Question about Proform Exercise & Fitness
It starts but stops right away. - Proform Exercise & Fitness
    Problem Solver:
  • 19 Answers
Bad speed sensor. When display recognizes no belt movement it stops within 5 seconds.
Posted on May 14, 2010
My 1999 chevy suburban starts but quits right away, what can the problem be?
Are you loosing fuel or spark when it stops running ?
Sep 01, 2014 | Cars & Trucks
I was driving down the street and the signal lights both stop functioning .. Parked car and was gone approximately 15 minutes. Started car and my signal lights are functioning again. Make a 2 minute stop...
Check your battery terminal's, check woltage when engine is off on your battery, check voltage when running. Could be alternator, battery ior something wrong with charging system.
Feb 12, 2010 | 1995 Ford Escort
A 1994 chev truck starts then stops right away its
Check to see if fuel pump is cyling if yes check fuel pressure, pump could be on the way out!
Feb 02, 2010 | 1994 Chevrolet C1500
Won't boot....fans start, then stop right away
check if your power source is ok. it may be broken and this is why you hear the fans start and then stop right away. they are working about 3-4 seconds, aren't they?
remove and put back the jumper for clear cmos after you test your motherboard with a new ac source
Jan 25, 2010 | Biostar P4M900-M4 Motherboard
Lawn mower starts and stops right away
take bowl off bottom of carb....clean and reassemble
Nov 16, 2009 | Garden
Kenmore electric dryer 6681290 runs for about 10 minutes then shuts off
HI, When the dryer stops, can you restart it right away? If it will not start right away, your motor is overheating and will need to be replaced.
If I can assist you further, please let me know.
Thanks
Vic
May 18, 2009 | Dryers
Engine start but stopped when you stop the key
Bad ignition switch in column. Bad key switch.
Apr 22, 2009 | 1991 Toyota Corolla
Start and stop
Top candidates for this problem are:
Clogged Fuel filter
Faulty Fuel pump
Clogged fuel injectors
Dirty / worn spark plugs
Of these, only the clogged fuel injectors are likely to respond to a gas tank additive, and even then you need to get the right kind of additive.
If your fuel filter has not been changed in a while (couple years), start with this. It is fairly easy to change. The fuel filter is under the car near the the driver's side rear door.
If this problem started "suddenly," then the fuel pump might be the culprit.
Fuel injector / spark plug issues are not likely to stop the engine right away, but would tend to cause it to miss cylinders, idle rough, or start rough.
Mar 08, 2009 | 1985 Oldsmobile 98
Problems when starts..
Turn your key on for 10 seconds but do not start the engine. That will give the fuel pump time to built pressure. After the 10 seconds try starting the engine. If it starts right away you may have a weak pump or dirty filter.
Oct 02, 2008 | 1999 Chevrolet Cavalier
Exercise & Fitness Logo
113 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
