Question about Xerox WorkCentre C2424DN All-In-One Laser Printer
Xerox workcenter c2424 error code 39,014.40;33151
Getting this error code on start up but if I open and close doc feed cover it resets, any advise
    President:
  • 2,072 Answers
Could be a dirty scanner. Not much to check, it is a lamp issue.
You can try disconnecting the cables to the document feeder and scanner. The one on the right side of the machine, where the power cord, thats is odd to access and tighten often works loose.
Here is the entire documentation troubleshooting procedure, this is from the service manual.
Step Questions and Actions Yes No
1 1.
Cycle power to the system to clear.
2. Did the error recur?
Replace the Complete.
2 1.
2.
3.
3 1.
Are the lamps on?
2. Run the diagnostic test:
Go to Step 3. Replace the
lamp(s).
4 1. Is the scan head in the home position? Replace Replace
Posted on Mar 28, 2008
  • Rick Kasper Mar 28, 2008
    step 2 means the scanner dadf assembly
Xerox C2424 error code 19,003.48 and 07,010.43
for error code 07,010.43
Access the power switch by opening the Interface Cover on the right side of the machine.
click on this:
for maintainance
http://www.office.xerox.com/userdoc/C2424/C2424_Web/pdfs/en/ug_maintenance.pdf
for troubleshooting:
http://www.office.xerox.com/userdoc/C2424/C2424_Web/pdfs/en/ug_trouble.pdf
Jan 30, 2008 | Office Equipment & Supplies
Fault code: 009-381 - resetting nvram on xerox 7346
That error indicates low toner concentration in magenta. Enter diagnostics, select max setup, select toneup/tone down button, select trc control, select the start button. See if you get a result or a failure. If it fails replace the ATC sensor.
Dec 26, 2012 | Xerox Office Equipment & Supplies
Bizhub 211 - doc cover open
Something is open. Check and make sure you closed everything securely.
May 30, 2012 | Office Equipment & Supplies
Error code 6000
Error 6000 is a line feed error, it means the platen roller isn't advancing properly. It usually means something has fallen in from the back where the paper goes and is stopping the rollers from turning.
Check the printer for any paper jam or try to reset the printer to release memory code errors.
1. Press and hold the Resume button for 1 - 2 minutes.
2. Open the cover.
3. Remove the cartridge and then reinstall it.
4. Close the cover.
5. Turn Off the printer.
6. Turn On the printer.
Jun 14, 2011 | Canon PIXMA mini260 InkJet Photo Printer
Service error 6000
error code 6000
Condition:an error occurred in the lf encoder signal
problem and solutions:
-clean the LF/EJ **** film. -remove foriegn material. -if other solution fail,replace the following *lf/ej **** film *lf/ej timing sensor unit *paper feed roller unit *logic board *paper feed motor
May 25, 2011 | Canon PIXMA MP190 All-In-One InkJet...
13387.48:16806 error code on Xerox Workcenter C2424
From the Xerox Solution center --
Solutions for : Fault Codes 13,XXX.4X: Thermal Error Related Fault Codes: 13,xxx.4x Solutions ranked by relevance:
  1. Make Sure the Room Temperature is Within Operating Temperature Specifications
  2. Make Sure the Power Source is Not Causing the Behavior
A previous firm I worked at had these units. Do not plug them into a surge protector of backup power supply system.
Mar 22, 2011 | Office Equipment & Supplies
Xerox c2424 37,002,47:280890
The 37,002 error code is for a defective heater in the printhead 650-4354-00. There is no reset or workaround for this error.
Unfortunately, the part is fairly expensive, but the C2424 is such a workhorse, you may want to repair it.
Whit Item, Inc.
Dec 06, 2010 | Xerox C2424 Copier
My hp laserjet 2200 suddenly quite picking up paper. The rollers roll but nothing comes out. After a few minutes the error lights come on and must be reset by powering off then on again. This started when...
Try cleaning the rollers with a cloth moistened with alcohol.
The error can be reset by opening the top cover and closing it again.
I trust that you were using the manual feed tray to feed the labels.
Aug 24, 2010 | HP LaserJet 2200dn Printer
Xerox WorkCentre C2424DN All-In-One Laser Printer Logo
294 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
