebooting each time in between.
Where it says,"In Ad-aware click the Gear to go to the Settings area", on the top of the Ad-aware window, there are 5 symbols, click on the one that looks like a gear.
Go to: http://sarc.com/ Scroll down and click on,"Free Online Virus and Security Check" Write down exactly anything it finds, then return to: http://sarc.com/ and do a search for what was found. Symantec usually has a removal tool and/or directions for removing. manually.
Regarding the Hard drive, check out what PCWorld offers at:
http://www.pcworld.com/howto/article/0,aid,105869,00.asp
Hope this helps!
Apr 11, 2008 | Computers & Internet
Ad-Aware Pro Back up Cd 00-2m-187935175
You can install it. but you need to know what type of back up you have , Like Norton Ghost, Dell Pc RESTORE, Etc and then Get back to Us...
Kindly give a feed back to Improve my statistics and to see If it was helpful for you...
Thanks and Regards
Mar 28, 2008 | Computers & Internet
Computer gets stuck loading win xp
Hiya ya, It sound to me you could be courripted with spy ware or a virus i will recommend using Ad-Aware SE Personal install this and run it! - you can find Ad-Aware SE Personal from this direct download link - http://software-files.download.com/sd/99nfDnO0WNfR5Wh8fucNAQf7N59p48yGyOq1e_XM8HIX6d0PeT0xd36uOth8kTloWoNAp4GOAh-Z2YdX8nf9afcV5NPn3Uc0/software/10639408/10045910/3/aawsepersonal.exe?lop=link&ptype=3000&ontid=8022&siteId=4&edId=3&pid=10639408&psid=10045910 This is a very good program i have been using Ad-Aware now for around 2 years and it's super. However if you have a virus you can use Avg_free - If you are already using norton or somthing like that REMOVE IT because personally Nortons Crap" Its not recommended - to remove your anti-virus go to Startmenu Settings/control panel /Add or remove Programs, Select the anti-virus program and press remove. After you done that! close all windows and open internet explorer with this link (explorer will open automaticlly) - http://free3.grisoft.cz/softw/70free/setup/avg75free_446a991.exe install that and run it on a virus check from the Avg test centre - If they don't work Then i would recommend a full deep clean for windows Xp But before you do that if you can Back-up any files that you want to keep as you need to Fully formatt C:/ drive (this is normally the drive that windows runs on) If you would need help at doing this On the telephone i can be contacted on * 0906 179 0906 (Call cost £1.50p/minute) @ all times. In the meantime take care And keep it hardcore = HTID = Hardcore till i die!
Apr 10, 2007 | Acer Aspire RC500 PC Desktop
Computers & Internet Logo
51 people viewed this question
Ekse
Alun Cox
