Question about Electrolux EL7020A Oxygen 3 Ultra Canister Vacuum Cleaner Bagged Vacuum
Belt replacement on an electrolux genesis
This older upright vacuum was given to me without a belt and I cant figure out where it goes or how to get to it. Ive removed 4 screws but cant tell where to begin to get it apart.
LizDahl
  • 75 Answers
SOURCE: electrolux canister vacuum
The easiest solution would be to call your local Aerus/ Electrolux representative, because the corporation doesnt publish diagrams.
Posted on Jan 12, 2008
  • 15 Answers
SOURCE: Electrolux Epic 8000
YES,JUST TAKE OFF THE HEPA FILTER.
IF I MAY SUGGEST,IF YOU WANT TO BUY AN AREUS/ELECTROLUX YOU MAY WANT TO LOOK AT THEIR "BOTTOM OF THE LINE" MACHINE, THE "CLASSIC" IT'S HALF THE PRICE AND A MUCH BETTER DESIGN THEN THE NEW "FLAGSHIP" MODEL, WHICH IS COMPLETELY DIFFERENT THAN ANY PAST ELECTROLUX. IT'S BULKY,AWKWARD TO USE. EVEN IF YOUR BUYING FROM ANOTHER SOURCE, GO INTO AN AERUS DEALER AND GIVE THEM A TEST DRIVE.
I CLEAN APARTMENTS FOR A LIVING AND AM VERY FAMILIAR WITH ALL ELECTROLUX MODELS.
GOOD LUCK!
Posted on Apr 09, 2008
  • 83 Answers
SOURCE: Vaccum will not turn on when upright
Do you have a DC17? It has two separate motors - one for the brushbar and one for the main motor - it sounds like the main motor is not turning on - call the Dyson helpline - they'll set you up for a repair with a repair dealer in your area.
Posted on Jul 30, 2009
  • 430 Answers
SOURCE: I have an older Electrolux canister vacuum - model
Check to be certain the thermo lite is on and not the bag full indicator. The thermo detector is very reliable, but the bag fill valve often fails. If it is the thermo, check your hose and wand for blockage by dropping a coin through them,before opening the vac itself.Otherwise you may have a bad set of motor bearings causing the motor to overheat due to its age.
The 2100 and all its canister cousins made since 1982 seem to be prone to failure of the dial valve on top cracking internally. The causes the bag full indicator to come on and the vac to shut down.
To open the vac you will need to slide the locking keys and bumpers forward with the bag door open. Do this with a set of pliers. Once done the vac will open from front to back like a **** shell. Be careful to look at the underside hinge are of the bag door before separating and mark and locate the wiring harness . This vac only goes back together one way, perfectly assembled it pops together with ease. If any piece is out of line it`s like a RUBIKS Cube. Take your time . OEM parts are only available through an AERUS Elctrolux dealer or repair shop
Posted on Dec 15, 2009
SOURCE: I have a 15 yr old electrolux genesis upright
Fip it upside down and hit the roller with a malett
http://evacuumstore.com/c-99-electrolux-belts.aspx?manufacturerfilterid=0
Posted on Apr 17, 2010
Where does the belt go on the Electrolux el8807
EL8807 no belt, separate motor for brush, use reset button. Call customer service, see my other post with the number.
Sep 30, 2014 | Electrolux EL8807A Precision BrushRoll...
Replace belt genesis upright
Turn vacuum upside down on flat surface, remove the 6-7 screws from the bottom of the power nozzle, lay it on it's side and pry on the two accessible internal tabs to pop top cap of the nozzle off to access the pn motor assembly. Lay flat on it's back again and remove the screws that hold the roller brush in, remove the roller brush, remove old belt, install new belt on brush roll and pn motor geared spindle, push brush roll back in place, replace screws and pn top and VOILA!..you're back in bidness! Hop that helps!
Jun 25, 2014 | Electrolux Vacuums
I cannot find a replacement belt for my Electrolux versatility HEPA bagless upright vacuum cleaner. Model# EL8505B
You can try to get a belt directly from Electrolux or maybe a local vacuum cleaner repair shop
Aug 14, 2013 | Electrolux Vacuums
Can't find the belt # for an electrolux genesis upright, serial number u 75344 p
The best place to get a genuine belt is the local Aerus Electrolux store. They're the only place to get a genuine belt without going on line. Most of their uprights use the same belt, so the store should have it on hand. I do highly recommend allowing their technician to make the switch as the power nozzle can be a bit tricky taking apart and reassembling.
To find the store nearest you, follow the instructions on the following site.
http://www.aerushome.com/storelocator/
Nov 26, 2010 | Electrolux Vacuums
How to change my vacuums belt
If you can't stretch it for enough get a bigger one and cut the bigger belt to where you want it.
May 19, 2010 | Bissell 6594 PowerForce Bagless Upright...
Need replacement belt PN 43409 for Electrolux Commercial Upright
Just about any vac shop should have the belt. This belt is the same belt used in the upright vacs as well as the power nozzels. The new oem part number is 48359.
Sep 25, 2009 | Electrolux UltraLux 2000 Bagged Canister...
I have a 15 yr old electrolux genesis upright vacuum cleaner that I can't get the roller out, to replace the belt.
There are two small screws at the end of the brush roll on some of these. There is a bearing block recessed into the housing at a slight angle to help tension the belt, so it comes out at an angle as well. It often fills with grit and you must clean the grit out carefully without damaging the blocks or housing. Sometimes WD 40 helps is the area has any rust build up. Then work a large screwdriver under one end the brush for leverage being CAREFUL not to damage the brush housing. Do not soak with WD40 as it will also get into the brush roll bearings
Jun 09, 2009 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Beater Bar Belt Removal from Upright Electrolux Vacuum
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=783793
Generic problem for all Vacuums
Beater bar Belt Removal from Upright Electrolux...
Posted by wrenn on Jul 14, 2008
I am trying to change the belt on an Electrolux Model 1717 Upright Vacuum and I am having difficulty disassembling the vacuum to remove the beater bar and belt.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. . Normally there are screws, clips or levers that would remove the bottom plate or if that does not work then the top cover will come off and that will expose the belt. Once that is off and the belt is exposed then cut off the old belt and then lift up the brushroll on the pulley end and install the new belt around the pulley end and re-install the brushroll. Then use a belt puller or a screwdriver with a bent right or left end to stretch the belt onto the motor pulley and then track the belt in a straight line and reverse you steps in the reinstall of the top cover or bottom plate. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://electrolux.com/ Customer Service 1-800-896-9756
Electrolux Home Care Products – North America
P.O. Box 3900 Peoria, IL 61612
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 14, 2008 | Vacuums
Changing belts
Turn vac over, remove the 4 screws holding the bottom plate covering the brush roll. There are 2 belts, one is a V belt ( 38528034) for the brush roll, the other is a flat belt (38528035) that goes from the larger pulley and the motor shat, put it on the motor shaft then stretch it to go over the pulley.
Jan 22, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Electrolux upright vac
Belts can look ok, but after a short period stretch so they won't turn the brush roll under load, if you have never changed it, and if it is a flat belt, I would try a new one.
Dec 26, 2007 | Vacuums
Electrolux EL7020A Oxygen 3 Ultra Canister Vacuum Cleaner Bagged Vacuum Logo
61 people viewed this question
Top Electrolux Vacuums Experts
Mack Baxter
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
