Question about Apple Mac OS X 10.4
System Preferences Preferences Error: You cannot open Desktop & Screen Saver preferences pane on this computer. Contact the developer of this software for a newer version. on macknook
  • spacemonk985 May 11, 2010
    checked updated even before receiving your suggestion and checked now ... last update 04/30/10.
    the only available ones now are for safari (which i don't use) and iTunes update, which is not
    necessary. these two updates cannot be hidden or made inactive on this computer.
    also updated disk utility ... normally this fixes any glitches ... still unable to open desktop-screen
    saver ... where do we go from here?
  • spacemonk985 May 12, 2010
    so far none of the solutions helped ... have gone through everything ... checked out likes from
    solution#2 .. none of thos downloads are acceptable on this computer ... this is really
    weird ...
  • 560 Answers
Hi. Corrupted wallpaper file (.jpg) can cause the desktop pane crash. Please try this:
1. create a new folder on your desktop
2. cut all pictures in /Library/Desktop Pictures and paste it in the newly created folder (this is just for testing purposes only and you can move it back to its original location)
3. open desktop and screen saver pane.
lf you don't get the error, cut and paste the wallpaper pictures one by one and see which picture gives you the error.
If you still get the same error, let me know and will think of other possible solution.
Thanks for using FixYa.
Posted on May 13, 2010
  • 23 more comments
  • spacemonk985 May 13, 2010
    do not have a library/desktop pics folder (searched computer just in case)
    am not using screensaver ... only pick one picture at a time as desktop wallpaper
    if you can find something else, that would be great ....
    research here tells me that this is an "old bug" and has been reported to apple (don't know when)
    just wondering ... if this is an old bug, why it showed up on my computer all of a sudden ...
  • Liza Halbrook
    Liza Halbrook May 15, 2010
    Please post the logs so i can look what is causing the crash. Open Desktop & Screen Saver preferences pane and after the crash, open the logs, copy and paste it here or send it to my email (blkc4us@yahoo.com). Logs are located at /Library/Logs/
    Thank you.
  • spacemonk985 May 16, 2010
    May 15, 2010-
    Please post the logs so i can look what is causing the crash.i know my way around this computer .... cannot find any logs ...
    when i open the desktop & screen saver preference pane, all i get is the same message i originally
    posted for assistance ... there are no logs to open, copy and paste here to you ... searched everywhere for "library/logs" .... came up with nothing ... which leads me to a question ... does apple mac OS X 10.4 work the same way on a macbook as it does on a regular computer? ... you do know
    that i'm on macbook ...
  • Liza Halbrook
    Liza Halbrook May 16, 2010
    Yes, I know you are using Macbook with OSX 10.4. The locations I am giving you are standard and I don't understand why you can't find them. Please verify that you have the Library folder. If you don't have that folder, that may be the reason why your Desktop & Screen Saver preferences pane is crashing because it is looking for a folder that doesn't exist anymore.
    Please let me know if you have or don't have the "Library" folder so I can think of other solutions.
    Thank you.
    when you first told me to look for "library/logs" ... that's all i searched ... yes, do have the 'library'
    folder .... and it has logs ... in the 'crash logs' this is what is there (the only folder which has anything to do with this problem) don't know if this is what you're looking for ... knowing my way
    around does not include this techie stuff!
    Mac OS X Version 10.4.11 (Build 8S2167)
    2010-05-12 03:53:58 -0500
    2010-05-12 03:54:04.594 SystemUIServer[271] lang is:en
    2010-05-12 03:57:44.698 System Preferences[316] [NSPrefPaneBundle instantiatePrefPaneObject] (/System/Library/PreferencePanes/DesktopScreenEffectsPref.prefPane): principalClass is nil.
    Debugger() was called!
    2010-05-12 04:04:03.543 System Preferences[324] [NSPrefPaneBundle instantiatePrefPaneObject] (/System/Library/PreferencePanes/DesktopScreenEffectsPref.prefPane): principalClass is nil.
    2010-05-12 04:08:19.145 System Preferences[327] [NSPrefPaneBundle instantiatePrefPaneObject] (/System/Library/PreferencePanes/DesktopScreenEffectsPref.prefPane): principalClass is nil.
    2010-05-12 13:57:37.106 System Preferences[383] [NSPrefPaneBundle instantiatePrefPaneObject] (/System/Library/PreferencePanes/DesktopScreenEffectsPref.prefPane): principalClass is nil.
