Question about ASUS A7V8X-X Motherboard
Will high density ram work with the asus a7v8x-x
    President:
  • 2,351 Answers
I'll advise you not to use high density ram with the A7V8X-X MB. Read the link provided for more info;
http://www.1ststop.net/1stStop_2.htm
Cheers'
Mike
Posted on May 11, 2010
Testimonial: "thanks mate"
A7v8x-mx 2GB (2x 1GB) don't recognize
Sounds like you have run into a compatibility problem between your RAM and motherboard. These kinds of problems have been very common and that is why most motherboards have a supported memory list. Usually if the RAM does not work properly you can try reversing the slots that they are plugged into and make sure that your motherboard is set for the proper voltage and speed for the RAM. If it still does not work then you would most likely need either different RAM or a different motherboard.
Feb 17, 2012 | ASUS A7V8X-MX Motherboard
Pc ddr memory what is the difference between high density and low density
you need to check with board to fine what ram works with first.i use what they say to use so no problems later and save money as well ok jim
Nov 25, 2011 | Computers & Internet
Can the the Asus A7v8x support DDR2 sdram memory?
no it does not support ddr2 ... it supports only ddr ram
Feb 04, 2011 | ASUS A7V8X Motherboard
Hi, I don't know if I should get single or double sided ram for this mother board, and is low density ram ok? Thanks, Wayne
This mainboard uses DDR400 memory
A High Density module is by far much slower than Low Density module at the same speed rating say PC3200/DDR400. High density modules are FAR CHEAPER, less than half the price when compare with low density modules and hence high density modules will NOT work on 90% of today's PC chipsets. LOW DENSITY modules have 100% compatibility with ALL systems and ALL chipsets. HIGH DENSITY modules only have 10% compatibility and are VERY SLOW.
So AVOID those 'High-Density - 128Mx4 config 1GB modules which is usually UNBRANDED and is NO NAME!
With this in mind it is far better to use low density Ram. Most RAM cards today are double sided, it all depends on the capacity of the RAM card.
Please rate this solloution as it it much appreciated.
Thanks.
Oct 31, 2010 | Gigabyte GA-8S661FXM-775 MATX MBD SIS661FX...
Network driver
Follow these steps to get the right network driver for your asus a7v8x-x motherboard.
1. Click the link: http://support.asus.com/download/download.aspx
2. On Select Product, scroll down and choose "motherboard.
3. On Select Series, scroll down and choose "Socket A(462)"
4. On Select Model, scroll down and choose "A7V8X-X"
5. Click Search button
6. Select Operating System and click Search
7. Click "LAN" and select one from different download sites.
Good Luck!
Please do rate this answer and give me high ratings.
Thank you for using Fixya.
Sep 07, 2010 | ASUS A7V8X- X VIA KT400 ATX AMD AUDIO LAN...
Will high density ram work on an ASUS A8N-SLI Motherboard?
Possibly not.
Your best bet is to check the website of your proposed RAM vendor and see what their configurator lists for this board, then you will know if the RAM you want works with the board.
Regards.
Jul 01, 2010 | ASUS Computers & Internet
Km266-mnb Mother Board .... pc2100 ddr266 ram, will high density ram be compatible? Thanks
By this do you mean you want to increase the RAM on your computer?
I suggest you use PC2100 DDR RAM (same speed) and increase the total RAM to what your require but use the same RAM manufacturer if possible.
If you want to install more than 2Gb of RAM, check the motherboard specification for the maximum RAM that the motherboard can support.
Your motherboards may support more RAM with a BIOS upgrade.
Sep 06, 2009 | Azza Computers & Internet
Does ASUS P4P800 deluxe support high density memories
Here is a link to Asus' Qualified Vendor List of RAM modules for your motherboard. I do not see it mention high density RAM. You would need to search the specs on the modules recommended to be sure.
ASUS QVL
In case you don't have the manual, here is a link for it too:
ASUS P4P800 Deluxe Manual
Memory info begins on Page 2-10. Again, there is no mantion of HD modules.
Mar 01, 2009 | ASUS P4P800 SE (890552603657) Motherboard
1gb DDR 400 not recognized
That board needs to have minimally memory in pairs .. get another 1Gb stick
Dec 06, 2008 | ASUS A7V8X-X (90-M7A690-W0EAY) Motherboard
K7vm3 mobo RAM
If you are referring to the ASROCK mobo then it will work on the high density although not as good as with the low density but it will nontheless work.
Oct 13, 2008 | VIA ASRock K7VM3 Socket A/...
ASUS A7V8X-X Motherboard Logo
212 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
