Question about Frigidaire ATF6000ES Front Load Washer
My washer was spinning, it made a loud noise and the drum dropped down in front
    President:
  • 2,468 Answers
You left it go toooo long and the drum bearings in the rear area have finally given way,the "lip-seal" that keeps water out failed some time ago and now the bearing(s) also went,this may be quite a costly affair getting the old bearings out of the plastic outer drum bore,if its even savable,bearings and seal are cheap,appx $70.00 for these/the drum if damaged $500.00+/the drum spline and spider that holds the drum $150.00 /plus labor depending how bad
Posted on May 10, 2010
I have a ge frontload washer and it recently started making a really loud noise when in spin mode. It sometimes bangs the side also. What's going on?
It could be a few things that could be wrong with it. With the washer empty does the wash drum sit centered within the door? Also the drum should be level and not sag down or up. If it does, then it could mean the the springs or shocks are broken. You can check shocks by removing the two screws on the front bottom access panel. There are two shocks, and are mounted on the bottom of the the drum.
If the drum sits level and centered in the door, turn the drum by hand and feel how it spins. It should spin true and quietly without any kind of thumping or scaping noise. If it makes a thumping or scraping noise, or it wobbles as it spins this could mean the the spider arms that support the wash drum are broken. If it does not make any abrupt noise when you spin it by hand but when the machine is in a spin cycle, it spins with a loud roar like a jet plane is landing in your laundry room, then the bearings are gone.
It can be very expensive to have these machines servied since the machines needs to be taken apart to get the drum/bearing assembly. If you are handy, you can replace the bearing and seal for less than $100 in parts, but, if the spider assembly is broken, the parts alone can cost as much as a new washer.
Apr 19, 2011 | GE WSXH208A Front Load Washer
Into the spin dry cycle a loud hammering noise appears. Immediately goes away when powered off and drum speed drops. Can you please advise. Regards Geoff
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems Washer noise when spinning
heatman101
Oct 05, 2010 | Hoover H130E Front Load Washer
Loud noise in final spin
Verify that the inner drum isn't broken. Sopin by hand it should trun smoothly and staight.
Aug 30, 2009 | Frigidaire ATF6000ES Front Load Washer
My model #gltr1670aso makes loud noises during spin cycle
Usually this is due to either the drum support breaking or the back bearing being bad-neither easy to fix- or worth it. Try lifting the drum up and down, if it moves up and down they are bad. I see this a lot, and the price of repair isn't worth it. Craig
Aug 02, 2009 | Frigidaire ATF6000ES Front Load Washer
Washer is loud, and won't spin or agitate
check the motor bushes,and also check for bearings in drum you can check this by lifting the inner drum up and down if you feel a knocking noise then this will be the bearings have worn.
Jul 13, 2009 | Frigidaire ATF6000ES Front Load Washer
Loud whining noise when my washer is spinning
could be two things
1) thrust bearing
2) transmission
Jun 11, 2009 | Maytag MAV6200 Top Load Washer
Front load washer loud noise and drum loose but not dropped
Spider arms attached to stainless steel drum inside of tub have probably broken. This is a known problem with Frigidaire front loading washing machines. The stainless steel drum has a 25 year warranty but this does not include the spider arms. You cannot buy the spider arms separately, you have to buy the unit as one. The drum cost about $250.00 and probably about $300.00 in labor to install. You can do it yourself but it is pretty involved. Good Luck!
Jan 02, 2009 | Frigidaire GLTR1670A Front Load Washer
Looks like the drum has droped
You will need to get the bearings replaced. Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Sep 18, 2008 | Frigidaire ATF6000ES Front Load Washer
Loud Noise during spin cycle
drum bearings are gone,it would cost too much to repair,the drum shaft would to be repalced as well.Sorry
Dec 15, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
354 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
