Question about Dryers
How do you light gas dryer? - Dryers
  • Dryers Master
  • 43,501 Answers
Hi, If you have a gas dryerhow do you light gas dryer? - 2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer is electric..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on May 11, 2010
Gas dryer burner intermittently lights. Foul gas
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 17, 2010 | Estate TGDS680EQ Dryer
I NEED TO KNOW HOW TO LIGHT THE PILOT TO MY GAS DRYER
Hi, Most dryers today use a hot surface ignitor to light them...yours probably went bad... If you have a gas dryer2_bing.gif.
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
If your dryer2_bing.gif is electric2_bing.gif..
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
heatman101
Aug 11, 2010 | Maytag Atlantis MDG8600AW Gas Dryer
My dryer only lights the first time.
Hi, If you have a gas dryer2_bing.gif.
heatman101
Jul 05, 2010 | GE DVLR223 Dryers
Dryer will not get hot
Tromm LG DLG5988 gas dryer
Heater not turning on Gas light on Cooling light on at the same time Heat Sensor light on
I checked gas it is on and flowing through the pipe up to the dryer
Can't find igniter, reset switch or fuses on the dryer
Jun 01, 2010 | LG DLG5932W Gas Dryer
Gas dryer wont light
heatman101
May 31, 2010 | Maytag Neptune MDG5500AW Gas Dryer
How to light it it is not hot does it have a
Gas Dryer not Working Gas Dryer Not Heating
If your dryer is electric2_bing.gif..
Dryer Troubleshooting2_bing.gif Electric Dryer won t Heat
heatman101
May 05, 2010 | Kenmore 73952 Gas Dryer
Old maytag gas dryer. Does not heat anymore, gas
Maytag dryer series 05. How do I light the pilot?
Apr 04, 2010 | Maytag Dryers
Hooking up my dryer
There is no pilot light on your dryer it sounds like you have a gas leak somewhere. Get a cup put alot of dish soap in it and a little bit of water and apply it to your fittings in the back. If you have a gas leak it will bubble up. If this is a used dryer you may have a damaged gas valve or another internal leak.
Jan 22, 2010 | Estate TGDS840JQ Gas Dryer
Hot water heater went out when they replaced our dryer doesn't
Make sure the gas valve at the dryer is turned on. Dryers use a glow plug or electronic ignitor to light the gas. There is no pilot light. Plug the dryer in and start it. Look inside the front lower panel to see if the ignitor glows. If it does and the gas does not light then the gas to the dryer is probably turned off. Look for a valve in the supply line to the dryer. Also inside near the front underneath.
Aug 05, 2009 | Dryers
Pilot light
Pilot Light? Are you sure? All the gas dryers I've ever worked on were pilot-less. There should be a glow-type ignitor that heats up when the dryer is turned on. When it reaches a certain current potential a gas valve is opened and the burner ignites. How old is this dryer? Maybe this is something I've never seen before.
Jun 05, 2007 | Kenmore 72802 Gas Dryer
Dryers Logo
Top Dryers Experts
