Question about Ricoh Aficio CL2000N Laser Printer
Can't find my booklet
I don't know how to change the toners, color and black...
Open the Top compartment. Slide the cartridge you are changing towards the bypass tray and lift out. Put new cartridge in same slot and slide into place.
Posted on Apr 22, 2008
Change BLACK AND WHITE DEFAUT TO COLOR
You can change the font color in the document you want to print.
(This will not help if the printer refuses to print blue while the black toner is empty.)
May 12, 2014 | Dell Office Equipment & Supplies
When any color cartridge finish , you must change the whole unit Why?????
No, you must change only the toner cartridge that has finished. It would be quite a waste to replace a toner cartridge that's not empty. Here are the codes for each cartridge, to know which one you need:
-CB540A Black Toner
-CB541A Cyan Toner
-CB542A Yellow Toner
-CB543A Magenta Toner
Remember to always use genuine cartridges.
Dec 12, 2010 | HP LaserJet CM1312 All-In-One Printer
How would i know which color of toner is need to change?
The life of the toner cartridge yield depends on the amount of toner that print jobs require. The actual number may also be different depending on the print density of the pages you print on, and the number of pages may be affected by operating environment, printing interval, media type, and media size.
If you print a lot of graphics, you may need to change the cartridge.
The machine uses four colors and has a different toner cartridge for each one:
yellow (Y), magenta (M), cyan (C), and black (K).
    The status LED and the toner-related message on the display indicates which each individual toner cartridge should be replaced.
    Trust this helps. Please vote. :)
Dec 11, 2010 | Samsung CLX-3175FN Color Laser All-in-One...
All toner cart's replaced, new toner heads about 1000 pages ago, new waste tray. Printing colors ok but anything with black in it comes out blotchy or faded.
(1) If it takes developer as well as toner you will need to change the black developer.
(2) Also check the voltage is correct
(3) check that the toner path is not blocked
lets know how you get on
Feb 23, 2010 | Minolta magicolor 7300 Laser Printer
Keeps asking for black toner even after changing toner
Hello sir; on the black developer unit have senser call toner end senser that one defective have to replace it.
Apr 20, 2009 | Toshiba E-Studio 3511 Color Copier
Printer changing color of paper
Make sure the transfer belt is clean. Also check the magenta cartridge and see if it isn't leaking slightly. By all means DON"T blow it out with compressed air! You may use a toner vacuum or a soft cloth to clean out any residual toner. If that doesn't do the trick, you may have a contaminated fuser. By the way, do you get the same effect when printing black and white?
Apr 20, 2009 | HP Color LaserJet 2600n Printer
Faint repeating
I have problem with my Phaser 6130 Laser Printer, I changed toners (black, cyan, magenta yellow). My printer printing only cyan and magenta, colors black and red is very, very light. I cleaned my printer exactly. Everything is ok, but he does not has a black & magenta toners. What's happen? I don't know.
Donna
Jan 30, 2009 | Office Equipment & Supplies
Faded on left hand side
If it only happens with the black then you need to change out the black toner cartridge. The good news is isn't doesn't happen with color so it more than likely not the printer but the toner.
Jan 09, 2009 | Samsung CLP 300 Laser Printer
Color toners are empty
Press Green Tick, Right, -> System Setup -> Right, Right, -> Print Quality, Right -> Replace Supplies. Change from stop at out, to override at out. It'll let you print, and you'll get loads more out of your toner before the pages start to fade.
Dan :-)
Sep 30, 2008 | HP Color LaserJet 2600n Printer
HP Color Laserjet4550
clen your toner surface and check that not leakage.
if leckage then replaCE IT
BY
Mar 24, 2008 | HP Color LaserJet 4550 Printer
Ricoh Aficio CL2000N Laser Printer Logo
49 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