    2010-05-12 13:59:45.479 System Preferences[386] [NSPrefPaneBundle instantiatePrefPaneObject] (/System/Library/PreferencePanes/DesktopScreenEffectsPref.prefPane): principalClass is nil.
    2010-05-12 16:27:47.832 System Preferences[459] [NSPrefPaneBundle instantiatePrefPaneObject] (/System/Library/PreferencePanes/DesktopScreenEffectsPref.prefPane): principalClass is nil.
    2010-05-12 16:28:51.063 System Preferences[462] [NSPrefPaneBundle instantiatePrefPaneObject] (/System/Library/PreferencePanes/DesktopScreenEffectsPref.prefPane): principalClass is nil.
    May 12 18:16:57 christine-hoods-computer mDNSResponder: Repeated transitions for interface en1 (FE80:0000:0000:0000:021B:63FF:FE09:889A); delaying packets by 5 seconds
    [00000001] main libvlc debug: VLC media player - version 0.9.10 Grishenko - (c) 1996-2009 the VideoLAN team
    [00000001] main libvlc debug: libvlc was configured with ../configure '--enable-release' '--with-macosx-sdk=/Developer/SDKs/MacOSX10.4u.sdk'
    [00000001] main libvlc debug: translation test: code is "C"
    [00000001] main libvlc: Running vlc with the default interface. Use 'cvlc' to use vlc without interface.
    [00000001] main libvlc: Key authenticated
    [00000001] main libvlc: Status file authenticated
    VLC(498,0xa000d000) malloc: *** error for object 0x137ca28: Non-aligned pointer being freed
    VLC(498,0xa000d000) malloc: *** set a breakpoint in szone_error to debug
    VLC(498,0xa000d000) malloc: *** error for object 0x137c820: Non-aligned pointer being freed (2)
    VLC(498,0xa000d000) malloc: *** error for object 0x137e080: Non-aligned pointer being freed (2)
    VLC(498,0xa000d000) malloc: *** error for object 0x1382db0: Non-aligned pointer being freed (2)
    VLC(498,0xa000d000) malloc: *** error for object 0x137e490: Non-aligned pointer being freed (2)
    VLC(498,0xa000d000) malloc: *** error for object 0x137c618: Non-aligned pointer being freed
    VLC(498,0xa000d000) malloc: *** error for object 0x137f4d0: Non-aligned pointer being freed (2)
    VLC(498,0xa000d000) malloc: *** error for object 0x137f0c0: Non-aligned pointer being freed (2)
    VLC(498,0xa000d000) malloc: *** error for object 0x1382388: Non-aligned pointer being freed
    VLC(498,0xa000d000) malloc: *** error for object 0x1382ba8: Non-aligned pointer being freed
    VLC(498,0xa000d000) malloc: *** error for object 0x1381d70: Non-aligned pointer being freed (2)
    VLC(498,0xa000d000) malloc: *** error for object 0x137d658: Non-aligned pointer being freed
    2010-05-13 01:10:02.067 System Preferences[504] [NSPrefPaneBundle instantiatePrefPaneObject] (/System/Library/PreferencePanes/DesktopScreenEffectsPref.prefPane): principalClass is nil.
    May 13 01:40:47 christine-hoods-computer ntpd[156]: sendto(17.151.16.23): Can't assign requested address
    Record Info Table 2: 1073472010-05-13 03:08:10.306 iLikeAgent[519] iLikeAgent launched
    2010-05-13 03:08:10.310 iLikeAgent[519] Agent checking for updates:http://www.ilike.com
    2010-05-13 03:08:10.673 iLikeAgent[519] update result: ok
    2010-05-13 03:08:10.673 iLikeAgent[519] version OK
    2010-05-13 03:08:10.673 iLikeAgent[519] iLikeAgent terminated
    May 13 03:57:18 christine-hoods-computer ntpd[156]: sendto(17.151.16.23): Can't assign requested address
    May 13 17:17:52 christine-hoods-computer mDNSResponder: Repeated transitions for interface en1 (FE80:0000:0000:0000:021B:63FF:FE09:889A); delaying packets by 5 seconds
    May 13 17:21:07 christine-hoods-computer mDNSResponder: Repeated transitions for interface en1 (FE80:0000:0000:0000:021B:63FF:FE09:889A); delaying packets by 5 seconds
    May 13 17:41:01 christine-hoods-computer ntpd[156]: sendto(17.151.16.23): Can't assign requested address
    2010-05-14 01:12:16.542 iLikeAgent[693] iLikeAgent launched
    2010-05-14 01:12:16.546 iLikeAgent[693] Agent checking for updates:http://www.ilike.com
    2010-05-14 01:12:16.862 iLikeAgent[693] update result: ok
    2010-05-14 01:12:16.862 iLikeAgent[693] version OK
