RV A/C fan motor is dying. I need to buy a replacement
  • kenao May 10, 2010
    How come you didn't tell me Emerson went out of business about 15 years ago? I just spent $10.00 for nothing.
    After calling around (locally)I found out Emerson went out of business about 15 years ago. So now I'm out $10.00 for nothing. This service sucks!!!
  • 713 Answers
Hi.you can purchase the fan motor of your unit from any of these websites;
www.repairclinic.com www.airconditionerparts.com www.airconditioner-parts.com www.tradekey.com
Thanks and take care
Posted on May 10, 2010
  • 1,284 Answers
Hi, you can the the parts to your RV A/C on this site below..
http://www.pplmotorhomes.com/parts/rv-air-conditioner-parts-1.htm
Take care
  • Shehu Pro
    Shehu Pro May 10, 2010
    Sorry about that, i wasn't aware to...
I have a 1999 camper with a Dometic rooftop AC . The fan motor will not turn,Where in Oklahoma can I find a new motor.
I wouldn't run out and buy a fan just yet. Have the fan start capacitor checked and/or changed. It is the most likely culprit.
Jul 26, 2010 | Dometic Rooftop RV Air Conditioner
Fan not blowing in coleman trs rv roof air
well check a few things first....have someone remove the cover and reach in with a hand and try to manually spin the blade...free spinning?....then tell the person below to click in the on postion while someone views from up top.....is it humming? or even trying to spin?....if not check the fuse on the RV that protects the A/C unit.....good?.....now replace the capacitor ( it the silver or gray can looking thing that the motor wires run to) only the correct size will work w/o causing further motor damage.
Jul 08, 2010 | Dometic Rooftop RV Air Conditioner
I have a Carrier RV Air V air conditioner. I turn
Have fan start capacitor checked/replaced by licensed tech, or electrician as they are very dangerous to work with if not experienced and can give a very high voltage shock, that could be fatal. They basically store and increase voltage to higher range for start up of fan and compressor.
Jun 01, 2010 | Dometic Rooftop RV Air Conditioner
I have a Dometic rooftop Air conditioner in my RV When I turn it to low medium or high the fan run the same speed and when I turn it to AC it will run for about 5 min then the fan will shut off but the...
Bad fan motor I suspect The windings are bad causing the motor to over heat sending the motor into thermal overload. would suggest the replacement of motor. Good Luck on repairs
Dave
Sep 14, 2009 | Dometic Rooftop RV Air Conditioner
RV AC not working
With power off, go on roof & try spinning fan at rear through cover with a stick, or something, until fan has made 2 or 3 revolutions, then try fan mode only & see if it starts. If no luck, remove cover on roof (watch for bees & wasps) and spin fan good by hand a few times & try again, if no luck, replace fan start capacitor.
Aug 30, 2009 | Dometic Rooftop RV Air Conditioner
Need fan motor part # for Coleman RV AC mod # 8534B876 2 speed
The Motor that you are looking for is part #14683109. This is the coleman part number and you should be able to contact your local RV Repair facility and give them this number and get the motor. Hope this helped.
Jeff
Jun 09, 2009 | Coleman Mach III Air Conditioner
RV air conditioner. Compressor running, fan stops before cool
The fan motor is getting hot and going off on the internal overload in the motor.
This is caused by either a low voltage, a bad capacitor, or tight or dry bearings in the motor.
To check the bearings turn the power off to the unit, then spin the fan blade if it spins freely then the bearings are ok.
To check the capacitor you will need some kind of tester or you can buy a capacitor and replace it, that's what a lot of people do. They usually don't cost very much.
To check the voltage you will need a voltmeter and measure the volts at the unit.
Jun 06, 2009 | Dometic Rooftop RV Air Conditioner
RV A/C fan won't start on its own
This could be the problem. It is more likely that the motor bearing is bad. Take the fan capacitor and have it tested. Or replace it, (under $20). Was the fan motor loud before this happened? Hopefully it is just the capacitor, the motor runs $60 - $100 and is a FUN to replace.
Jul 02, 2008 | Coleman Mach 15 Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
