Question about Apple iTunes
Cannot connect to istore or any apple site at times. Run diagnostics and get the following: Firewall Information Windows Firewall is on. iTunes is enabled in Windows Firewall. Connection attempt to Apple website was unsuccessful. The network connection timed out. Connection attempt to iTunes Store was unsuccessful. The network connection timed out. Secure connection attempt to iTunes Store was unsuccessful. The network connection could not be established. Secure connection attempt to iPhone activation server unsuccessful. The network connection could not be established. Last successful store access was 2010-04-27 19:04:50.
Ipad disabled how do I connect it
Use the charger cord to connect the iPad to a computer with iTunes on it.
Dec 04, 2014 | Apple iPod touch
Problem is with iTunes
hi try this: The intention is to remove all iTunes and Quicktime software references. The following steps remove the software traces and worked on my machine. 1. Using add/remove programs uninstall Quicktime (click on Start ?> Settings ?> Control Panel ?> Add/Remove Programs) 2. Using add/remove programs uninstall iTunes 3. Right click on My Computer, use Search and remove all programs named Quicktime 4. Right click on My Computer, use Search and remove all programs named iTunes (except your iTunes download, so you won?t have to sit through another long download session). 5. Left click on Start, click Run, type ?regedit?, go to HKEY_LOCAL_MACHINE, click on SOFTWARE, and remove the Apple Programs folder (you may want to check in case you have other Apple applications, but all I had were iTunes and Quicktime in my Apple folder). Steps 1 through 5 should remove all traces of the software and now you can install iTunes. make sure you install all the latest updates from apple hope this will work for you :)
Aug 18, 2007 | Sony (DWQ30AB2) DVD RW Dual Layer Burner
Itunes error 3259
salam,dear, Resolution
  1. Remove any proxy information you have set up.
  2. Update to the latest iTunes software version.
  3. Try turning off your Firewall to see if the issue is resolved (this includes the built-in Firewall or a third-party Firewall such as Norton Personal Firewall, McAfee, Symantec, etc.). Learn how to turn off your Firewall:
Also check me
Apr 24, 2012 | Apple iPhone (16 GB) Smartphone
Itunes error 1200 cannot connect to itunes store internet connection okay
Sounds like a firewall issue, please try the steps in each article depending on what OS your using:
Using MSCONFIG to troubleshoot conflicts in Windows XPhttps://support.apple.com/kb/ht1275
Using Msconfig to troubleshoot conflicts in Windows Vista and Windows 7https://support.apple.com/kb/ht2292
Let me know how you make out..
Oct 21, 2011 | Apple iTunes
Why itune cannot connect to the store
ResolutionClick on the description below that most closely matches your iTunes Store situation:
I have been unable to connect for less than 24 hours Try quitting iTunes and reopening it. If the issue persists, it's possible the store is temporarily unavailable for maintenance. Try again in a few hours. You might want to check the iTunes Store discussion board to see if a connection issue is impacting many other iTunes Store customers.
iTunes Store Discussion Board (Mac)
iTunes Store Discussion Board (Windows)
I have been unable to connect for more than 24 hours on a Mac. If you haven't been able to connect to the iTunes Store for more than a day—and other customers on our discussion boards aren't experiencing similar issues—a software or internet service provider (ISP) configuration issue may be blocking your access to the iTunes Store. Click here to find out which ports and servers need to be allowed for iTunes Store access.
  • Your copy of the iTunes application may be out of date. If iTunes is out of date, it will not be able to connect to the iTunes Store. You can download the latest version of iTunes from our website:
    http://www.apple.com/itunes/download/
  • You may need to reset your keychain. Connection issues are occasionally caused by keychain issues. Click here to find out how to use Keychain First Aid to resolve this issue.
  • You switched to a new ISP. If you didn't install new networking hardware, your ISP may be blocking access to the iTunes Store. Let your ISP know about article TS1629 which can help your them configure their servers to allow iTunes Store traffic through.
I have been unable to connect for more than 24 hours on Windows. If you haven't been able to connect to the iTunes Store for more than a day —and other customers on our discussion boards aren't experiencing similar issues— a software or internet service provider (ISP) configuration issue may be blocking your access to the iTunes Store. Click here to find out which ports and servers need to be allowed for iTunes Store access.
  • If you have not done so, try the steps in this article to troubleshoot iTunes Store connectivity in Windows.