    2010-05-14 01:12:16.862 iLikeAgent[693] iLikeAgent terminated
    2010-05-14 03:09:07.262 Preview[391] *** Assertion failure in -[PVThumbnailOutlineView expandItem:expandChildren:], TableView.subproj/NSOutlineView.m:709
    2010-05-14 03:09:07.262 Preview[391] Exception raised during posting of notification. Ignored. exception: Invalid parameter not satisfying: item
    2010-05-15 00:25:40.618 iLikeAgent[792] iLikeAgent launched
    2010-05-15 00:25:40.622 iLikeAgent[792] Agent checking for updates:http://www.ilike.com
    2010-05-15 00:25:40.937 iLikeAgent[792] update result: ok
    2010-05-15 00:25:40.937 iLikeAgent[792] version OK
    2010-05-15 00:25:40.937 iLikeAgent[792] iLikeAgent terminated
    terminate called after throwing an instance of 'std::logic_error'
    what(): basic_string::_S_construct NULL not valid
    firefox-bin(796,0xa000d000) malloc: *** error for object 0x1ca0d450: incorrect checksum for freed object - object was probably modified after being freed, break at szone_error to debug
    firefox-bin(796,0xa000d000) malloc: *** set a breakpoint in szone_error to debug
    2010-05-15 17:11:51.782 firefox-bin[840] GrP not requesting _registerDragTypes because the window is dying already
    2010-05-15 17:11:51.783 firefox-bin[840] GrP not requesting _registerDragTypes because the window is dying already
    2010-05-15 17:11:51.784 firefox-bin[840] GrP not requesting _registerDragTypes because the window is dying already
    2010-05-15 23:28:55.293 System Preferences[996] [NSPrefPaneBundle instantiatePrefPaneObject] (/System/Library/PreferencePanes/DesktopScreenEffectsPref.prefPane): principalClass is nil.
    2010-05-15 23:38:24.896 iLikeAgent[1002] iLikeAgent launched
    2010-05-15 23:38:24.900 iLikeAgent[1002] Agent checking for updates:http://www.ilike.com
    2010-05-15 23:38:25.234 iLikeAgent[1002] update result: ok
    2010-05-15 23:38:25.234 iLikeAgent[1002] version OK
    2010-05-15 23:38:25.234 iLikeAgent[1002] iLikeAgent terminated
    2010-05-15 23:46:22.650 System Preferences[1007] [NSPrefPaneBundle instantiatePrefPaneObject] (/System/Library/PreferencePanes/DesktopScreenEffectsPref.prefPane): principalClass is nil.
  • Liza Halbrook
    yes, this is the error logs. please open desktop and screensaver pref pane and wait for it to crash then open logs, look for the dates, copy and paste all logs generated recently. thanks.
    here's the latest:
    2010-05-16 16:45:39.177 System Preferences[1067] [NSPrefPaneBundle instantiatePrefPaneObject] (/System/Library/PreferencePanes/DesktopScreenEffectsPref.prefPane): principalClass is nil.
  • Liza Halbrook
    Liza Halbrook May 17, 2010
    The screensaver effects is causing the crash. It is either corrupted or accidentally deleted.
    Make a folder in your desktop, cut "DesktopScreenEffectsPref.prefPane" from "/System/Library/PreferencePanes" and paste it to the folder you just created. If you can't find the file, it is probably deleted.
    Manually copy "DesktopScreenEffectsPref.prefPane" from either a time machine backup before the crash or from distribution disk image to "/System/Library/PreferencePanes".
    If you have a time machine backup, you could restore "DesktopScreenEffectsPref.prefPane" from there. Otherwise, you can download an application named Pacifist which will allow you to extract "DesktopScreenEffectsPref.prefPane" from your install DVD.
    You can download it here:
    http://www.charlessoft.com/
  • spacemonk985 May 17, 2010
    wow .. you've taken me to places i didn't know existed ... it's an adventure i'd rather not take again!
    made folder on desktop ... the "desktopscreeneffectspref.prefpane' was actually there!
    cut it and placed into desktop folder ....
    don't have backup on this computer ... don't know what you mean by "manually copy from
    distribution disk image? ... what is a distribution disk image? cd which came with computer/
    since i'm not clear, i'm thinking there's no point in getting the 'charessoft' download
    you are definitely more patient then i am ...!
