Question about Comfort-Aire RAD-243 Air Conditioner
Exhaust fan can you use the fan for exhaust
    Novelist:
    Champion:
  • 246 Answers
No, the air conditioner fan moter - basically 're-circulates' the air in a space - while an exhaust fan takes air from the space and puts it outside to the atmosphere.
Plus an exhaust fan is considerably cheaper than an Air Conditioner.
Posted on May 10, 2010
When I light my pellet stove and push the start button the exhaust fan comes on but the smoke in the stove don't blow out the exhaust. What could be the problem?
Are you sure it is the exhaust fan and not the convection fan or the fresh air fan you hear? If it is the exhaust fan, check for blockage in the exhaust pipe.
Feb 22, 2016 | Whitfield Advantage II-T Service Manual
LIGHT, turntable, and fan don't come on
follow this test and fix it. God bless you
  1. Exhaust fan motor If your exhaust fan motor is not running, there are a couple of things that you can check involving the motor to locate the problem. After removing the fan motor, you can manually attempt to turn the fan blades with your hand. If the fan motor is working properly, the blades should spin effortlessly. If this does not occur and the blades are taught, the motor will need to be replaced. Secondly, the fan motor itself can burn out due to time and usage. Using an ohm meter, the exhaust fan motor should read open for continuity. If it does not, then the fan motor has expired and will need to be replaced.
  2. Thermostat Another part that could cause the microwave exhaust fan to not work is a faulty thermostat. A thermostat gauges the air temperature, which activates the exhaust fan when required. If this part becomes flawed, the exhaust fan will not energize and the thermostat will need to be replaced.
  3. Main control board If your exhaust fan is still not working and the microwave fan motor, wiring, and thermostat are operating accurately, the root cause could be with the main control board. Replace the main control board.
Dec 09, 2013 | GE CVM2072SMSS Microwave Oven
Fan running when door open
measure this test and use the multimeter for fix it. GOD BLESS YOU
  1. Exhaust fan motorIf your exhaust fan motor is not running, there are a couple of things that you can check involving the motor to locate the problem. After removing the fan motor, you can manually attempt to turn the fan blades with your hand. If the fan motor is working properly, the blades should spin effortlessly. If this does not occur and the blades are taught, the motor will need to be replaced. Secondly, the fan motor itself can burn out due to time and usage. Using an ohm meter, the exhaust fan motor should read open for continuity. If it does not, then the fan motor has expired and will need to be replaced.
  2. ThermostatAnother part that could cause the microwave exhaust fan to not work is a faulty thermostat. A thermostat gauges the air temperature, which activates the exhaust fan when required. If this part becomes flawed, the exhaust fan will not energize and the thermostat will need to be replaced.
  3. Main control boardIf your exhaust fan is still not working and the microwave fan motor, wiring, and thermostat are operating accurately, the root cause could be with the main control board. Replace the main control board.
Nov 08, 2013 | GE JVM2070 Microwave Oven
Fan starts when i open door
follow this test and use the multimeter and fix it. God bless you
Cannon ir 3025 photocopier displays error code 805-000.
E805
There is a fan error.
0000
Failure in heat exhaust fan (front) (FM2)
When lock signal is detected for 5 sec while the fan is stopped.
- Replace the heat exhaust fan (front) - Replace DC controller PCB
0001
Failure in rotation of heat exhaust fan (front) (FM2)
When lock signal failed to be detected for 5 sec while the fan is driven.
0002
Failure in heat exhaust fan (rear) (FM1)
- Replace the heat exhaust fan (rear) - Replace DC controller PCB
0003
Failure in rotation of heat exhaust fan (rear) (FM1)
there are 2 fame in the right door if you just look on the right door you will see 2 square vents
get in there and remove the fans and clean them out with canned air and apply a small amount of oil in the center then flick the fan to make sure it spins softly
reinstall and try it should fix the problem but please go ahead and order a new fan the part number is on the fan itself in the sticker it will say FK2-????-????
Oct 30, 2013 | Office Equipment & Supplies
When Exhaust button pressed, vent fans not working, but microwave running for 30 seconds.
test the components and fix it. God bless you
Oct 24, 2013 | Frigidaire Microwave Ovens
The vent fan is not working but micro is. Replaced charcoal filter & reset still not working.
follow this steps and fix it. God bless you
Read more: http://www.appliancepartspros.com/repair-help/microwave-repair-help.html#12#ixzz2gURd1VtM
Sep 30, 2013 | Whirlpool WMH2175XVB Microwave Oven
We changed the charcoal filter & reset it. The vent fan still does not run. I cannot turn the vent on by pressing the vent button but the micro still heats up. What happened to the fan?
follow this steps and fix iT. God bless you
I need a replacement motor for a NuTone Model LS-80SE exhaust fan but can't find one.
Home depot usually has a good selection of replacement fans. They usually are a fan on a mounting plate, not just the fan motor itself. Sometimes you have to purchase the entire fan unit just to get the fan motor plate inside for a replacement part.
Feb 23, 2011 | Broan-NuTone N-LS100SE Exhaust Fan Exhaust...
My parents had a Broan exhaust fan installed in their bathroom and water is leaking from it. Any ideas on what this could be?
Sounds like a condisation problem. Check the exhaust tube for low spots, and also check if the exhaust tube is isulated.
Nov 29, 2009 | Broan-NuTone N-LS100SE Exhaust Fan Exhaust...
Comfort-Aire RAD-243 Air Conditioner Logo
344 people viewed this question
Top Comfort-Aire Heating & Cooling Experts
Ottoniel
Tim Whalen
Are you a Comfort-Aire Heating and Cooling Expert? Answer questions, earn points and help others
