Question about Navionics: Gold+ Chart Cartridge
The depth contour line on map navonic lake chart
The depth contour lines on navonic lake chart chip have disappeared.
Installed in a lowrance LM480 depth findwe.
3 Suggested Answers
SOURCE: installed chip on hummingbird 787c2 but there's no detailed map
Low detail charts included. You have to buy high detail charts!
Posted on Apr 16, 2009
bigcass
  • 35 Answers
SOURCE: I have a Lowrance 7200C GPS (marine) unit with a
Not showing the Depth Contours usually means it doesnt have that programmed on the chip.
The best Chips Ive ever seen, used or worked with for the Lowrance's are the "Navionics" and Fishing Hot Spots. Both can be obtained from Cabela's...either retail or online. And normally go from 99bucks for last years maps to 199 for this years. Hope this helps.
Posted on Oct 16, 2009
I need a map chip & onwers manual for a Lowrance HDS 5 like insight. Serial no. 102574610. Where can I get them?
here is the manual
HDS-5, HDS-7, HDS-5m & HDS-7m - Lowrance
https://www.lowrance.com/.../Lowrance.../HDS-5-7-5M-7M_OM_EN_988-10041-00...Sonar references do not apply to the HDS-5m and HDS-7m GPS only units. Manual Conventions. When you are instructed to press a button in this manual, the ..
Software Upgrades here
Lowrance HDS 5 Software Google Search
and finally Mapping
mapping for Lowrance HDS 5 Google Search
and specifically, INSIGHT
Insight Genesis - Download free Lake, River and Coastal Maps
https://gofreemarine.com/insight-genesis/Make your own maps and download free maps from the community. Insight Genesis' cloud-based software does all the work, automatically processing ... with sonar signals from your existing Lowrance, Simrad or B&G transducer. ... The cloud automatically backs up all your data, protecting against lost or damaged SD cards.
Jun 26, 2017 | Lowrance Boating
How do I get my lake map chip to come on
With your card in your unit follow these steps it should accomplish letting you view your map data.
push MENU twice
Highlight CHART push ENTER
Highlight CHART DATA push ENTER
Highlight LOWRANCE push ENTER.
You will note there is an option for Lowrance and Navionics, if you select Navionics you will see a distinct difference in the way the base map displays on your unit.
Hope this helps.
Feb 11, 2015 | Lowrance HDS 5 Fishfinder GPS Chart...
Lowrance lcx-111c hd, single beam transducer
Hey Tingo,
I have two 113's,, the problem sounds like the transducer is going bad,, Try this.. unplug all your connections,, replug them and see if it helps...
Don't get me started on $$$ updates....
May 15, 2017 | Lowrance Lcx 112c 10.4" Screen Color Gps...
I have a Lowrance 7200C GPS (marine) unit with a "Navico 041-0680-17 chip. It doesnt show the depth contours, is there an upgrade or do I buy another chip? and if so, what chip will be best for my unit?...
Oct 15, 2009 | Lowrance Globalmap 7200c Gps 7" Screen...
Loading Maps
MapCreate Topo does not have lake maps. There are 'some' maps on Lowrance's web site (Free Enhanced Lake Maps) but you may need to purchase lake maps on SD cards for the area you're interested in.
Jun 02, 2009 | Lowrance iFinder H2O GPS Receiver
I cannot bring up a marine chart showing depth and markers on my
Marine maps must be installed on SD cards. The base-map does not contain marine maps. Most on-line or brick-and-mortar hunting/fishing stores carry map cards for Lowrance units.
May 28, 2009 | Lowrance iFinder Expedition C Handheld GPS...
I have a lcx 28c hd fish finding sonar and mapping gps
I've had several similar units, and used them with Navionics HotMaps Premium series chips. You must select Menu. The "Browse files" to access the MMC card option. Once the selection screen opens, choose which card or file you want.
FYI...All of Lowrances HD models come preloaded with pretty much every major lake and river in the US.
Lemme know if this helps...
Triton72
Mar 23, 2009 | Lowrance LCX-27C GPS Receiver
Will not recognise navionics chart
take the chip out and put it back in why the unit is on
Sep 05, 2008 | Lowrance GlobalMap 3500C GPS Receiver
How do you get the gps to show depth and markers on the water?
It depends on what model you have. Most chartplotters require a chip with regional chart data. Most Lowrance models use Navionics charts. If you have a chip in the GPS, go to the map screen and press the "menu" key. Somewhere in the map setup menu will be a field where you can specify which chart to display.
For example a Navionics gold chart may cover the entire east coast, but it is broken down into a few sub regions. If you are boating in New England you would select the sub region labeled Northeast. Some of the earlier models didn't name the regions, they used model number for each region such as "XL904G". In that case your best bet is to try each one until you can view the charts in your area. Zoom in to 1/2 mile scale to make sure you can see charts.
If you have done all that and still can't see the chart details, there is also a setting in the map setup menu that allows you to set the level of detail. Make sure it is set to normal, more, or most. If you see a declutter setting on the setup menu, try setting it to off.
Jul 21, 2008 | Lowrance GPS
Troubleshooting my Lowrance LC X - 15MT Unit
All of my lowrance products ar very particular to cards. Both my I-finder and my X-15MT would not read cards that other readers would read. I finally have three cards that work and guard them very carefully. PS. I found this via Lowrance troubleshooting and received great help from a tech there. You can check the cards before registering them by placing them in your unit and see if it shows the card present.
May 03, 2007 | Lowrance LC X-15MT Sonar
Navionics: Gold+ Chart Cartridge Logo
60 people viewed this question
Top Navionics Boating Experts
Mike Marcotte
Mike Marcotte
Steve
Steve
Steve P
Steve P
Are you a Navionics Boating Expert? Answer questions, earn points and help others