  • Liza Halbrook
    yes, I am patient and determined to help you :)
    distribution disk is the DVD installer of you Mac OSX
    i did download the charles software ... however, seems we have an additional issue ...
    in seaching for 'dvd installer', all i have it "idvd.pkg" ... it goes to "you have chosen to install the
    software on the volume" (does not give me other choices) ... goes to "upgrade" ... after upgrade
    message reads "these are errors installing the software - please try again" ... did this 3x ...
  • Liza Halbrook
    Liza Halbrook May 18, 2010
    Hi. I installed Mac OSX 10.4 and here is a copy of the file you needed. Please download and save it to /System/Library/PreferencePanes
    http://cid-6b0f782e0155345c.skydrive.liv...
  • Liza Halbrook
    Sorry. Typo error on previous link. Here is the correct one:
  • spacemonk985 May 18, 2010
    downloaded the 'desktopscreeneffects' link ... put it in system preferences folder ... checked and it's sitting there ... when i click on it it opens the system preferences window, but the icon does not show up, therefore desktop pic cannot be changed ... every time it feels like we're getting closer, something
    else doesn't work .... grrrrrr! :)
  • Liza Halbrook
    Download and unzip this file. This include other files on desktop and screensaver pref pane. just get the ones you needed like when your desktop icon is missing, copy the icon and paste it over your old file to get rid of the corrupted ones.
    a colorful desktop/screensaver icon now resides in the preferences folder ... obviously it does not
    like sitting there and reads: "preferences error ... could not load desktop & screen saver preference
    pane" ...
    can you hear me screaming????
  • Liza Halbrook
    i think i can read you screaming..... what files did you replaced?
    replaced/pasted over the old desktop/screensaver which was set aside in its own folder .... now even that old icon is gone!
    i'm done screaming ... now i think i'll just cry :(
  • Liza Halbrook
    did you replaced the whole folder ?!?!?!? or just the icon file?
    the icon was in an unmarked folder ... i didn't name it anything ... so, when i replaced the icon there was not need for an empty folder ....
  • Liza Halbrook
    Liza Halbrook May 19, 2010
    Is it ok if I connect to your computer via logmein? It is safe and secure and you can watch what I'm doing on your Mac.
  • spacemonk985 May 19, 2010
    have at it ... be my guest! :)
  • spacemonk985 May 21, 2010
    HEY .... did you get lost in cyberspace?
  • Liza Halbrook
    Liza Halbrook May 22, 2010
    Hi. I need your email address so I can send the login details so you can install logmein client on your computer. Drop me a message on my yahoo messenger. My ID is blkc4us. Thanks.
  • spacemonk985 May 22, 2010
    oh my ... we're really getting personal here! :)
    haven't used messenger in years ... here's my email address: spacemonkey7us@yahoo.com
    ps ... what state are you in? just curious ...
    Genius:
  • 1,354 Answers
Hi
go to folowing link you will get all anssers for your mac
http://www.apple.com/support/macosxtigerserver/usermanagement/
Posted on May 11, 2010
  • 1 more comment
  • http://support.apple.com/kb/HT1554
    rafer above link i hope u will get your anser
    the user management link was useless ... i tried all of them and downloads were unacceptable
    the apple support link deals with transferring files .... duh?
    your post deals with the same 2 solutions you gave me in your last one ... how about some new ones?
  • 493 Answers
You should update your OS of Mac-book by clicking this link.
Then you can install and update the Quicktime X Preferences software.
Hope this helps.
Posted on May 10, 2010
  • 2 more comments
  • Ibrahim OKTAY
    Ibrahim OKTAY May 11, 2010
    Hi again,
    - If you copied the JPEG files/default pictures (which you used in your screen saver) to Library/Desktop folder, it may cause problem.
    Try to move and open them from their orijinal places, (open SysPrefs, go to Desktop and Screen Savers Pane.). Try on the Desktop and Screen Savers tabs.
    Hope this helps.
  • Ibrahim OKTAY
    Ibrahim OKTAY May 12, 2010
    Would you please read this article. It is not similar to your problem but it may give some clues to solve your problem with Mac OS.
    You are right. This problem looks like a weird. But trying to solve :)
    Good luck.
    ioktay
  • Ibrahim OKTAY
    Ibrahim OKTAY May 18, 2010
    Hi Spacemonk,
    Did you check my previous link?
