Question about Whirlpool GS6NBEXR Side by Side Refrigerator
Whirlpool ice maker
Water still dispenses but ice maker not functioning I have replaced the filter checked every thing as per the manual Im sure water is not getting to the ice maker. The water in our village was disconected for about an hour last week and when the pressure returned the Ice maker did not spring back to life. Please help. Thanks
  • Hung1261 Apr 16, 2008
    I have the same problem. My Whirlpool ice maker just stop working last few days. I replaced the filter and check the light and the unit itself. The light is blinking or steady light when flapper is pressed. Not sure how to remove the ice maker unit to see if the line is clogged or not. I'm able to get water through water dispenser but it seems that there is no water get into the ice tray to make ice. Any help would be appricated. Thanks.
  • sjspoon Jan 06, 2009
    The water still comes out to make ice, but it pours out into the freezer so I turned off the icemaker; therefore, I have no ice now. What could be the problem?
    President:
  • Whirlpool Master
  • 2,651 Answers
This is a hard one to diag in person, let alone via email. you know your not getting water to the ice maker, problem is finding out why, ther is (or should be) a tech sheet behind the kickplate of this unit with a little trouble shooter and diag procedure for the ice maker. folded little blue/and or brown paper.
1. is the water line leading from the valve to the ice maker fill clogged/frozen??? pulll the machine out and youll see the line leadding to the top corner of freezer, disconnect that line and try to blow though to the insde of freezer, should blow withno resistance. if so your good if not youll need to thaw that line
2. is the red light blinking on the inside of door. its a sensor for the ice maker if its faulty you wont get ice either.With the flapper on rt wall of freezer depressed the light should remain on solid, if continues to blink a pattern, 1 and 1 quick blinks, 1 and them 2 quick blinks, youll need to replce the electronics
3. is the water valve itself just not sending water to the ice maker. its a dual vavle 1/2 does water and the other half feeds the ice maker . generallly youll hear the valve being energized, just no water coming through
4. ice maker itself can be damaged and not calling for water at all.a pretty common issue with these electonic control ice makers is the center gear actually over torques itself and winds up snapping itself(at least the tabs that hold ino place snap anyway). gaining acess to the face of the ice maker will tell this.
while looking at the exposed from\nt of ice maker you should see the center gear adn the 2 tabs holding the gear on as well. ther shoud be a SMALL but definite space betwwen the 2 tabs in middle of center gear, as if it were pressed on and the tabs spread back open to hold onto the gear. if 1 of the tabs is cracked or the gear isnot mounted correctly because of the tabs, you best bet is to replace the ice maker assy
GOOD LUCK
Posted on Mar 30, 2008
#4 hit my problem right on the head.
Posted on Apr 27, 2008
2 Suggested Answers
Healeyman
  • 1198 Answers
SOURCE: whirlpool ice maker
Sometimes the fill tube to the ice maker can freeze up. Remove the screws holding the ice maker, see if it will lower out of the way. Now the fill tube is visible, check to see if it's clear. If you have to unplug the power cord, there is a tab that has to be pushed down. If you find the fill tube is clogged, clearing it may just solve your problem.
Posted on Jan 24, 2009
Whirlpool gss26c5xyy ice maker not making ice, but will dispense ice and also will dispense water.
Andrea, make sure you are getting water to your ice maker. Most common ice maker problems are caused by lack of water. There is a water valve( dual) that feeds your water dispenser and ice maker that could be the culprit. Even if you are getting water out the door the valve can still be bad( separate water lines)..
Second thing to check are your optics( It measures ice level in your bin. If they are defective it will trick your ice maker into thinking its full of ice and not produce anymore.) They are located on the freezer walls just below ice maker..
Good luck
Jul 08, 2017 | Whirlpool Refrigerators
Ice maker in Kitchenaid KSCS25FT does not refill. Makes ice cubes when filled manually. How to fix?
When an ice maker produces ice after filling with tap water and then cycles and does not refill with water that is an indication that the=> 2319734 Dual Water Inlet Valve
is defective. Replacing the water valve should get you back into the ice making business. The 2319734 Dual Water Inlet Valve has two sides. One side is for the dispenser and the other side is for the ice maker. When one side goes bad you end up having to change the complete dual valve set. Here is a link to a Whirlpool Ice Maker Trouble Shooting Manual Here is a link to another source for the 2319734 Water Control ValveI will be here should you have questions please ask, Thanks Sea Breeze
Apr 09, 2013 | Refrigerators
Ice maker doesn't make ice anymore. The water works and dispenser levers on the door work for both ice (use store bought ice dumped into tray) and water. I replaced the filter after it quit making ice. Not...
you've already done the first thing i suggest, and that is to change the water filter. But if you still cant get ice made, you have a problem with either your ice maker or your water valve, or an electrical issue in the ice maker system.
Apr 02, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice machine isn't working
Two things come to mind.
First, the water valve at the bottom rear of the refrigerator may have failed. You didn't mention if there is a water dispenser and whether or not this is still working. This valve pumps water to the icemaker and water dispenser when the control unit of the icemaker calls for water. Also, there could be a blockage in the line which brings the water to the icemaker.
The other possibility is that the part of the icemaker controls which calls for water from the valve has failed. If this has happened, it would likely be more cost effective to replace the icemaker unit.
Oct 19, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water dispenser and ice maker don't work
You have a bad water filter housing. Be sure to turn of the water to the refrigerator before replacing this part. Replace the filter at the same time.
Apr 30, 2017 | Whirlpool GS6NBEXR Side by Side...
Freezer does not make ice
You need to check and see if ice maker has any water init. if not check the fill tube that goes thru the back wall for stoppage while you have it out rin the maker thru a harvest mode and listen for the sounds of the solonoid opening. If tube is full you'll need to replace the slow leaking valve a common problem. for parts call 704-819-6557
Mar 14, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool ice maker
Dec 17, 2008 | Whirlpool GS6NBEXR Side by Side...
Our icemaker stopped functioning. It is a Whirlpool Conquest Gold refrigerator. Are there some simple things we can try?
  • The refrigerator has a duel water valve, one for the ice-maker and one for the water dispenser (if equipped). The valve that the ice-maker relies on may be bad,
  •  or it could be the ice-maker itself.
  • Another thing that could cause it would be the temperatures in the freezer. The ice-maker will not call for water until it reaches under 15 degrees.
  •  In addition, check the water tube behind the ice-maker to make sure it is not frozen, blocking more water from entering.
  • Note: The water does not go to the ice-maker or thru the filter unless the ice-maker turns on the water valve.
Jul 06, 2008 | Refrigerators
I have a Whirlpool ED5GTGXN000 and the ice maker stopped working. Water dispenser is still working.
The refrigerator has a duel water valve, one for the ice-maker and one for the water dispenser. The valve that the ice-maker relies on may be bad, or it could be the ice-maker itself.
Another thing that could cause it would be the temperatures in the freezer. The ice-maker will not call for water until it reaches under 15 degrees. In addition, check the water tube behind the ice-maker to make sure it is not frozen, blocking more water from entering. The water does not go to the ice-maker or thru the filter unless the ice-maker turns on the water valve.
Jul 04, 2008 | Whirlpool Refrigerators
GE GSH22SGRE - water dispenser not working but ice cube maker working fine
check the water valve on the back of the ref. it sends water to the ice maker and water in the door one can work and the other one not
Apr 30, 2008 | Whirlpool ED2FHEXN Side by Side...
Whirlpool GS6NBEXR Side by Side Refrigerator Logo
6,214 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
