How do I reset my URC-3940? Had it working until I tried the AV button; since then neither direct code input nor search method works.
SOURCE: Unable to install my RCA Universal Remote Control
how do you install it to work in my tv i lost the instructions!!!!!!!!!!!!!!!!
Posted on Jun 19, 2008
SOURCE: URC-R6
if u have any questions about the urc-r6 then jus go to the link and u can find exactly what u need. it took me no more than 2 min to get my situation resolved.......excellent
Posted on Jul 25, 2008
SOURCE: URC 7510 (no barcode for LG tv?)
i phoned sky with problem finding the number for my LG and they said it was only a monitor and not a tv and therefore there was no code for it....any help to you at all?
Posted on Oct 28, 2008
SOURCE: RCA Universal Remote RCR4258
ive got the same problem.
Did you ever solve it
Posted on Jun 02, 2009
SOURCE: just bought 9in1 universal remote urc 386, tried
http://www.xdiv.com/remotes/
Posted on May 30, 2010
Manual on URC-3940
Note: most remotes allow you to find the code by manually turning the TV (or other device) on first, then press the appropriate button (cable, DVD, surround, etc) then setting the the remote in the "program" mode, then keep pushing the "off/power" button until the TV (or other device) turns off, at that point the code is set.
Aug 08, 2014 | GE Tv Dvd Vcr Audio Universal Remote...
One for all remote codes don't work URC-3920
Hi keep teaching should come up with more if still dosent work try one for all web site or phone them very helpful
Aug 04, 2012 | Televison & Video
URC-3021 code search digitron
Code Search
If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
Jul 14, 2012 | One For All URC-3021 Remote Control
Does URC-3920 Remote Control work soniq tv
Try to find it out in manual One For All URC 3920 URC 3940 Or use automatic code searching mode
Jul 02, 2012 | One For All URC4220 Remote Control
INSTRUCTION FOR PROGRAMING THE CODES FOR A URC 3220 REMOTE TO A SHARP ENERGY TV
Code Search Method.
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Jun 15, 2012 | One For All URC4220 Remote Control
Learn mode urc 3940
URC 3940 has 5 digit setup codes. If you want to make sure about the compactability of this remote control to your devce, you have to make an autosearch function to it.
For more details Type in this site name < Electro-help> (DO NOT copy and paste the site name from here. Doing so may lead you to wrong place) to search box of your search engine [not in the address bar of your browser], and press "Enter".
It is an electronic equipments service help site.
Note the position of hyphen in between words in site name. The site will appear as it is in web; subtitled as Service help to electronic home entertainment equipments.
Pull up older posts.
You can locate this site, either at the bottom part of first search page, or at the top of second.
Detailed descriptions are there to help you.
visit this site. I'm sure that it will help you. There is description about how to do an auto search function to a remote control. Pull up older posts there.
Jun 08, 2012 | One For All Televison & Video
One for all urc 7110 guide button
For lg hdtv the method to hold the magic button for a while until led for tv is on and pressing code 991.then power off button and ch+ button for 35 times untill your tv switches off and back on several times and back ch- button.This works well for hdmi cable connection as well as to set the magic remote to work with guide and AV button properly.Then input for hdmi works well.many thanks.
Apr 12, 2012 | Televison & Video
Ive got a urc-3920 One for all remote . All functions works perfect , but the AV button mutes the TV. Cant change to AV with remote.I've pressed all buttons on the remote to see if it has not been switched...
i have a goodmans tv GTV69RFDT and i have brought a one for all remote urc-3920-urc 3940. All the codes dont work, i have tried the seach method and still nothing is working properly, i get the number buttons and volume but no up channel and down or menu button. Need help
Dan
Nov 03, 2010 | One For All URC-3021 Remote Control
Lost remote
Actually I found there are several remotes that work. The first is the Bright House networks remote, the larger one...The second is The Universal Remove Control by GE. It's numbered 24944 in the upper right hand corner of the paper. It's sold for $4.94 at Walmart in the checkout area...
I found that manually inputting the code for the remote doesn't work. You have to do a search for the code using their method...on this particular remote from Walmart, its hold the setup button down until it lights up, then press and depress the TV button...then press channel up until the TV changes channels. It worked once, but I just kept going, the 2nd time it worked, then I pressed the mute button [to keep the code] and it works...you simply press input and it switches to AV.
I have to admit I thought it was ridiculous that you can't use this particular TV without the remote, but I was happy that I went through the effort the first time to keep trying remotes...
This is the first kids TV that I have found that you can't find the AV channel by going through the channels AND you can't hook up two items to the AV outlets because you have to disconnect the back or front ones, to use the other....PLUS it only comes with a dual AV outlet, instead of the 3 plugs [red, white, yellow] only has the white and yellow.
A disappointing TV to say the least.
Feb 11, 2009 | Emerson SpongeBob SquarePants TV
Need a new remote for my SB315.
just get a generic remote and any tv shop
Dec 03, 2007 | Emerson SpongeBob SquarePants TV
Televison & Video Logo
145 people viewed this question
Top Televison & Video Experts
