Question about A.O. Smith SQ1102 Pool Pump Motor
I have a AO Smith pump and need front bearing and seal kit for the pump-------help
  • 2,841 Answers
Need the model number of the pump. Here you can find a distributor in your area which may help you. http://www.aosmithmotors.com/Distributor/default.aspx?id=40&ekmensel=fb5d653b_6_15_btnlink This link will more than likely lead you to a parts supplier. http://www.aosmithmotors.com/
Posted on May 10, 2010
What size bearings does AO smith motor 8d-10-1n11cb use
better off replacing whole motor or pump if bearings bad soon seals because they got hot less headache replace whole pump
May 27, 2016 | AO Smith Pool & Spa
What bearings I need for AO Smith century 3.6 HP part 186364
cannot buy bearings for motor must replace motor dont forget seals
Feb 26, 2015 | AO Smith Pool & Spa
Pump drawings
if seal went probably ruined bearings replace whole unit less hassle
Sep 26, 2013 | AO Smith Pool & Spa
Help! Just opened my pool and the pump/motor (which is only 2 years old) is very noisy. Sounds like it could be the bearings. Do call someone to the house, disconnect and take to a repair shop, ord
Disassemble the pump to the point where you can see the whole impeller. Then turn the power back on to verify that it is the bearings, and not trapped debris causing the noise. If it is the bearings the short answer is to replace the motor.
Bearing failure is usually related to a leak at the pump seal. This results from either a faulty seal installation, or the pump running excessively hot (from running w/o water).
When replacing the motor carefully examine the seal plate (where the seal is set) front and back for any cracks or deformity. If the new seal doesn't set exactly, it will leak.
Apr 03, 2013 | Smith AO Pool Pump Motor
Need replacemant bearings for 1 hp AO Smith pool pump motor
6203 2rs c3 are the bearing you need. best to have a pro do it. should cost around $75, thats what I charge /w free shaft seal. remember to prime the pump after any repair
Mar 27, 2013 | AO Smith 1 hp 3450rpm 56J Frame 115/230...
Oil a ao smith motor
no way to lubricate unless oil hole on shafts
Oct 27, 2012 | AO Smith Pool Pump Motor Hayward Swimming...
How to replac bearings in century pool & spa motor
if bearings are bad motor overheating and ruining seals replace whole unit less hassle
May 10, 2012 | AO Smith 1.5hp Pool Pump Motor 2 Speed Ao...
Ao smith century 1 hp 56y pool pump sqeals for few minutes at start up and then is ok - sounds like bearings - unit 6 yrs - what is fix
How do I change the front and back bearings in this pool pump motor 1hp. ao smith motot I did the shaft seal last year myself but needs bearings now. thank,Bill
Feb 06, 2011 | AO Smith 1 hp 3450rpm 56Y Frame 115/230...
I have an AO Smith SQ1102 pool motor that stopped running. it blew the breaker It was very loud, So I know it needs bearings. I have 3 AO Smith above ground pool motors that are more of a round flange...
no. it sounds like its too late for your motor , no need for a pool pump motor repair kit ,there is one on ebay . but it sounds like your motor is toast if it blowing the breaker... hey i could be wrong . look for a shop that has free pool pump motor testing .use your zip code in your search..
as far as using the bearings off them threw bolt motors. do what ya got to do, but you might find that the front bearing is a bigger bearing .. i charge 85.00 to rebuild a 2.. but you must catch them befor its too late 2hp new = big $$$
best of luck .. and if'n i was any help ? push on them thumbs up to vote ... thanks jay..oh PRIME THAT PUMP !
Jul 30, 2010 | A.O. Smith SQ1102 Pool Pump Motor
How difficult is it to replace the bearings on an a.o.smith sq1202 pump
Bearings MAY be bad from a bad seal. To do this right you MAY need an arbor press to insert new seal without damaging it.
Aug 05, 2009 | AO Smith SQ1202 Pool Pump Motor
A.O. Smith SQ1102 Pool Pump Motor Logo
101 people viewed this question
Top A.O. Smith Plumbing Experts
Donni Steen
Tom Chichester
Are you an A.O. Smith Plumbing Expert? Answer questions, earn points and help others
