Question about Sony HDR-SR10E HDD Camcorder
Sony model hdr-hc1 moisture error code c:21:00
  • 3 Answers
Mine was from sitting for over a year. The sensor WAS dirty. Black just like the photo posted. Also tried hitting it, tried hair dryer and leaving it open (Worked for like 30 minutes)... next day problem is back. Found on different forum of a guy using a soldering iron to reheat the sensor contacts (2 soldering points just above the squigly sensor) and viola!!! No issues since. You'll need a super fine point low watt like a Weller WM120 (Pencil Thin Soldering Iron). Now I can archive all tapes to DVD and sell my camera!!! Make sure you have steady hands and good vision. You certainly don't want to spend much time with a hot iron near your mechanism. Practice a few times with a chopstick.
Posted on May 05, 2013
Posted on Apr 11, 2013
Had same issue, tore hair out for days. Fixed by cleaning little sensor at the back on the left (towards lens) inside. Its about 5 mm by 4 mm copper with black centre. Cleaned with alcohol cotton tip. Left for a day. This still didn't fix it. In the end i reset it and swapped batteries. Presto! Working again, happy Camper. I still believe the sensor needed cleaning (as did have gunk on it) and that's what triggered the issue in the first place, then swapping the battery and also hitting the 'reset button did the refresh the system needed to release it was clean. Done. Hope that helps! Who would have thought to swap the battery ? But that got it in the end. Good Luck
Posted on Sep 11, 2012
SOURCE: HDR-HC1 power keeps cycling
I had this exact problem, and the cycling would stop after about 30 sec. and then function properly. I believe a circuit was confused, mainly because I used an older battery and let it run out till the batt was dead - accidently - and when I put in a fresh batt, it no longer cycled and works perfectly to this day.
Now if I can get my computer to recognize the camera via firewire, I'd be golden.
Posted on Dec 29, 2007
welcomejee
  • 10594 Answers
SOURCE: Moisture Condensation
While cassette compartment open, blow hot air of dryer for 1 minutes in camera and check the dew error.
Posted on Sep 04, 2008
  • 41 Answers
SOURCE: blinking error code C:21:00 how to remove from sony camcorder
Try depressing the small "Reset" button with the camera power on. Use a sharp pencil/ball point pen to do that. It resets the logic in the camera and may help.
Posted on Feb 03, 2009
  • 30 Answers
SOURCE: HDR-HC1 video camera won't close after you put the tape in. Hmm
MECHANIZAM fauly.repalace it by expert.
Posted on Jun 21, 2009
  • 80 Answers
SOURCE: the lcd screen is almost black/ very dark, but i
The LCD screen may be turned OFF. To turn the LCD backlight off or on, press and hold the DISPLAY/BATT INFO button for a few seconds. After the backlight has turned off or on, release the button.
Posted on Aug 08, 2009
My HDR HC1 is showing moisture condensation alert every second time I turn it on for shooting. Also, in the playback mode on a shot tape I cannot find any video on the monitor...
- remove all from camcorder.(battery,tape and accessories and place the camcorder in a dry storage(ive tried placing it inside a rice container for a while and it helped because rice grains will absorb moisture) make sure to put the camcorder on a platform(cardboard or anything flat to place your camcorder) if you're going to place it in a rice container.its worth a try and its safe but if the problem persists i would recommend you to have you're camcorder checked and cleaned by a professional.
Jun 05, 2011 | Sony HDR-HC1 Mini DV Digital Camcorder
My sony hdr-hc1 cmacorder is saying moisture condensation turn off for one hour but its been more than an hour
Leave it in a warmish dry place for as long as it takes. Condensation on the tape mechanism will cause the tape to cling and get snarled and tangled in the drive. You also need to make sure that the tapes are completely dry. Exposure to cold then warm air will cause condensation even without any rain or other obvious wetting. If the problem does not clear up overnight, then there may be a fault with the sensor, but give it plenty of time.
Nov 29, 2010 | Sony HDR-HC1 Mini DV Digital Camcorder
How do you fix the touch screen on my hdv 1080i mini dv,
touchscreen problem on the HDR-HC1 is usually caused by a broken flex cable. service manual is a must-have; it illustrates the correct disassembly and replacement procedures for the cables.
Jun 05, 2009 | Sony HDR-HC1 Mini DV Digital Camcorder
CAMERA DOT CAPTURE TO LAP TOP
Make sure your camera is set to Play/Edit mode.
May 06, 2009 | Sony HDR-HC1 Mini DV Digital Camcorder
I had the same problem and found numerous solutions on the internet. The most common and apparently most successful was to remove the battery and give the camera a sharp whack. Didn't work for me. I tried to find a seperate CMOS battery to remove that but couldn't but your model may have one - try that. Then I found a thread at http://www.dvinfo.net/forum/sony-hvr-a1-hdr-hc-series/88013-moisture-condensation-2.html which suggested cleaning the moisture sensor on the left hand side at the very back of the tape transport mechanism. It is oblong shaped, has two solder points at its top and (in my case) a black square that should actually be a black circuit like pattern. Scroll through the aforementioned thread and you'll find photos to help you locate it. Using a cotton wool bud soaked in CD lens cleaning alcohol (you'll need a long one or small fingers :-) a couple of wipes was all that was needed to reveal the pattern. I re-inserted the cassete but still the same problem. With the camera turned on I then used a paper clip to depress the reset button (Flap open the LCD screen and you'll find it under the auto lock slider switch). The camera "re-booted" and everything worked fine! I had to reset the date and time and all my settings preferences but no big drama. Hope that helps.
Sep 04, 2008 | Sony HDR-HC1 Mini DV Digital Camcorder
Mar 07, 2007 | Sony HDR-HC1 Mini DV Digital Camcorder
Sony HDR-SR10E HDD Camcorder Logo
610 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
