The message says to open cover and when i open the cover it says close cover
  • 3 more comments
  • lorrainet01 May 10, 2010
    the error code reads A1 and message says pls open cover and when i open the cover and close it back the message is still there.
    MFC-3220c Brother
    plz help with this problem mfc-3220c error code A1 the message window read pls open cover so when i open and close the cover the message is still there
    soo much typing i asked for help with my Brother MFC-3220c it has a error code A1 not 41 the message reads pls open cover and when i do and close the cover back it reads the same thing.
    this is a message error A1 and i told u i have an brother MFC-3220c this message is stopping me from using my printer and scanner.
    President:
  • 1,382 Answers
Hi, To clear the message "PLS OPEN COVER" from the display follow the steps listed below:
  • Pull the scanner cover release lever (located on the right-hand side of the machine). This will release the scanner cover, causing it to slightly rise upward.
  • Lift up the scanner cover until it locks into place.
  • Examine the inside of the unit to see if any paper or debris is stuck inside. If you locate any paper of debris inside the machine, remove it.
  • Close the scanner cover and press on both sides until you feel the cover lock back into the closed position.
If you located paper and/or debris inside the Fax/DCP/MFC and removed it and the machine's LCD still reads "PLS OPEN COVER", call Customer Service for assistance.
Posted on May 11, 2010
  • 10,319 Answers
Depending on what model fax machine you have most do this on the message display
Posted on May 10, 2010
  • 713 Answers
Hi,i think you should clean the paper rollers of your machine,afterwards,put off the machine,then remove the plugg from the mains,then plugg it back after 5mins.make sure the cover is properly closed and well aligned.put on your machine,problem solved
Thanks and take care
  • 1,284 Answers
Hi, please you have to re-phrase your question, it does not pass any message across to me..
Take care
  • 1 more comment
  • Shehu Pro
    Shehu Pro May 10, 2010
    Hi, what type and model of fax machine is that....
  • Shehu Pro
    The error code 41 requires the replacement of the print head assembly, a relatively simple repair and now it looks a though the parts might be available at a fraction of what it had been previously listed for. Many of this machine can be repaired outside of the warranty period without spending more than what it will cost for a replacement unit.
    Take care
  • Shehu Pro
    Shehu Pro May 11, 2010
Bizhub 211 - doc cover open
Something is open. Check and make sure you closed everything securely.
May 30, 2012 | Office Equipment & Supplies
Tip
Main Error MINOLTA DI 1611, DI 2011 Messages and Their Remedies
PAPER JAM A paper misfeed occurred in the
main unit.
Open the cover at the indicated
location, and then remove the
misfed paper. (“When the Message
(Flashing alternately)
OPEN XXX SIDE COVER
All misfed paper was not removed
from the main unit.
Check the message in the display
for the location of the paper misfeed,
and then remove the misfed paper.
ORIGINAL DOC.JAM A paper misfeed occurred in the
Document Feeder.
from the Automatic Document
Feeder.
Open the Document Feeder Cover
and the Document Feeder, and then
OPEN DOC.FEED COVER
∗REMOVE PAPER IN
BYPASS TRAY∗
Paper is loaded in the Manual
Bypass.
Remove the paper from the Manual
Bypass.
FRONT COVER OPEN The Front Cover of the main unit is
open or not securely closed.
Securely close the Front Cover.
CLOSE FRONT COVER
DUPLEX COVER OPEN The Duplex Unit Cover is open or
Securely close the Duplex Unit
Cover.
CLOSE DUPLEX COVER
DOCUMENT COVER
OPEN
The Document Feeder is lifted up
(while a document is loaded into
it).
Securely close the Document
Feeder.
CLOSE DOCUMENT
COVER
DOC.FEED COVER OPEN The Document Feeder Cover is
open.
Feeder Cover.
CLOSE DOC.FEED
COVER
TONER EMPTY The toner is empty. Copying and
printing cannot be performed.
Replace the toner bottle with a new
one.
SUPPLY TONER
PAPER EMPTY The selected paper tray has run
out of paper.
indicates the paper tray, and
“XXX” indicates the paper size.
