Question about ViewSonic VX910 19" LCD Monitor
Viewsonic VX710 Monitor scrren goes black
The screen on my monitor is totally black..... It was working great yesterday, but today nothing. When I tried unplugging everything and rebooting my system, it quickly presented a normal screen image, however it was only for a send, maybe two seconds at the most.
I have also tried pushing every button available and in doing so (this might be the biggest clue?) when I push #2 on the monitor, the screen displays again, but only for a second/second and a half, then goes black again. This leads me to beleive it's just a setting issue, however if I can't see the screen for more than a second or two, I don't know how I can see anything long enough to make any changes.
Please HELP............ This is my home office computer and I need to access my company documents ASAP
THANK YOU.....
  • 4 Answers
Replace all caps on power supply board check values
should not cost more than 20 us. and 1 hour soldering
easy fix but new monitor goes around 100 us.
can you do it???
Posted on May 11, 2010
The picture on my monitor works for a half of a second when I first turn it on, then it fades to black. What can I do to fix this?
If you can see your desktop faintly in the background, this means that the CFL lighting tubes have stopped working and would need to be replaced. However try to increase the brightness using the buttons on the monitor.
Rate me high.
Nov 01, 2010 | ViewSonic VX710 17" Flat Panel LCD Monitor
My Viewsonic 2235wm goes on and off frequently
Look for bad caps as shown in my VX2235 album.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find.
Oct 25, 2010 | ViewSonic VX710 17" Flat Panel LCD Monitor
My viewsonic vx710 lcd monitor shuts off after @ a hour of operation then won't come on for @15 minutes
Check the power supply section first.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed VIEWSONIC monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
May 31, 2010 | ViewSonic VX710 17" Flat Panel LCD Monitor
Monitor will not turn on
It could be bad caps on the power supply. Look for bulging caps and replace them if bad.
Sep 12, 2009 | ViewSonic VX710 17" Flat Panel LCD Monitor
ViewSonic monitor 171b. I turn and after about 30 sec goes black
The problem could lie in your monitor screen not having enough power. This could lead to total destruction of your monitor as i had this problem before. The best solution: Get a new monitor or get it fixed.
Jul 11, 2009 | IBM 17IBMRBABLKNR
The problems is my monitor (VeiwSonic VX910) is blinking evey few seconds from destktop screen to black screen. help!!!
PSU- Board, Rev.C
Item: B-PS-0204-0076
Compatible with: VX710 VX910 VX912 VX924
BER-2 Number: D9 SCRAP NOT AUTHORIZED
(This item has been discontinued and not available to order.)
Please order B-00002481 instead. Your Price: US$45.00 Each
Jan 08, 2008 | ViewSonic VX910 19" LCD Monitor
Viewsonic VA712b 17 " flat screen monitor
Realheadache, Unusual problem, it could be the resolution and refresh rate setting your PCs video card is currently set at. I don?t know if this will fix your problem but its worth a try: - Now go to your PC with the old monitor connected, right click anywhere on the desktop. - Left click Properties from the box that appears. - When the Display Properties box appears click on the Settings tab. - Make note of the screen resolution. - Change the screen resolution to 1024 x 768. - Click on the Advanced button in the lower right hand corner. - In the next box that appears click on the Monitor tab. - In the Monitor settings section of this page record the value of the Screen refresh rate. Then change it to 60 Hertz. - Close this and the Display Properties box by click on the OK button. - Now try connecting your new monitor. Let us know if this helps and as always please don?t forget to rate this posting.
Feb 04, 2007 | ViewSonic VA712B 17" Flat Panel LCD...
ViewSonic VX910 19" LCD Monitor Logo
276 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
