Question about Whirlpool LER2614JQ Electric Dryer
Whirlpool LER2614 repair
I tried to reply without success that I fixed the problem I posted previously.
The symptom was, the dryer would not turn on. As it turns out it was the
paddle that controls the door switch. It was broken.The dryer works fine now.
The problem was that the dryer did not work when the start button was pushed.
The cause was the paddle that controls the door switch. I fixed it but thanks to those who gave suggestions.
Posted on Mar 31, 2008
SOURCE:
Whirlpool dryer duet quit during drying cycle everything lights up works is normal except it will not turn on when you push the start button it just makes a click sound in the back of the machine
Whirlpool Duet Dryer - turns on, clicks, won't run
you may need a technician if you are not savy with electrical testing but here is your route to fixing and by all means unplugg first
  • #1Alwckw4
    Premium Member Join Date Sep 2013 Location Florida Posts Whirlpool Duet Dryer - turns on, clicks, won't run
    Model Number: GEW9250PW1
    Brand: Whirlpool
    Age: 6-10 years
    My dryer turns on but when I click start, it simply clicks, but doesn't run. Any ideas would be greatly appreciated.
  • September 10th, 2013, 12:14 AM#2 Jake
    Appliance Tech - Admin Join Date Aug 2004 Location McMullen Valley, Arizona Posts
    Ok, lets first check your thermal fuse.
    You would need to take off the lower front access panel under your door, then take off the duct assembly#45, by removing the two #11 screws as shown in your parts diagram here: Bulkhead parts for Whirlpool GEW9250PW1
    Unplug or turn the breaker off to your dryer first before opening it up and ohm testing.
    Then you will need a multimeter to ohm your thermal fuse. Its #59 in that parts diagram, take both wires off the thermal fuse first.
    Here's the thermal fuse for your model you can order here if needed:
    Thermal Fuse WP3392519
    This video shows how to test it:
    Let us know what you find.
    If the thermal fuse tests good, We've had a few members report door switch problems.
    You can check it for continuity with a multimeter to make sure.
    Here's that door switch you can order:
    Door Switch WP8283288
    It shows on Page 4-6 in your repair manual I posted a link to below how to access it to check/change it. Make sure your dryer is unplugged!
    Push the button in on the door switch with one meter probe on COM and the other meter probe on NO and see if it reads. Normal ohms is 0-1.
    If the thermal fuse and door switch check fine, then its the control board.
    Here's the control board for your model you can order here:
    Main Control Board WP8546219
    I'm attaching the repair manual pdf for the Whirlpool Duet dryer below.
    It shows how to get access to the control board on page 4-2 through 4-4.
    Unplug or turn the breaker off to your dryer first.
    below is a link to the manual
https://www.applianceblog.com/mainforums/attachment.php?attachmentid=12424&d=1378793669
Feb 03, 2018 | Whirlpool Dryers
My dryer made a loud bang and wont spin
Bridgette, Most common problem is a broken belt when dryer drum dose not turn. Look through the attached links to help diagnose and repair your dryer. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Dryer Drum Not Turning
Whirlpool Dryer Drum Not Turning
Appliance Repair Forums
Duet Dryer Drum Belt part 661570 How To Replace
Jul 17, 2016 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
11076812693 drum won't turn.
Kenmore Dryer Model 110.76812693 (11076812693) Drum ...
www.repairclinic.com/.../Model-11076812693-Kenmore-Dryer-Drum-T...
Kenmore Dryer Model 110.76812693 (11076812693) Drum & Tub Parts in stock. One million parts for 125 brands. Guaranteed same-day shipping. Call 7 days ...
Kenmore Dryer Model 110.76812693 (11076812693) Motor ...
www.repairclinic.com/.../Model-11076812693-Kenmore-Dryer-Motor-...
Includes pulley for dryer drum drive belt. Other shaft has reverse threads for blower wheel. Common symptoms of a bad drive motor are: -Dryer stops turning ...
Kenmore, Whirlpool Dryer Repair - Heats properly, drum will ...
? 6:29
https://www.youtube.com/watch?v=bOShDc4kLfk
Jul 10, 2013 - Uploaded by ApplianceVideo.com
Service a Kenmore Dryer with some of the following issues: Heats but ... Kenmore, Whirlpool Dryer Repair - Heats properly,drum will not turn - 11068202794 ..... Whirlpool Kenmore Maytag Amana Dryer Won't Start - Easy Fix ...
How To Fix Dryer That Won't Tumble ' Dryer Repair
www.partselect.com/Repair/Dryer/Will-Not-Tumble/
Feb 08, 2016 | Kenmore Dryers
How do i reset the fault code FO4 on whirlpool dryer AZB 7570.i read the manual and it says i need to call service engineer
It can only be reset after fixing the issue with the unit. Have you successfully completed the repair?
Dec 28, 2014 | Whirlpool AZB 7570 White Electric Dryer...
My dryer is only making a ticking noise
one of the common reasons for that is the door latch, make sure it is not loose and or broken. post the model number for more info
Nov 24, 2017 | Whirlpool Dryers
The transmission on our 5 year old whirlpool top loading washer is not working. The machine goes through all the cycles, drains the water but the tub does not spin. It is all but impossible to contact...
Hi just read your posting.I know your machine well and the reason the machine is not spinning is the clutch ring is worn.I do not know what country you are in but $ 250 seems a bit excessive.This web site has no affiliation with Whirlpool and everyone on this website try to help people for free.I have repaired this fault many times and If you like I can help you repair your machine.Please reply with the country you are in and if you would like further help.Looking forward to your reply.
May 17, 2011 | Washing Machines
Dryer will not turn on. I have cleaned the lint trap and the vent hose and no when we set the setting and try to start the unit no success. I have light in the drum. Any suggestions? Is there a reset...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Oct 18, 2010 | Whirlpool LGB6300 Gas Dryer
Dryer is coming on for 3 mins and stops
I have a Whirlpool Duet Electric Dryer that I purchased in Jan 2009. It does the same thing. I have had 4 whirlpool service out ot repair it and none of them could. Now I am being given a hassle from Whirlpool about replacing the unit. I am reporting them to the better business bureau. If your dryer is still under warranty you can try to get them to fix it like I did. But I can't promise that you will get anywhere. I used to think that Whirlpool was the best as well...my mistake. I will never buy another Whirlpool appliance.
May 30, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Dryer makes a buzzing noise when start button pushed.
Chrysta:
Thank you for your review.
We would like to inquire further about your review with you. Please respond back to this email address, [email protected], with your name, phone number, street address, zip code, model & serial number, and date of purchase on the appliance.
We look forward to your reply.
Thank you,
Whirlpool® Social Media Relations
Mar 07, 2018 | Whirlpool Dryers
Control panel
I was able to fix our problem by running through the control panel diagnostics as outlined in the repair manual, which I found here:
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/cdce3c10dcb5382285256aa20064beaa?OpenDocument
All the diagnostic steps were successful and after I had worked through the list I was able to use the Automatic Cycles. Hope this helps!
May 27, 2008 | Whirlpool GEW9250 Electric Dryer
Whirlpool LER2614JQ Electric Dryer Logo
98 people viewed this question
Top Whirlpool Dryers Experts
Marvin
Marvin
John Tripp
John Tripp
Donni Steen
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
