Question about Whirlpool GBS277PRS Stainless Steel Electric Single Oven
E6 F2 problem
Coffee got in behind the display is it fried or can it be repaired for less than a new stove
    Guru:
  • 310 Answers
We repair a lot of control boards for this problem.
Best Regards,
Bruce
www.fixyourboard.com
Posted on Jun 19, 2010
Whirlpool double oven display reads E6 F2
I have a Whirlpool RBD275PRT00 that showed the same codes. it would allow me to cancel and work for a few more days until the display finally went blank and after a few days of being blank displayed the codes again. I ordered a New Electronic control board from Sears W10340941 for 189 dollars just recently, when I just looked for this part for your model it's that same number but now listed for 254. There are services that will repair your board for a little less but it will not be a new board. it's still much cheaper that a new oven.
Dec 02, 2013 | Whirlpool GBD307PRS Stainless Steel...
I keep getting the following error message: E6 F2 - what does this mean?
If you have a Whirlpool oven, the F2 E6 error means that the Cancel key line is open. You will need to replace the keypad or the keypad and controller board (if a single assembly) if the keypad doesn't respond to a press of the Cancel Key.
I hope this helps.
Dec 12, 2011 | Whirlpool Ovens
Displaying E6 & F2 code
F2/E6 fault code implies a Cancel key drive line open. This means the key pad ribbon connector could be loose or dirty where it connects to the oven control board or a faulty oven control board.
Press Cancel. If the error code returns after 60 seconds, replace the key pad. If it continues to display F2/E6 after replacing the key pad, replace the oven control board. The parts can be ordered from Sears PartsDirect
NOTE: Disconnect the power supply from the oven before servicing.
Check additional details in THIS IMAGE LINK.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Nov 13, 2011 | Ovens
Received E6 and F2 code. repair man replaced the control panel key padand it worked for a while. stopped working and got same codes E6 and F2. Repairman saw the control's behind the key pad needed to be...
Hello & Welcome to FixYa
F2-E6 error code indicates an open/shorted oven temperature sensor and to solve this problem the temp.sensor needs replacement. If you want to be sure then before replacing the sensor you can test it with a voltmeter for around 1100ohms....if it reads more then 1120 ohms then it needs replacement however, if the reading is between 1080-1120 ohms then it is the control board that needs replacement. However, after reading your problem it seems that the sensor is causing this and replacing it is recommended repair. Please get back to me if you have any other questions.
Kevin
Mar 15, 2011 | Whirlpool GBD307PR Electric Double Oven
I have a whirlpool oven which has an error code flashing "E6 F2" the display is coming and going
F2 is most likely the oven temperature sensor. I cant find any reference for E6
Sep 15, 2010 | Ovens
Model RBD245PDB14 Error code F2 E6(left side) replaced original key pad with new. One week after install same error code and display blank out. Unpluged and reattached key pad cable but still diplays F2 E6...
If you replace the keypad and continue to have the same error you also have to replace the electronic control.
You can contact fixyourboard. com for a price to repair your control at a reduced price over a new control. It also comes back with a better warranty than anew control.
Jan 03, 2010 | Whirlpool Ovens
My oven is giving me an error of E6 F2, what does that mean
Equipment is Whirlpool double oven RBD305PDS14 built-in. After a very stormy summer 2007, I thought a power surge may have zapped the control board. Problem initially presented on display as error & fault "E6 F2"; simply pressing "Timer Off" would usually clear this error & fault code.
However, some months later, the display would often go completely blank followed by the beep sequence "short-long-short-short-short" (Morse code: dit dah dit dit dit). No error & fault code would appear. Pressing any keypad oven control did not work at all in this condition. When power was cycled at the breaker panel, the usual "PF" with clock display did not appear.
[TURN OVEN POWER OFF AT BREAKER!!!]
After following the excellent information on "how to remove the control panel" posted in this forum, I first tested the "control panel thermal fuse" (refer to the tech sheet that should be behind the control panel once it is removed). It showed a closed circuit.
I turned my attention to the "flexible" keypad connector cable (error & fault code "E6 F2" is a keypad or keypad connector problem; again, refer to tech sheet). The control panel has a board mounted female connector with two tabs that may be gently pulled upward to release the flexible cable.
I cleaned the flexible cable contact area (it seats into the board mounted female connector) carefully with a Q tip and some isopropyl alcohol. I reinserted the flexible cable and gently pressed down on the two tabs (noted above) on the board mounted female connector. VERY GENTLY tug on the flexible cable to insure it is gripped by the connector.
After all of this monkey business, I re-mounted the control panel display panel on the oven and restored power. So far, so good. After applying power, the "PF" with clock display always appears. I am able to set the clock and press "Start". Over functions normally. The clock displays as normal and I no longer observe the problem I described above.
BTW, I noted the incoming 240V has transient suppression (no surge protection, however
RATE THIS SOLUTION
RNJ VINOD KUMAR
Sep 19, 2009 | Whirlpool Ovens
My whirlpool oven is displaying E6 and F2. It
Your cancel key is defective at this point. follow these steps below?
1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Aug 08, 2009 | Whirlpool RBS305PDS Electric Single Oven
Whirlpool GBS277PRS Stainless Steel Electric Single Oven Logo
49 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal De
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
