Question about Dryers
Dryer runs 2-3 mins. then stops turning. Turn it by hand, it will restart for 2-3 more mins.
  • Dryers Master
  • 43,501 Answers
There can be many reasons why your dryerDryer runs 2-3 mins. then - 2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer Repair ? The dryer will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Posted on May 12, 2010
Dryer runs 20 mins, stops, must be restarted over and over. run time becomes less and less after each restart.
check thermal switch on back of dryer,join wires together(tape with electrictape so i tdoes not touch body)then turn on,if runs properly there you go.or change timer
Mar 28, 2014 | Maytag Neptune MDE7500AY Electric Dryer
Dryer stops
If the hum is loud I would suspect something is jammed and the motor is stopped leading to a heavy current running through the motor. After 5 or 10 minutes I would anticipate the circuit breaker would trip or the motor would burn up. If the humming suddenly stops then a thermal overload switch might be activating and when it cools down normal operation resumes. This is my only insight.
Jun 08, 2013 | Kenmore 73952 Gas Dryer
Amana DLE330RAW Elec Dryer starts then shuts off & wont turn on
There can be many reasons why your dryer2_bing.gif will not turn...
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
heatman101
Jul 08, 2010 | Amana DLE330RAW Electric Dryer
Kenmore dryer won't work upon restarting
Yeah, I would buy that new motor....
heatman101
May 12, 2010 | Kenmore 73952 Gas Dryer
Dryer noise sounds like bearing out or a roller is bad model # 417-98702891
my dryer makes a funny noise about 10 to 15 min. into cycle. then shuts off. if you try to restart will not restart unless you hold start button down. once you let go will stop. wait about an hour and dryer will run for another 10- 15 min and start process over again.
Feb 22, 2010 | Kenmore 98702 Stacked Washer/Dryer
The igniter fires the gas, it burns for a minute or less, then stops and won't restart unless the dryer is stopped and restarted? Is this a coil problem?
Sounds like a clogged vent. If you let it run for a few minutes after it shuts off, it will come back on. Your overtemp. thermostat doesn't allow it to work, because the hot air is not being sucked in. But to answer your question, not the coils for sure in my opinion. When coils fail, it won't turn on after 10 min of running or more. Not right away.
Maytag Neptune dryer repair in orange county, ca
appliance repair orange county, ca
Feb 07, 2010 | Maytag MDG9206 Dryer
Dryer only shuts off and restarts during cycle
Get a new timer. It is not that expensive and the wiring is fairly simple.
Jan 14, 2009 | Dryers
Setting model number jr3060-59f
1. set mode to CHR with the bezel fully in.
2. pull bezel out 2 notches. This will set all (or most) hands to 12.
3.press A (top button) repeatedly until you get MIN in the left window
4.turn the bezel to move the min hand forward.
4a. turn the bezel several clicks in quick sucession to get the minute hand to continue to move in the forward direction. This will "drag" the 24 hr UTC hour hand froward 1 hour per 1 revolution of the minute hand. if the minute hand stops before you want it to repeat step 4a. continue till the 24 hr UTC hour hand points to 24.
5. to stop the minute hand turn the bezel backwards 1 click. remember however to approach the 12 position with the minute hand in a clockwise direction.
Mar 25, 2008 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
Will run for about 1 min then stops
might be that the Drum is stuck, can you turn it by hand...it is possible that the drum has just got stuck, or maybe you have a drive belt problem . I hope this helps
Sep 27, 2007 | Amana DLE330RAW Electric Dryer
Noisy dryer
Don't turn the tub to much this may make the belt run off track . If the machine makes a rumble at the beginning and at the end or when u stop the machine and restart it it is probably the blower wheel,it is made of plastic ans wears out on the motor shaft.
Apr 05, 2007 | Maytag LSE7806A Top Load Stacked...
Dryers Logo
54 people viewed this question
Top Dryers Experts
