Question about Car Audio & Video
It sounds like its going to turn on when the power button is pushed, but it won't turn on.
  • andrumarcus May 10, 2010
    Where and how do I put the code in?
    How and where do I put in the code?
    President:
  • 2,923 Answers
Does your interior light work? How about the clock?
The radio has two power circuits, one for memory (constant 12v+) and one switched 12V+ lead. The radio fuse is for the switched lead and the memory lead is usually on the same circuit as the interior lighting, cig. lighter, and/or clock. Make sure you check them out as well.
Thank you and good luck!
Posted on May 10, 2010
  • 1 more comment
  • Melvin Ramos
    Melvin Ramos May 10, 2010
    If everything else works except for the radio, then you may need to punch in the anti-theft code. The radio becomes disabled once the battery is removed from the car or once you replace the alternator.
    You need to take the radio out, get the serial number on the side, contact the dealer or the manufacturer, and they will give you the code.
    Punch the code in, and your radio should work.
    Thank you!
  • Melvin Ramos
    You need to access the menu of your car radio, then there's an option to put the code. But, that will depend on the brand of your car and radio.
    The manufacturer will also give you the instructions on how you will power up the radio and how you can punch the code in.
    Thank you!
  • Melvin Ramos
    It is designed to be like that, so that it will be useless once it's stolen.
Simply won't turn on. All the power at the plug has current but nothing when you push the on button.
Gary, Could be power supply failure. Links below for trouble shooting your problem.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How To Fix Laptop That Won Turn On
Laptop not powering up won turn on Fix Solutions
My laptop won turn on when push the power button
Here What to Do When Your Computer Doesn Turn On
Feb 26, 2016 | Computers & Internet
Dryer won't tumble but gets hot
try holding the door switch with your finger and turning the drum with your hand after you push the start button , if this does not start it then you will have to replace the motor
Feb 24, 2013 | Dryers
Dell 8200 beeps 10 times monitor won't come on says power saving mode
Hi
Remove the sound card and blow the slot with dry air to rid off dust.
Examine it to make sure nothing's damaged and fix it again.
Checkout the RAM's.Probably remove them,wipe the slots off dust and fix them again.Make sure they're well seated on their slots.
Feb 05, 2012 | Computers & Internet
1996 nissan pathfinder driver side window won't go up and down
does it click or grind when pushing window button if so the window lift track may need replaced, if there are no sounds then disconnect the wires from the lift motor and with the ignition on so power is sent to switch, push button and check wires to 12 volts dc. If no power I would replace the driver side switch after checking the wires for defects. If there is power then I would re-install wires to motor after turning off key and try button again with power on. replace motor if it doesn't work.
Dec 31, 2011 | 1996 Nissan Pathfinder
PS3 won't turn on. When I push the power button
Sounds like your system has a failure in it, that needs professional assistance. If you want your data saved you should try a place called www.videogame911.com. They do fast repairs and can save your data.
Jun 11, 2011 | Sony Video Game Consoles & Games
My dryer won,t start. When you set the timer and turned the starter on you hear a sound that seems it will run but when you let go the starter it just won/t run
You have a bad motor. There should be a button you can press to make your dryer go while the door is open. Hold that and push the button in and then turn the drum. if that doesn't make it go then it is your motor
Apr 18, 2011 | Frigidaire Dryers
Flashing green power light on TV
have the power supply checked out sounds like it went out
Jul 09, 2008 | JVC AV-56WP74 56" Rear Projection...
Pv900 power amp 300 watts
Recheck your switches on the back sounds to me like you have the subwoofer crossover setting turned on.
Nov 12, 2007 | Audio Players & Recorders
Car Audio & Video Logo
27 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
