Question about Rowenta DG-980 Iron
Trigger button broke during ironing. What to do?????
While ironing, the trigger just quit working. Now it is loose and sloppy. The button doesn't work anymore. No way to make the steam come out. What to do???? Is it worth trying to fix or should I just get an entire new unit???
    Scholar:
  • 70 Answers
The fix is easy, order the trigger that has an actuating tab that is probably broken off. Gently pry up the blue cushion from the front to the back near the cord and you will see the tab lying over the switch. I order my parts from the Rowenta Region Service Center below:
California Electric Service in Concord CA (it is the only Rowenta repair station in California) go to either of the following addresses:
their website is: http://www.californiaelectricservice.com/
or tech service: service@californiaelectricservice.com
Keep us informed as you resolve and solve the problem. It is a fine machine and well worth the repair.
Posted on Jun 06, 2010
  • Wes Kilgore
    Wes Kilgore May 07, 2014
    The link for the "Electric Service" place is BROKEN/DEFUNCT.
How to repair breville steam iron trigger
The trigger may have to be replaced.
Apr 02, 2018 | Breville Irons
My Rowenta pro precision iron steam station gets hot but doesn't steam. How do I get the iron to produce steam?
There are two cause. One the boiler resistance doesn´t turn of because of snap disc or bimetal thermostat fault or because a coil in the working valve (security valve). But if you can heard a click of opening movement of valve when you push the button it is able to be a thermostat.
Apr 12, 2016 | Rowenta Irons
Ssteams constantly without pressing steam trigger
Sounds like your trigger valve in the iron portion (not the tank) is jammed open. It could be from mineral deposits so maybe try running it with a solution of distilled water and a couple of tablespoons of vinegar in the tank. Wiggle the steam trigger to try to release any scaling that maybe present inside the valve. If your steaming from the iron stops, you've fixed the problem so let the iron cool and rinse the tank using ONLY DISTILLED WATER which anyone knows is the only type of water to be used in ALL appliances. Minerals in regular tap water kill appliances quickly. Never use tap or bottled drinking water even if the directions say it's okay. Iron some old rags or towels with a tank of distilled water to make sure no mineral deposits or staining steam comes out after cleaning.
If this fix doesn't work, you can buy a replacement iron portion online..try 1800Parts.com. It's cheaper than buying a whole new iron but you may need a repairman...I've never tried to fix this portion of my DG5030 iron.
Aug 28, 2013 | Rowenta DG5030 Iron
The trigger on the handle is not working and neither is the steamer HELP
Need a little clarification, do you feel/hear click when pressing trigger? No means the trigger inner actuator tab is broken...easy fix, just gently pry off cush rubber cover on handle from front to rear (gently to not scar up the works) and lift. Steamer not working?...is it getting hot? Steam building up in the boiler? Need a little more information here before I can proceed...
May 31, 2010 | Rowenta DG-980 Iron
DG-980 Iron: The button to use the steam is stuck. I was ironin...
Hi Mary, sounds like something jammed in the trigger mechanism or the microswitch button is stuck in the housing. Unplug the iron, let it cool. Gently pry up the blue cushion from the handle from the front towards the rear cord, you will see the trigger, the actuator tab and the microswitch button (nib) that should be sticking out, if it is flush with the housing it is jammed down. That switch is replaceable, but I don't know how savy you or your appliance servicer are at replacing it. Here is where I get my parts:
Please keep us informed as to your progress resolving this...
May 18, 2010 | Rowenta DG-980 Iron
Steam button not working
I had the same problem. I found the trigger button at SmallAppliances.com. You'll have to pry off the rubber grip, and unscrew one or two screws on the handle, bu the trigger inserts neatly into the space. Screw it back together, snap on the rubber grip and it will work like new. Below is the part number & price.
Rowenta DG0123 Knob Trigger, Blue $9.99 (plus shipping)
Watch out, the next thing that will go is the on/off switch. Once it starts getting difficult to turn the unit on or off, just plug and unplug it until you get the new part, or you will be stuck one day and need the iron and go to turn it on and it wont start.
The part is $20, and the same site has it available.
Aug 29, 2008 | Rowenta DG-980 Iron
Steam trigger broke
i did some research for you and i found out the main web for Rowenta Usa and they do provide spare part as well.
You can also send the iron to a repair center near to you if under the warranty at no cost.
This is the information i got from them
http://www.rowentausa.com/rowenta/frame.aspx
Good Luck
Jun 17, 2008 | Rowenta DG5030 Iron
Rowenta DG-980 Iron Logo
532 people viewed this question
Top Rowenta Irons Experts
Joseph Hoffmann
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
