Question about Rowenta Commercial Garment Steamer - White
Rowenta IS8050 steamer won't heat up. I am trying to access the inside so I can replace either the fuse or thermostat. I removed the 4 phillip screws but the unit still won't cme apart. I'm beginning to think the 2 swivel wheels may be the issue. Also do you know how I can get my hands on a schematic? Rowenta is no help and their service center won't even talk to you unless you send in the steamer.
2 Suggested Answers
SOURCE: rowenta commercial steamer
got this off the manual for the IS 7800
CLEANING
Remove water container and clean the main unit with a damp
cloth. To maintain maximum performance, your steamer must
be descaled occasionally. The descaling intervals will depend
on the water quality and the frequency of use. The unit should
be descaled at least once a year or every 100 hours of use.
For descaling proceed as follows:
1. Unplug the unit and remove water container from main unit
by releasing container lock and pulling up.
2. Fill it with fresh water and shake vigorously to remove any
scale. Pour out the water and repeat if necessary.
3. Purchase a quality decalcifier agent and follow the instructions
of the manufacturer for the proper ratio of the mixture
to water and use.
4. After filling the water container turn it up and down to
descale.
5. Attach reservoir to unit, plug in and switch on.
6. Let the appliance run until the water container is almost
empty and do not steam any clothing with this mixture.
7. Unplug and detach the water container. Rinse it with fresh
water.
8. Fill water container with fresh water and repeat steps 5 and 6.
Note: If after descaling you believe that there is still buildup in
the boiler, repeat steps 1-8.
Posted on Oct 31, 2008
Need Replacement Support Pole for Rowenta Commercial Steamer
According to eReplacementparts the DC0084 part you're looking for is not available for retail sale. They do however inform that that the part is avaiable for sale via Rowenta Service Centers. You can find a list of these Rowenta Service Repair Centers by state, here. I hope this helps & good luck!
Nov 07, 2013 | Rowenta Irons
Rowenta Pro Steamer only works 5 minutes then shuts off!
temp limit switch bad... replace iron(sorry)
Jul 04, 2012 | Rowenta Irons
ROWENTA IS8050 INSTRUCTION MANUAL
Rowenta IS8250 Garment Steamer instructions are no longer available from Rowenta.
May 28, 2012 | Rowenta Commercial Garment Steamer - White
The power to heating section suddenly went off. Is there an internal circuit beaker or fuse?
check your power cord if it has a break from the plug side.if not take it to a repair shop for repairs. the steamer has a element inside that gives off the heat if that goes bad then there is no where it can be replaced or repair.but if its the wires then repairs can be made.best way to know that is to take it to the repair shop.good luck.
Sep 23, 2011 | Rowenta Commercial Garment Steamer - White
How do i open d rowenta garment steamer to change the fuse or burnt wires
There are four screws (Phillips) but you need long thin screw driver to remove them. Then there are TWO screws underneath the Castors. Just pop the Castors and turn them and you will see the screws. BTW there are two fuses inside. One you can replace and the other one is soldered in and you need to be little skilled to replace it. Chances are if the first one blew the second one should be OK. Good luck.
Jul 04, 2011 | Rowenta Commercial Garment Steamer - White
MY ROWENTA 1550W UPRIGHT STEAMER NO LONGER PRODUCES STEAM. WHAT MIGHT BE WRONG AND HOW CAN I ATTEMPT TO FIX IT?
I have a Rowenta garment steamer. It will turn on but no steam comes out. Does it need to be cleaned from the build up of iron, etc. from the water? If so, how do I go about this?
Dec 04, 2010 | Rowenta Commercial Garment Steamer - White
I need to purchase the thermostat/steam generator that is inside the water tank of the rowenta dg050 iron/steamer. where can i find that part? i know it is the problem
I would call a Rowenta service center to find the part and cost. If you are in the US go to the After Sales Service, Service Centers at
http://www.rowentausa.com/rowenta/frame.aspx
If you are outside of the US go to the www.rowenta.com site and select your country.
Aug 09, 2009 | Rowenta Steam Generator DG050 Iron
2 screws on bottom of iron are rusted
they do take a special tool. However I have used an allen wrench and it will remove them. Take them to a local hardware store or sears and get the same screw thread pitch in stainless steel and with a phillips or slotted head
Dec 30, 2008 | Rowenta Powerglide DM273 Iron
Rowenta Commercial Garment Steamer - White Logo
624 people viewed this question
Top Rowenta Irons Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