  • You upgraded to Windows XP Service Pack 2. Windows XP Service Pack 2, by default, enables the Windows Firewall. As with a third-party firewall, you will need to configure Windows Firewall to allow iTunes to access the iTunes Store. To do so:
    1. From the Start menu, choose Control Panel.
    2. If the Control Panel is in Classic View, skip to step 3, otherwise open Security Center.
    3. Open Windows Firewall.
    4. Click the Exceptions tab.
    5. Select the iTunes checkbox to enable it as shown here:
      2. Click OK.
      If you have further questions about configuring the Windows Firewall, contact Microsoft's Service Pack 2 hotline at (888) SP2-HELP. Read this article for compatibility information.
    6. You switched to a new ISP. If you didn't install new networking hardware, your ISP may be blocking access to the iTunes Store. Let your ISP know about this article which can help your them configure their servers to allow iTunes Store traffic through.
    7. The "hosts" file may be blocking the iTunes Store Instructions for Windows 2000 and XP: Find your hosts file. The hosts file is normally found in the following locations:
      Windows XP: C:WINDOWSSYSTEM32DRIVERSETC
      Windows 2000: C:WINNTSYSTEM32DRIVERSETC
      1. Select the hosts file. Then click the Edit menu, and choose Copy.
      2. Then, click the Edit menu again, and choose Paste. There should now be a duplicate of the hosts file named "Copy of hosts".
      3. Drag the original hosts file to your desktop.
      4. Right-click the "Copy of hosts" file and choose Open. You may be prompted to choose the program you want to use to open this file. Double-click Notepad.
      5. When Notepad opens, click the Edit menu and choose Select All. Then click the Edit menu, and choose Delete.
      6. Click the File menu, and choose Save. Close Notepad.
      7. Right-click the "Copy of hosts" file, and choose Rename. Type "hosts" (without quotation marks) and press Enter.
      8. Restart your computer and try connecting to the iTunes Store.
      • Make sure that your computer meets the iTunes minimum system requirements.
      • Make sure that your operating system is up to date:
        • For Mac OS X, use Software Update to determine if you need to update your system.
        • For Windows, go to Microsoft's Windows Update webpage.
      • Make sure that you can access the Internet on your computer.
      • You may have firewall or other security software that is preventing your computer from connecting to the iTunes Store. Click here to find out which ports and servers need to be allowed for iTunes Store access.
Aug 06, 2010 | Apple iTunes
I tunes store error 306.
Launch Internet Explorer
Click the Tools menu
Select Internet Options
Click the Connections tab
Click the LAN Settings button
Make sure that that "Use a proxy server for your LAN" checkbox is unchecked
Click OK till you are out of everything, and then close Internet Explorer
Try again in iTunes to load the store
if this dose not work
Then it is your security that is blocking you
try this
Sometimes this error can be caused by software on your computer that slows down the network connection. This error can also appear if you are downloading multiple items. I'd like to provide some steps that should help you successfully download your purchases.
It often helps to pause the download and then download items one at a time. These steps will walk you through doing this:
1) Open iTunes.
2) From the Store menu at the top, choose Check for Available Downloads. If you're unable to upgrade and are using iTunes 7, the option will say Check for Purchases.
3) Enter your account name and password, then click Check. Your purchases should begin downloading.
4) Under the STORE section on the left, click Downloads.
5) Click the Pause All button in the lower-right corner. This will temporarily pause all of your downloads.
6) To resume only one of the downloads, click the refresh button that appears to the right of one of the paused downloads.
Certain types of software can affect the way a computer sends and receives information from the Internet. Here are a few examples of these types of software:
  • Firewalls
  • Web accelerators
  • Ad filters
  • Virus protection software
If you have any of this kind of software installed on your computer, you will need to configure each of the applications to allow your internet connection to access iTunes freely. For instructions, please refer to the documentation that came with that software, or contact the software's manufacturer. You'll need to configure the software to allow these domains to send and receive data from the Internet freely:
itunes.apple.com
ax.itunes.apple.com
For assistance in configuring your firewall or accelerator software, you may need to contact the manufacturer or your Internet service provider (ISP). When contacting their support representatives, it may be useful to have the following information:
"Well Known" TCP and UDP Ports Used By Apple Software Products
http://support.apple.com/kb/TS1629
The following article helps Windows users pinpoint software conflicts that could cause the error:
http://support.apple.com/kb/HT1275
Using MSCONFIG to troubleshoot conflicts in Windows Vista
http://support.apple.com/kb/HT2292
Once you have managed to allow access to iTunes through other software, please follow these instructions:
1) Sign out of the iTunes Store.
