Question about D-Link AirPlus Xtreme G DI-624 Wireless Router (DI624RE)
All of a sudden there are no lights on and I have no wireless connection. I have unplugged and replugged. Any suggestions?
    Problem Solver:
  • 10 Answers
The power adapter may be dead. they're usually 12V, 1000mA. take it to a radio-shack or other electronics store and have them test it for you. you can easily find a cheap replacement. standard-ish plug.
Posted on May 10, 2010
Testimonial: "I will try that. Thanks!"
What is error code 51030
Try going to internet settings and delete your wireless network settings then make new wireless settings. You may need to unplgug and replug in your router.
Sep 16, 2014 | Nintendo Wii Console
I will be working on the internet and suddenly the connection is dropped. It will restart when I unplug and replug in. Will run fine for a few hours and then stop again and have to unplug/replug. All...
I would call the professional and have him replace/repair it for starters. There is obviously something wrong with the hardware or the connection of your Internet Provider, ether way the install should test the connection and stand behind his installation. If you paid this guy demand, politely but firmly of course, to repair it. 2DAYS OLD, I would be livid. By the way I do the exact same thing as your professional.
Nov 09, 2012 | NetGear N300 Wireless Router
Dropping internet connection
Yes like all equipment a router can go bad. Watch the lights and try to see if it is power cycling when you loose connectivity. Some other things to look at would be: Have you moved it?New wireless device nearby (like a new cordless phone)Has someone in the area put in a garage door opener recently?The list goes on and on, however if you have not had any changes the router could be bad.
I hope this helps
Jan 27, 2012 | NetGear WGT624 Wireless Router
Their is a red light that keeps blinking on top it wont connect to my wireless
Hi i'm Basti,
Is your router connected directly to the wall or to a modem?
Unplug power cable for router and after a minute or 2 replug it back for it to re-establish the connection to the server. If you have a modem, powercycle or unplug it as well. Turn modem on first before the router.
Keep me posted.
Feb 26, 2011 | Belkin Basic Wireless Router
Liftmaster 1/2 hp professional, all functions work except for lights, i have unplugged and replugged in, bulbs are new, contacts good. Any suggestions?
Unplug the opener and remove the bulb. Using a small screwdriver pull out on the center contact in the socket. Replace the bulb and plug in the opener.
Nov 27, 2010 | Sears Craftsman LiftMaster Chamberlain...
My belkins wireless light wont come on anymore?
* try connecting ur belkin router to different power socket * try with different power adapter * or else press the reset key for more than 1 min while holding the reset unplug the router power cable and plug it back again 3 times.--- while holding the reset u shouldnt release the reset while u unplug and replug. the interval between each unplug and replug should be 15 seconds. * then release the reset then unplug the power cable and plug it back * it has to work or else replace it with the belkin tech support
Nov 15, 2009 | Belkin (F5D72304F5D7000) Router
No power light on dlink dir450 modem
unplug and replug the power cable.
try to plug it directly to electrical outlet.
if still no power light, the modem is defective.
Jul 06, 2009 | D-Link AirPlus DI-524 Wireless Router
Intermittent DSL connection
see if the filters, is coneted well, if not, exchange it.
Sergio
Nov 24, 2008 | 2wire (1000-000057-000) Modem
Router issues?
If you haven't made any changes and suddenly your wireless connection has stopped working than these are the signs that your router is offline.
Now first of all check that on your router have you got the dsl or the internet light solid if it's not solid then it could be a problem with your broadband line...check with your isp whether the signals are there on the line or not.
Now, if the signals are there then...
1) Do a complete power cycle of your router unplug all cables from your router replug them then check....
if still you are not able to open up any pages on ie...then reset your router to default settings...
in order to reset your router at the back of your router you will find a small hole that is the reset hole press the pin in that hole for 10secs that will reset your router....restart both of your comps....
Now, if you are using windows xp then
click start>control panel>in control panel click on switch to classic view>after that click on network connections>
in network connections you'll find wireless network connections....right click on wireless networks..
then click view wireless networks you'll get an option of belkin wireless network..select it and press connect....
once it says connected close all the screens and run the router installation disc that you got with your router .....you will be able to connect..
If you are on windows vista then
click start>then in start menu click connect to you'll find belkin network select it and press connect once connected run the router installation disc...
Feb 12, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
D-Link AirPlus Xtreme G DI-624 Wireless Router (DI624RE) Logo
191 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
