Question about HP Pavilion dv7-1245dx Notebook
Hp dv7 1245dx fan is making a loud noise. how do i replace it?
  • codynsoxx May 10, 2010
    I have a little experience...I have changed the optical drive ( that was quite easy). I have changed numerous things in desktop type pcs. The laptop is not under warranty at this time. The warranty has expired as of last month.
  • Glen Law May 11, 2010
    Hi there codynsoxx, Before i give you a recommended replacement procedure, do tell me, do you have experience opening laptops and is the laptop under warranty? Thanks :)
  • 17 Answers
If it's anything like my dv7-1130us, it's quite a job.
I picked up a new fan for around $20 on ebay. That's the easy part.
The fan is pretty much the first thing they put in when they build the laptop. You have to take pretty much every part out, including the motherboard before you can get to it.
I couldn't find the service manual for the 1245dx, but I would assume it's about the same as the 1130us. There is a service manual for that on HP's website and it will tell you step by step.
It took me about 1 1/2 hours from start to finish.
Posted on May 27, 2010
How can i repair a loud noise my hp iq506 just started making? the noise is on the left side of the screen and it sounds like a fan running and skipping?
Its probably exactly that, switch off and remove the access panels and you will probably find its full of dust etc. Find the fan, give it a good blow out with an airline or a strong vacuum and see what happens. Replacement fans are a few bucks and take a good DIY person a few minutes to change. Look online for your make, model, serial for compatible fan.
Aug 12, 2015 | HP Computers & Internet
Hp laptop hp 430
Maybe the cpu fan is fubar - check that out.
Mar 18, 2017 | Computers & Internet
My computer fan making loud noise ,why?
fans tend to make loud noise right before they stop working!!! check to make sure that there is no clump of dust inside affecting the spin of the blades
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/charles_c2f37a3461344482
Dec 16, 2010 | HP (219426-001) Cooling Fan
A fan is making a horrible noise
hello
if its the CPU fan is making loud screech noises, its time to replace it
if the power supply fan is making the noise, its time to replace power supply , 5188-2859 is HP part number $25-$40
CPU fan = 5188-3722 HP part number , costs about $40-50
please rate my service with 4 thumbs up
Dec 09, 2010 | HP Pavilion Elite m9510f PC Desktop
The fan on my HP Pavillion laptop is making a loud noise
It is good idea to repair it in service before burn out. Fan blockage may lead to processor overheating and burning ... so as soon as better regards Greg
Mar 08, 2010 | HP Pavilion DV9700Z notebook PC
My fans are very loud do I need to replace them
check the plastic rings behind the fan blades, check to make sure plastic rings is tight and the screws holding fan cage on. Then when putting the fan cage back together, make sure it is tight so it wont vibrate
Jul 20, 2009 | HP (219462-001) Cooling Fan
I think the fan is making a super loud grinding noise.
I would not recommend this. You could fry your cpu and then you would have no notebook. If you are going to open the notebook make sure there is nothing interfering with the fan. The fan can be replace. Take the fan out and try to replace it, if needed. Do not run the notebook without a fan.
Feb 18, 2009 | HP Pavilion a1620n (882780664494) PC...
Hp laptop dv9500 noisy and loud fan ...
The sound you are hearing is probably the fan, This fan has a noisy bearing and will eventually lock up and the fan will stop spinning and therefore the CPU will overheat and shutdown.
The fan needs to be replaced.
Feb 13, 2009 | HP Pavillion ZV6000 Athlon 64 3500+ 15.4in...
Motor noise coming from hp designjet 120 nr
The fan is probably filled with dust. This can throw the balance off and make vibrations or cause resistance which can make a humm, not necessarily a bearing, not sure if the fan even has bearings. Anyway, the intermittent noise can be that the fans only run when the printer is hot. Find where the noise is coming from clean off the blades and components with a damp rag, blow around or lubricate the center of the fan, and replace it in the printer. Should fix it.
Dec 10, 2008 | HP DesignJet 120nr InkJet Printer
HP Pavilion dv7-1245dx Notebook Logo
2,207 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
