Question about Danby DPAC8399 Air Conditioner
E4 fault code on KF35-12-GW-E Lennox split system
  • 45 Answers
SOURCE: My Lennox HS22 series split system scroll compressor overheats
There couild be a small blockage in the refrigerant piping. This obstruction could be cyling through the system and causing the pressures to increase and decrease which is overheating the compressor. Normally when the compressor is overheating there is not enough refrigerant getting returned to the compressore to keep it cool while running. When it shuts down the the refrigerant equalizes which can return the blockage back to the coil or just simply dislodge it frome where it is hung up. When the compressor returns to its running temp, it turns back on and can cycle that blockage through the refrigerant piping which sometimes it may go thru and sometimes gets hung up and clog the system again. I would have a certified technician come over and hook their manifold to the system which can easily tell them if there is a blockage or he can trace the problem. Do you know what type of metering device is in the coil inside?
Posted on Jun 06, 2010
Testimonial: "Thanks Terry I did refrigeration for over ten years but got out of it 15 years ago...It took a while for my brain cells to click.I didn't think about the blockage which still may be a possibility. My pressures were a little low for my ambient temp so I added some freon now I have a good sweat back to the compressor and it has been working good for the last 3 hrs...the temps outside are supposed to hit the hi 90's and I will keep an eye on my head pressure.it is a split system and I'm getting some sweating at my txv..that is were the restriction usually happens.I used to get a lot of cap tube restrictions in small systems.thanks for the help."
hvac1960
  • 2133 Answers
SOURCE: Yonan Split Air Conditioning System
F6
ambient temp.
sensor of outdoor
fault
1?Check whether the resistance of sensor is normal,
otherwise replace it.
2?Check whether the sensor wire is short circuit or open
circuit, and whether the plug is well contacted, whether
there is welding off or rosin joint on the electric control
board, repair it if there is any above.
3?When the 1 and 2 are both normal, then the components
or integrated circuit is damaged, the electric control
board should be replaced.
Posted on Dec 02, 2010
hvac1960
  • 2133 Answers
SOURCE: I have a daikin split
Short of gas. Leak test and arrest it. Vacum and do gas charging
Posted on Jan 01, 2011
guru_fixya
  • 944 Answers
SOURCE: The Wall unit to my
hi,
If the unit displays Error E4
1)Check whether the winding resistance and
operation current of the compressor are normal.
2)Check whether the high and low pressure is normal
when the unit is running.
3)Check (whether the coil pipe sensor is normal)
whether the contact of the inserted on the circuit
board is well, the coil pipe temperature sensor is
fixed, the evaporation of the indoor unit is well,
the key is to check the evaporator temperature
detected by the coil pipe temperature sensor has
reached the cooling or heating temperature.
4)Check whether the surface of the condenser is too
dirty, it should be cleaned when it is too dirty.
5)Check whether the capacitance of the outdoor motor
and the fan is damaged, it should be replaced when
it is damaged.
6)If the above items are normal, the electric control
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Jan 11, 2011
melvinperezl
SOURCE: I have a house in the carribean with three Lennox
Use the same codes as York air conditioners. Done!
Posted on Oct 08, 2015
I have a waves airconditioner. Its not cooling well n after some time show e4 error. How to remove the error? Plz help.
http://acerrorcode.com/tcl-air-conditioner-error-codes.html
This was googled: waves error codes
It showed a page in "images". Stated
"System abnormity" I think. Page was blurry.
Call a tech! Mini splits can be a troubleshooting nightmare! I think its a Fujitsu unit. It would help, and may save you some $$, to call around to find a technician who has worked on mini splits. And maybe find them a 1-800 # that is their tech support # before hand, so if the tech needs it, you have it. E4 is a vague description for a fault. Make sure you have cleaned air filters, cleaned o.d.coil (turn off power at breaker 1st). Changed batteries in remote. Work safe!
Jun 20, 2015 | Heating & Cooling
1 ton ac works for 5min and display E4
e4 error code comes for defrost. just remove the cover of your split ac, you shell found a sensor there , check for rat cut.
Oct 12, 2013 | LG LS-L1210CL Mini Split Air Conditioner
What is E4 error code o. Yonan airconditioner?
My yo nan midwall split aircon is displaying an E8 error code. What is the fault?
Aug 12, 2013 | Heating & Cooling
Lennox codes
e5: open or short circut of outdoor yemp. sensor or outdoor unit.
see more Air Conditioning Fault Codes
May 11, 2013 | Lennox 7 Series MS7-HO-09P MS7-HI-09P Heat...
Lennox 8 series ms8-z0-2ap3a error code H1, defrost operation
h1: defrosting /normal operation/ normal defrost operation.
see more: Air Conditioning Fault Codes
Jan 16, 2013 | Lennox Heating & Cooling
My sairon split system ac unit does nothing and comes up with e3 on the display
if split ac display shows e3 what is the solution for that problem
Dec 10, 2010 | Heating & Cooling
We were getting an E4 but now we get an E2 but
I do know that the owners manual should show you what each and every code means? Some times the manufacture will paste a strip located on the panel of the indoor unit showing what each code means. If not, I would contact the factory on this. I know on Bryant, Mitsubishi splits, Day and night, (Bryants), Tranes, Lennox and most all others, do show in the manual and on the unit behind the panel. Try looking for them there.
Sincerely, shastalaker7
Oct 19, 2009 | LG LS-L1210CL Mini Split Air Conditioner
Ramsond split AC 12000
HI YOUR BROBLEM I THINK IS THE SENSOR FOR THE ROOM TEMP
Sep 02, 2008 | GE Quiet-Aire Ductless Split System Air...
Danby DPAC8399 Air Conditioner Logo
929 people viewed this question
Top Danby Heating & Cooling Experts
Dan Webster
Dan Webster
Dennis Boxerman
mintvl
Level 1 Expert
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
