Question about Refrigerators
My ice maker is not freezing the water in the ice cube tray
  • Refrigerators Master
  • 43,501 Answers
As the weather is getting warmer for many people their freezermy ice maker is not freezing the water in the ice - 2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on May 10, 2010
My ice maker isn't despensing enough ice fast enough to fill the ice bucket up
Ice makers spray cold water upward into cube shaped trays that freeze the water almost instantly upon contact . Then when you press the ice dispenser a heater comes on that releases the ice cubes from the metal trays. If it is very old replacement probably a good option.
Nov 27, 2017 | Refrigerators
U-LINE ICE MAKER NOT MAKING A FULL TRAY OF ICE AND CUBES ARE SMALL
HI.KATHY.if u got enough water then it must be the ice thermostat cutting out too early.hope this helps ali
Jul 12, 2012 | U-Line Icemaker
Excess water delivered to ice maker
That will depend on type of ice maker and model number of refrigerator. At times the water control valve will stick because of age or just leaking while off like a dripping faucet. Can you find model number of your whirlpool? I do have some repair manuals for ice makers if they are not the electronic type. Sea Breeze
May 22, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
My ice maker is letting too much water go into the ice tray so it freezes in a solid piece. Cubes do fall down but there is so much water it freezes into a solid block
The icemaker produces small cubes if the water fed into it is not enough and lumped together if too much water is supplied. In order to obtain the desired size of ice cubes, the amount of water supplied to the ice maker needs to be adjusted. Adjust the valve supplying water to the icemaker or the unit in general in such a way that right amount of water fills the ice tray.
Oct 30, 2009 | Sub-Zero Bottom Freezer Refrigerator
Ice maker does not run. Tray fills with water and ice freezes but the cubes are not ejected into the tray. Wire loop is down.
You will probably need to replace your ice maker. There is a heater on the bottom that seperates the ice cube from the tray. More than likely this heater is defective, but it is all internal to the ice maker so you will need to replace the whole unit.
Oct 25, 2009 | Refrigerators
Ice freezes into one solid block and won't dump out of the tray
remove cube tray from ice maker. clean with limeaway adn rinse. Spray with a light coating of PAM cooking spray. wipe dry and reinstall. be careful not to damage the sensor ( in center of tray)
Aug 26, 2009 | Samsung RS2578BB Side by Side Refrigerator
Roper Ice maker wont kick ice cubes out of tray.
Remove white plastic cover on ice maker. On bottom you will notice the heater connections, check for voltage. If good, heater is most likely bad.
Apr 16, 2009 | Roper RS22AQXKQ Side by Side Refrigerator
Ice Maker Freezing Up and Ice not dispensing
Check your ice cube tray to see if it is warped. Mine was. I took the tray off and dipped it into boiling water and remoulded it to the original shape and re-installed it. So far no problems. The tray gets warped because of the ice cube release mechanism. The tray is rotated around until it meets a block on one corner which creates the twisting motion we used to do on manual trays. Over time it tends to warp the tray. Good luck
Nov 26, 2007 | LG LRSC26925 Side by Side Refrigerator
My ice freezes together!
Do you mean the ice cubes are too large to be individual cubes and come out as a lump? The water is filled by a timed fill so if the fill solenoid stays open a little and drips water into the cube tray it will have more water than normal. I guess I'm not sure if you mean the ice cubes are stuck together in the tray or are they sticking together in the holding bin area?
Jan 30, 2007 | Kenmore 74172 / 74174 / 74179 Top Freezer...
Refrigerators Logo
56 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