    Is your problem solved or not? Hope you solved your problem.
    Best wishes.
  • Ibrahim OKTAY
    Ibrahim OKTAY May 22, 2010
    Hi Spacemonk,
    I couln't get any response from you. I assumed that you solved your problem.
    If you read this comment, would you please give feedback?
    Thank you very much.
How do you get Windows 10 free update from Windows 8 to operate the screen saver?
How to customize Screensaver in Windows 10
RECOMMENDED: Click here to fix Windows errors and optimize system performance
There were times when computer monitors used to suffer from image burn-in issues caused by showing the same image for a long period of time and people used to install a screen saver to avoid the issue. The computer screens today no longer face the burn-in issues, but people still use the screen saver on their computer systems for fun's sake. Windows 10 comes with a six built-in screensavers. Let us see how you can customize screensavers in Windows 10.
Read: Are Screensavers necessary and still needed.
Screensaver Settings in Windows 10 You can get to your screen saver settings directly by typing 'Screen Saver' in the taskbar search box in the lower left corner of your system. Click on 'Change Screen Saver' and it will take you the Screen Saver settings right away where you can adjust the settings according to your own preferences.
Alternatively, right-click on your Windows 10 desktop, and select Personalize to open Personalization settings. Next click on Lock screen in the left pane.
Scroll down the Lock Screen settings and click on Screen Saver Settings. The following window will open. Here you can adjust the settings according to your preferences.
By default, Windows 10 offers the following six screensavers - 3D Text, Blank, Bubbles, Mystify, Photos and Ribbons - nothing new here. Select the screensaver from the drop-down menu and change its defaults Settings, if any are available.
For instance, the 3D Text screensaver lets you customize the text as well as a few other options.
The Photos screensaver lets you display your favorite photos as a screen saver.
Once you are done, click on save and exit.
Create Screen Saver Settings Shortcut
If you access the screensaver settings frequently, you can create its desktop shortcut as follows: However, it is easy to change the settings but if you change your screen saver often, it would be better to create a Screen Saver Settings shortcut on your desktop.
To create the shortcut, you have to right-click on your desktop and click on New > Shortcut.
Type control desk.cpl,,@screensaver in the location space in the wizard.
Click Next and give a name to your shortcut. Click Next and you are done. Give it a suitable icon of your choice.
Use this shortcut to change or adjust your screen saver settings whenever you want, quickly.
You can also create a shortcut to launch or change Screensaver state for a specific screensaver.
Nov 29, 2015 | Microsoft CompuRegister POS-1000 POS...
Tip
Black and white or negative screen resolution in Mac OS X
A black and white display, or negative screen resolution, is an issue which can occur within the various Mac OS X system versions ranging from Mac OS X 10.3 to Mac OS X 10.6.
It can appear as an anomaly which can leave a Mac User dumbfounded, not sure what is going on.
At one time your screen is normal like this, but then somehow,
the screen changes into this strange negative, inverted screen.
So how does this occur?
The answer is more simple than you think.
An inverted screen like the one you see in the screen shot above, is not actually an anomaly, or the result of some sudden strange happenstance. What's more, chances are, this occurred because of what you did.
Its an easy fix however, because the only way your Mac OS X desktop screen can turn into a negative or black and white resolution, from its normal color resolution, is if a setting within your Mac OS X system has been modified.
To return your screen back to the normal color resolution, follow these steps:
* Click on the Apple menu icon, located on the upper left corner of your Mac OS X desktop screen.
* From the drop down menu, select System Preferences.
* Within System Preferences, select the pane (in System Preferences, Apple references all icons as "panes") entitled "Universal Access".
Quick Note About Universal Access:
The reason this System Preferences pane is known as"Universal Access", is due to the purposes Apple designed it for. If you notice the image for this pane above, this symbol for this feature, is similar to a placard or sign you would see on a car license plate, parking space, door or building, for an individual who has a disability or is handicapped.
Universal Access was designed to enhance features like Voice-over speech (your Mac talks to you), screen size, display settings, keyboard and mouse settings for those Mac users who are vision impaired, hearing impaired and /or physically disabled.
* For the next steps in the process:
Click on the Universal Access pane.
If you look in the screen shot, under Display, you will see that the current setting is "White on Black".
Click on the radio button entitled "Black on White"
and this is the window you will see:
Back to normal!
That is all it takes, to return your desktop screen resolution back to normal.
