Question about Bosch 3.81 cu ft WFMC530 1UC Nexxt 500 Plus Series Washer
Can't turn off my signal
Hi, I have a Bosch front loader and theres no signal on/off button. Is there any way to turn off the signal?
    Problem Solver:
  • 10 Answers
Short of disconnecting the beeper device wires inside the machine there isn't a way to do it. The Dryers have a signal button that lets you turn it off, the Washer's don't.
Posted on May 18, 2010
PCB isnt locking the door, what relay or other part is in charge of sending the signal to the door ?
Washing Machine Fault Diagnosis - How to repair
www.how-to-repair.com > Home > Washing machines
Nov 11, 2014 - Washing machine leaks from the front (see video tutorial on this) ... I have a Bosch washing machine which is leaking from underneath and the water ... It did work with no load in the drum on a 30 wash. ... Hi cecilia this is not enouth info on this fault but i would start with door lock and checking wiring to pcb.
Bosch Washing Machine Parts - RepairClinic.com
www.repairclinic.com/Shop-For-Parts/.../Bosch-Washing-Machine-Parts
Huge selection of Bosch Washing Machine parts in stock. Same day ... Door Boot Seal - Part # 1388885 Mfg Part # 00667489 · Skill Level: .... Front door sleeve.
Bosch Logixx WAS28440AU - ProductReview.com.au
www.productreview.com.au > ... > Front Loaders > Bosch
Rating: 3.4 - ‎74 votes
3.4 out of 5 stars for Bosch Logixx WAS28440AU in Front Loading Washing Machines. ... I've been quoted $895 to replace the PCB board plus technicians time plus have .... We're sorry to hear that you're having issues with the door locking on yourBosch WAS28440AU Washing Machine and .... This isn't limited to Bosch.
Jan 12, 2016 | Bosch Logixx WAS2446 Front Load Washer
How do i get the bottom filter out off my bosch front loader washing machine WAE22460AU. it will turn one quarter of the way but will not come out.
plenty of you tube videos on how to remove filter on a bosch front loader either go to www.youtube.com and search for bosch washing machine changing filter.
Dec 30, 2014 | Bosch Washing Machines
How come my bosch WA20261AU makes loud vibrating sound and its hot inside?
Hi Yvemarie,
Based on what I searched about the machine that you have where in the beep noise can only be hear at the end of the cycle not during the cycle. And also that noise can lower down and I will provide you steps on how to do that. It seems to me also that there is some kind of an issue on your machine since you said there was steaming and smoking happening, right? If the steps I will provide below works and still doing the same thing I guess you need to have that machine serviced.
    • 1 Press and hold the "Select" button on the electric display until the acoustic signal symbol, which looks like a small speaker-phone, is illuminated on the display.
    • 2 Continue to hold down the "Select" button until the system cycles through "Continuous", "Max" and then "Off" settings.
    • 3 Release the "Select" button when "Off" is highlighted next to the acoustic symbol. The signal noise is now turned off on the washer.
Read more: How to Silence a Bosch Washing Machine ' eHow.comhttp://www.ehow.com/how_7552735_silence-bosch-washing-machine.html#ixzz1fRDAKHrO
Apr 27, 2014 | Bosch Washing Machines
How do i clean Bosch WAE20261AU front loader washing machine
The lint will be in a removable filter and as for cleaning the rubber seal the black grime will most likely be mould. Try a good mould remover.
Apr 27, 2013 | Washing Machines
Bosch maxx clasic front loader Wkm41 the control panel has just died. what can I do to fix this?
I had the same issue this morning. I turned on the washing machine change a few settings, but didn't want these setting so i turned off and on again. When i turned it back on the panel was blank, but what had happen was the spin button was stuck in. Once i free the button the panel came back on.
Regards
Sep 10, 2010 | Bosch Washing Machines
Bosch maxx classic washing machine doesn't clean clothes
There are a lot of things to consider when trying to solve this problem. Obviously a front loader washes differently than a top loader. Top loaders tend to using a washing motion that is good for stains but wear out your clothes fast. Front loaders typically use less water and wash more gently, but in some ways still do better than top loaders. Anyway, think about any other variables that go into the laundry equation. Consider the distance the machine is from your water heater. This machine will use MUCH less water to fill than your old one, and, you know how when you turn a faucet on hot it takes a minute for the hot water to actually get there? It's the same way with your machine. If there's a sink next your washer, you should always turn on the hot water on the faucet until it gets hot right before you start the machine. The same goes for dishwashers. If there's not a sink close you can easily turn up the temperature for all hot water on your water heater, although that will use more energy.
Consider what detergent you're using. If you're using high efficiency detergent (like Tide he) maybe you should switch to your old brand. If you're using your old brand of detergent, try getting a high efficiency detergent.
Sep 20, 2009 | Bosch Classixx WFL 2066 Front Load Washer
I have a bosch maxx Wlf1600 front loader washing machine
This will require a replacement door lock,easy replacement & part very cheap
Jun 08, 2009 | Audiovox Bosch 718 World Cellular Phone
My bosch wfk2401 front loader is stuck on spin
Hi
There is a door bottom right of the system which has a screw out (by hand) plug.
Remove this and ensure there are no foreign objects such as coins, bobby pins etc stuck.
I have found this to be a problem with the Bosch systems and cost me $150 the first time.
Ensure you have some towels as when you open the plug, water will escape
Mark
Mar 04, 2009 | Bosch WFK 2401
Bosch Axxis front loader will not drain
check filter. check no foreign objects fouling pump impellor - bra wires are the favourite
Apr 25, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Bosch 3.81 cu ft WFMC530 1UC Nexxt 500 Plus Series Washer Logo
248 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
