FixYa.com
Tags:
IBM ThinkPad T40 2373 PC Notebook
IBM Thinkpad t40 black screen (by 2 users)
posted by Ben813 on Mar 28, 2008
I have an IBM Thinkpad t40 that has a black screen if I push down on the key board the screen comes on sometimes and stays on sometimes. Someone told me it might be an issue with a loose chip under the keyboard, can anyone assist. Thanks in advance.
Comment by Ben813, posted on Apr 02, 2008
thanks for the info i was trying the first suggestion and everything seemed ok, I have looked at the second suggestion more in depth and that seems to be my issue, I will try to do that in the next couple of days. Thanks to all for the help it is greatly appreciated.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by mkoelby, posted on Apr 13, 2008
I have almost the same problems. Sometimes the screen start to flicker and within seconds it goes black. But if I look carefully I can still see the desktop and all the windows, so its like the sceen is still on but only with 2 percent intensity. What will help in my situation? It is a loose cable?
Best Solution
posted on Jun 13, 2008
Helpful (85)
Guest
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Ginko, sorry but your wrong. it definitly the GPU which always needs to be reflowed. Look up reflowing t40-41 gpu's. Also Ibooks have the same GPU chip set and are now running into the same problems. I hae contracts with 5 colleges in the area Western MA, I see them every day, this is a common problem..
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Apr 01, 2008
Helpful (85)
NETDESIGNZ
Rating: 85%, 1 votes
Chips DO get loose and what you're experiencing is a common problem with IBM T40's. The solder that holds the graphics processor to the motherboard is cracked and no longre consistantly makes a good connection. This problem can only permanently be resolved with a new motherboard, or reflowing the solder of the GPU chip on the old one with a heat gun. Do a search for "thinkpad solder reflow" in any search engine.
Good luck.
Rating Locked! (?) Ben813 has rated this solution as Helpful
Solution #3
posted on Mar 28, 2008
Thanks for Trying (70)
ginko
Rank:Guru Guru
Rating: 87%, 620 votes
Chips dont get loose. what is out of place is your lcd ribbon cable. It is a flat cable connected on one side to lcd display, on the other to lcd display. If you keep pushing the keyboard to get screen on you can break more parts inside your laptop. open carefully the laptop and adjust lcd cable on connector. be careful not to break keyboard flat cable, speakers/pad ribbon cable etc. when lifting the keyboard. Servicing laptop requires attention and involves risk of damage if you do not have enough experience.
Regards
Solution #4
posted on Apr 14, 2008
Not Rated (0)
SSSzar
Rating: 0%, 0 votes
First of all I would hook an external monitor to see if the graphics card is working, if you get a good screen on the ext. then you more than likely have a loose connection on the ribbon cable.
Can you Help with these PC Laptops problems?
PC Laptops
Notebook, Satellite
My C drive was formatted... Answer This...
PC Laptops
please help me agian
please help me about my... Answer This...
PC Laptops
problem vith lap-top
Several things you need to... Answer This...
PC Laptops
microphone problem
hi my name is anil my laptop is... Answer This...
PC Laptops
crstal eye
how do i use it to record Answer This...
Repair Service
Find PC Laptop Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