This is why you were suggested as the probable cause" for your desktop screen to go into Inverted mode. Chances are you may have been in System Preferences, clicked on the Universal Access pane, and in exploring settings, may have clicked the Display setting and the
White on Black radio button, causing the screen to go into
the inverted mode or change in gray scale.
Another theory could be that you may have accidentally pressed the Ctrl-Alt-Apple Command keys on your keyboard, combined with either < > keys, depending on if you were in process of' increasing or decreasing contrast on your Mac's screen or display.
The true purpose of the inverted screen mode or change in gray scale, is to aid Mac Users who may be sensitive to the bright normal colors, that you and I see on the standard Mac OS X display screen, due to poor or failing vision.
So now that your screen is back to normal, if you should see an inverted display, or screen that resembles a negative resolution, like that of a photo negative, you know how to correct this issue.
For more information on Universal Access, click here.
Regards,
- Mactechtrainer
on Feb 08, 2010 | Computers & Internet
How do i change my screensaver design to dictionary word of the day?
Hi Kyle,
Here is how to change the screensaver to Word of the Day.
Click on the Apple icon at the very top right of your screen and select System Preferences. The System Preferences window will open and you will see rows of icons. Click on the Desktop & Screen Saver icon. In the next screen, click on the Screen Saver tab. Now you will see a list of different type of screen savers. Scroll down to the bottom and select Word of the Day. Close the System Preferences windows and now your screen saver should be set to Word of the Day.
Hope that helps!
Thank you,
Mark Salvo
SalvoTech Support
503.383.9175
http://www.salvotechsupport.com/
Mar 21, 2015 | Apple MacBook Air
Grey side bar on desk top screen
The picture or image you have chosen does not fit the screen. Go to your system preferences, Desktop &Screen Saver, click on the desktop tab and change the image to "fit the screen" or a variety of other options.
Nov 09, 2013 | Apple Computers & Internet
How to remove desktop picture on emac a1002 computer
Go to system preferences and then to desktop and screen saver and from here you can select the picture and then at the bottom of the left hand column you click on the minus sign and this will remove the picture. Hope this helps.
May 26, 2012 | Apple eMac Desktop
My macbook screen keeps going off but the macbook is still running it occurs
The screen sleep is set for a different period than the hard disk sleep. This can be changed in the Energy Saver Preference Pane.
1. Launch System Preferences
2. Select Energy Saver (its icon is a CFL bulb)
3. Select Battery or Power Adapter settings. The upper slide allows you to set the elapsed time until your computer sleeps, while the lower slide allows you to adjust the elapsed time for the display to sleep. There are several chackboxes to further refine when your computer or its display sleeps to save power.
Dec 21, 2010 | Apple MacBook 13"White /2.0Ghz Intel Core2...
I have a similar problem but am using an Apple Mac
Top of the screen menu to the left of the mac bar. System Preferences is the option. Once in there click energy saver.
Jul 25, 2009 | Polyview V17E 17" LCD Flat Panel Monitor
Why my MAC G5 turn off when the sleep mode is on
You may have your energy settings set to turn off the Mac after a specific time of inactivity. The power on / off option is in the Schedule button in the Energy Saver pane in system preferences under the Apple menu.
Jun 06, 2009 | Apple iMac G5 Desktop
Computer turns off unless constantly using... even put to sleep, it turns off instead.
Hi, Sorry you are having problems,
Sounds to me like either your energy saving preference pane is set WAY too short or it is corrupt.
Go to your system preferences and select (Energy Saver) and be sure it is set to never sleep and set the idle time to screen sleep time to about 30 minutes and be sure the button ( Shutdown instead of sleep ) is not selected... if you have that button.
Try these, then do a restart to be sure they take.
If you still have the same problem, then, your settings are corrupt, you will need to delete it:
go into your hard drive, into your user folder, into the library folder into the preferences folder and find this file:
com.apple.systempreferences.plist
put it in the trash, empty trash, restart the computer the reset your energy saver settings and you should be OK!
Mar 10, 2009 | Apple iMac G5 Desktop
Screen switches from application back to desktop
Open your System Preferences. Go to Dashboard & Expose. This is a very helpful application in my world. Whenever you want to see all the windows, hide windows, start screen saver, you just push your mouse into the appropriate corner. Sounds like you have a corner set and when you hit it, you trip the effect. Change the corner and check them out, Handy to use when you have multiple windows open. Experiment and see.
Jan 05, 2009 | Apple Power Mac G5 Desktop
Apple Mac OS X 10.4 Logo
825 people viewed this question
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
Martin Buck
Martin Buck
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