Load paper of the specified size into
the specified paper tray.
on Dec 18, 2009 | Office Equipment & Supplies
My Toshiba e-studio 233 copier is giving the error message, "Close side cover." Opening any cover to close again changes the message to "Close x" where x is the part opened, until that...
there is a switch at the side that is being push by the cover when it closes check this switch to be sure it hits the button when close or you may replace the switch it has a problem.
Jun 27, 2011 | Office Equipment & Supplies
When I try to print, I get the error: Top Cover Open: The printer cannot print because the top cover is open. How do I fix this?
Hi cduckyquack ,
  • All you need to do is close the printer cover if it's open , once it's closed you should be able to print correctly without any warning messages.
  • If the cover is closed and still you are getting the same message , then it might be a problem with the censor switch which indicates to the printer whether or not the cover is open, so if the switch / sense has gone faulty then you need to repair it.
  • Sometimes just because of dust the printer does not sense the cover being closed and it results in the error message that you have described.
  • Hope this helps ...) your feedback would be appreciated.
Jun 02, 2011 | HP DesignJet 1050c plus InkJet Printer
Message 'Clean Sensor' has appeared. Followed advise to open Cover D and close it again but to no avail. Has anyone got any other suggestions, please?
Follow the steps below to clear the "Clean Sensor" error message.
  2. Slowly close the cover again. c2600_close_cover_d.jpg This action will move the lever shown below and clean the sensor.
  3. Open and close the cover several times. Once the front cover is left closed the printer will start to calibrate.
Once complete, the error should no longer appear and the printer should resume normal operation.
Note: If the error message is still apparent after following the steps above, contact Epson for further advice.
Nov 16, 2010 | Epson AcuLaser C2600N Printer
Getting "inner cover is open" message
The inner cover is a flap on the inside in front of the carriage when it is at rest when the cover us open. You had to flip the inner cover down to access the ink cartridges.
Open the cover. The inner cover is in the center and need to be flipped up.
Good luck.
Dec 04, 2009 | Canon Pixma MP500 All-In-One InkJet...
Doc. Cover Open displayed
That usually means some sensor giving you trouble.
This is what brother recomends:
How do I clear the message Cover Open or Please Close Cover from the display?
The message Cover Open or Pls Close Cover may appear if the front cover
for the drum was not closed securely. Verify the cover is closed
securely by pressing the cover release button located in the front of
the unit below the Output Tray Support Flap and open the front cover.
Close the cover until it clicks into place.
If the message continues to appear on the display verify the drum and
toner assembly is installed correctly by following the steps listed
below:
1. Press the cover release button located in the front of the unit and
2. Remove the drum unit and toner cartridge from the unit by lifting it
up and out. Place it on a drop cloth or disposable paper to avoid
scattering toner.
3. Hold down the blue lock lever located on the right side of the drum
and lift the toner cartridge out of the drum unit.
4. Reinstall the toner cartridge into the drum unit by inserting it in
the drum until it clicks into place
5. Reinstall the drum unit into the unit. Make sure it is securely in
place.
6. Close the cover until it clicks into place
If that doesn't fix it, I guess you will have to talk to their support people.
Dec 15, 2008 | Brother MFC-8840D All-In-One Laser Printer
Error mesage
No solution, but I have the same problem. THe printer starts up fine, I hear no grinding noises or other "funny" nioses, and then displays no error message... UNTIL I ask it to print. Then I get a message that says, "Pls (please) Open Cover".
I open the cover and it says "Please Close Cover".
I close the cover and it says, "Please Open Cover"
and this happens forever!
Does anyone have any ideas? Can anyone help me?
Stefan
Mar 05, 2008 | Brother MFC-8440 All-In-One Laser Printer
Brother Intellifax 2800
Pls open cover = Please open cover. Probaly has a jam - Open the cover remove the drum/toner unit and check for jammed piece of paper under of in the drum unit.
Jan 24, 2008 | Brother IntelliFAX 2800 Laser Fax
Printer cover open error message
I had that problem too.
Unplug the printer.
Hold the printer cover open while you plug in the printer.
Then wait for the printer to power on while still holding the cover open.
Then close the cover.
The buttons should work and th error message should be gone.
It worked for me.
Nov 01, 2007 | Lexmark X2250 All-In-One InkJet Printer
71 people viewed this question
jasbo
jasbo
