Question about KitchenAid KGST307 Gas Kitchen Range
Oven takes too long to reach temp and the smell of gas
After turning on the oven and setting the desired temp, it will take at least 30 mins before it will come close to the set temp. While using convection, will result in a heavy smell of gas... Call my locate fire department to confirm with a meter if there was an excess of gas than normal. Yes, there was. After just 1 min from turning on...The fireman turn the oven off immediately since the meter was starting to go up quickly. They advised me not to use again and call a tech.
  • 999 Answers
Sounds like a weak ignitor is not opening the gasvalve completely. Only testing the amp the ignitor draws will confirm. It could also be a sticking valve. Have a professional verify, this is not safe.
Eric
Posted on May 10, 2010
Bottom oven isn't heating to desired temp. Considering swapping the heating elements to see if one is faulty - thoughts?
try thermostat first. verify heating elements operational, if so check if tstats are same. swap if so, If not jump out tstat and see if higher temp achieved.
Sep 20, 2015 | Thermador PODC302 30" Double Electric Wall...
Oven temp fluctuates
It is normal for the thermal device to turn on and off. Obtaining a steady temp is not always possible. When setting a temperature on some ovens, they have what is called a tolerance point. That means a set temperature has a range of a few degrees up or down. At the Down point, the oven is triggered to energize the coils and bring the interior of the oven back to the settings desired. The other factor is opening the oven and allowing cool air to enter, or in some cases a leaking door seal allows air to enter and heat to escape.
Feb 26, 2014 | Kenmore 30" Slide-In Electric Range...
Is there any way to turn off the beeps- starting oven, when it reachs set temp, changing temp
Hello g harrison - Unfortunately the range does not have an adjustable volume level or cannot be turned off. It is designed to advise you of when the oven is starting or reach desire temperature.
Nov 29, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
My Frigidaire FEFL77ABF gets way too hot. When set at 350, temp soars to over 450. Have cleaned oven and tried resetting procedure, but neither worked. High temps are not consistent, so I can't...
Hi
This means a loose/broken wire on the oven temp sensor or the oven temp. sensor itself is bad and should be replaced. To solve this issue test the oven temp. sensor, it should read between 1080-1120 ohms, if the rating is more then that and the door appears to be closing fine then it is the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 02, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
I have a 30 inch Frigidaire self cleaning oven. The oven will no longer heat up in a normal amount of time using the bake function. Sometimes I can smell gas when using bake. It cant reach the desired...
Sorry to read about your problem, I hope this helps you out.
Bad gas control valve or oven temp control
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 22, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
When using the BAKE setting, the desired temperature is input and the oven begins a preheating phase. The temp will only rise to one degree less than the desired setting, and the oven never reaches the...
more than likely there is an issue with one of the temp sensors. you will need to press and hold clear then upper on off at the same time then release them then immed. press clear 3 times and hold on the 3rd till the service screen appears. on the right side you will see internal temp and catalyst temp they should be equal or very close. ill bet one of them is alot higher than the other if so the sensor will need replace but depends which one is bad as there are 2 of them. if the problem is on the lower just repeat above but use lower instead of upper
Dec 07, 2010 | Miele H398BP2 / H398B2 Electric Double...
Oven will not reach desired temperature and slight gas smell
Just had same problem it was nice it waited until christmas dinner, all i did to resolve the problem was switch the upper broiler igniter with the lower one for the oven. I tuned on the oven & it fired right up i never use the broiler on my oven so itll buy me some time. So if you can get the broiler to light try that but i did have the same low temp. & the smell of gas. Good Luck
Jul 29, 2010 | KitchenAid KGRT607 Gas Kitchen Range
The oven pre heats to desired temp and then loses
SOUNDS LIKE THE TERMOSTAT IS FAULTY REPLACE IT AND YOUR OVEN SHOULD WORK FINE.
Nov 09, 2009 | Thermador SMW272 Electric Double Oven
Takes too long for oven to heat up
Hhi, Is this a gas oven? If the ignitor is going bad, it will not open the gas valve as soon as it should.
Please let me know so I can assist you further.
Vic
Jun 21, 2009 | Hotpoint RGB745 Gas Kitchen Range
KitchenAid KGST307 Gas Kitchen Range Logo
233 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
