I have a 16yr. old Goodman unit and I want to replace the capacitors, but they are rusted and I can't read the values on them. How can I determine the values of them so that I can buy replacements?
  • Brian Niten May 11, 2010
    Can you read the model # and serial # on the compressor and fan motor?
    Guru:
  • 588 Answers
A lot of parts stores can cross reference them, if you have the compressor model number and the motor model number. If you don't have the model numbers, I assuming the capacitors are still good you might call your parts store and they might check them for you, if you take them in, with a capacitor analizer.
Make sure before you disconnect any wires that the disconnect is removed and that there is no voltage or power to the unit, and mark every wire and draw a picture of where it goes, so, when you put the new capacitors in you know how to wire it.
If they give you a dual capacitor ( it has 3 terminals and it's for both, the compressor and fan, in one capacitor) have them show you how to wire it or let me know and I can help you.
Posted on May 11, 2010
What capacitor part is for goodman manuf. A.C. modelCk18/1B s/n **********7
Value should be printed on side of capacitor expressed in microfarads. The symbol is a uf. The u has a long tail on it. That is how you pick up a replacement.
Aug 15, 2016 | Goodman Heating & Cooling
10 year old Goodman central AC won't come on after mini power outage. Breakers and wall thermostat OK.
Check the start capacitor for proper value and replace if necessary.
Ditto for thermostat. There are also some fuses in the air handler that might need replacement.
You may have had a power surge that had a bad effect on electronics of unit. Make sure that unit is receiving power for one thing. U might try to reset the electronics by completely shutting off all the breakers to compressor and air handler and waiting a few minutes and then reconnecting.
Sep 02, 2015 | Goodman Heating & Cooling
Goodman ac/heater drain pan leaking since instillation 3 years
sounds like the unit needs to be elevated and leveled.
Aug 10, 2012 | Goodman Heating & Cooling
I have a Goodman Model CPLE24-1A, Serial # 0207416067. First, can you tell me how old the unit is? Next the fan comes on in the outside unit and it sounds like the compresser trys to start but cant no
Hello, based on your serial number It looks like the unit was built in Feb of 07. If the compressor is trying to start you may either have a bad capacitor or one of the windings in the compressor is open. Start by replacing the capacitor as it is inexpensive, if it does not work than looks like your compressor will need to be replaced.
Jun 04, 2012 | Goodman CKL24AR24 Air Conditioner
I have a Goodman 4 ton unit that is 7 years old.The capacitor went out. Now the unit cools great until it cycles out. The compressor will not restart until it cools down for a couple of hours. Is there...
Just replace the capacitor...with the same size or even one that is a slightly higher MFD rating...you can go up to 10% higher with no problems...
heatman101
Aug 05, 2011 | Goodman CKL36AR36 Air Conditioner
Goodman ck36 1b a/c. Capacitor replaced 2 years ago. Unit is 13 years old and thermostat is Honeywell, also 13 years old. This summer there seems to be a 3-5 min delay (from when thermostat registers call)...
If you have a AC unit with electric or gas its doing what its supposed to do, let the pressures in the system equilize before starting again, If you have a heat pump its doing it there as well you just have not noticed. Anti cycling is a good thing, 4 to 5 minutes is normal.
Jul 05, 2011 | Goodman Heating & Cooling
Run Capacitor is bad... what is the correct replacement number for model cple30-1c? Thanks
Look at the old capacitor. The rating should be printed on it. You just need to get one with the same microfarad rating. If you can't read it take the model # with you to heating and air supply that sells Goodman units and they should be able to help you.
Sep 01, 2010 | Goodman CKL42AR42 Air Conditioner
Blower motor doesn't start with capacitor installed!
you need a meter that will measure uf (micro farads) it should read within about 10% of the rating 12.5uf otherwise you could charge it with an insulation tester (megger) and short the terminals with an INSULATED screwdriver to see if it discharges.
Dec 21, 2009 | Goodman CKL24AR24 Air Conditioner
Replacing old 3 wire condensor fan motor with new 4 wire
the new one needs its own capacitor 5 to 7.5 uf hook to the 2 brown wires
May 08, 2009 | Goodman CLQ36AR49 Air Conditioner
Heating & Cooling Logo
57 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