2) Quit the iTunes application.
3) Restart your computer.
4) Open iTunes.
5) Select Check for Available Downloads from the Store menu at the top of iTunes, (if you're unable to upgrade and are using iTunes 7, you'll choose Check for Purchases).
If you can't find this option, you can also click this link to do the same thing:
https://phobos.apple.com/WebObjects/MZFinance.woa/wa/checkForPurchases
6) Enter your account name and password, then click Check. The missing item should begin downloading and appear in your Purchased playlist.
Please note that the iTunes Store cannot investigate every user's connection issue. Apple Discussions are another source of information about iTunes, where everyone from new users to professionals can interact and share their knowledge and experiences. You may find another user with the same operating system or ISP that may be able to help resolve this issue. You can find the iTunes discussions group at:
http://discussions.info.apple.com/itunes
If you are using a dial-up connection, you might consider downloading your purchases over a broadband connection, if you have access to one.
Apr 06, 2010 | Apple iTunes
Itunes says it cant connect to the itunes store because the internet isnt connected, but it is... what should i do?
Many connection issues can be resolved by configuring Internet-filtering software to recognize the iTunes application and the iTunes Store addresses (listed below).
(The following iTunes Store Internet addresses should be added as trusted domains to any filtering software that may be running:)
  • itunes.apple.com
  • ax.itunes.apple.com
  • albert.apple.com
  • You can configure your Internet software to allow iTunes to access the Internet. If you're using Norton Personal Firewall or Norton Internet Security, you will need to enable iTunes in your Firewall settings.
    Nov 26, 2009 | Apple iTunes
    Cannot download itunes since a recent firmware upgrade for ipod touch, went to apple forum site and told to delete apple,quicktime, apple mobile device support and now i can`t get itunes to download onto...
    Make sure VBScript is installed, turn off script blocking in anti-virus and personal firewall software, reregister VBScript, and then install iTunes." Resolution Download and install the latest version of iTunes.
    Install the latest VBScript engine from Microsoft for your Windows OS platform Windows 2000 Download and install VBScript version 5.6 for Windows 2000 from Microsoft, and then try installing iTunes or QuickTime again. Windows XP Download and install VBScript version 5.7 for Windows XP from Microsoft, and then try installing iTunes or QuickTime again. Windows Vista No download necessary. The latest VBScripting engine (version 5.7) is already included with Vista. Follow the steps below to register the VBSScript again if you still have this issue in Vista.
    Register the VBScript engine again If the latest VBScript engine is already installed, register it again. Note that you must be logged in as administrator or logged in as a user with administrator privileges for the computer to execute these steps.
    For Windows 2000 or Windows XP: 1. On the Start menu, click Run.
    2. In the "Open" field dialog box, enter the following command and click OK:
    regsvr32 vbscript.dll
    3. A message should appear stating that the "DllRegisterServer in vbscript.dll succeeded."
    4. Click OK and try installing iTunes or QuickTime again.
    Oct 19, 2009 | Apple iTunes
    My itunes and ipod say i need to restore my ipod, however when i try it says it can not connect to the internet so therefore cant restore, ive tried everything.and i have a connection up and running and...
    Ok your problem is the internet connection. If iTunes says there is no internet connection, there is no connection. Try closing itunes and starting it up again. Let me know what happens.
    Jun 17, 2009 | Apple iPod touch
    I can connect to the internet but not to Itunes store, AIM...
    Turn off your windows firewall and try connecting again.
    If it connects then windows is the culprit.
    It shouldn't be your iPod, but it definitely sounds like a firewall issue or an internet connection issue.
    The windows firewall is pretty harsh when it comes to programs that they don't endorse.
    also, If you want to keep your firewall on, open the security center and firewall, uncheck the box on the bottum to allow exclusion of http: site. It could be checked and only allowing exclusion of https: sites.
    Good Luck
    Feb 03, 2009 | Apple iPod MA446LL/A MP3 Player
    Apple iTunes Logo
    79 people viewed this question
    Top Apple Computers & Internet Experts
    paulcarew
    Martin Buck
    Martin Buck
    Paul Bade
    Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
