Question about HP Pavilion dv9000z Notebook
Regarding my HP Pvavilion dv 9000, try to turn it on and the keyboard lights up for a few seconds and shuts down. Screen does not light up.
  • 3 Answers
Mine has been doing this for a long time, it seems to be a hardware issue vs a driver issue, also my laptop touchpad isn't working which is a driver issue. HP has not responded to any posts regarding this by loads of customers on their website.
Posted on Jun 25, 2010
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 94 Answers
It could be a hardware issue with the Motherboard of the notebook.
Contact HP and confirm it and then rate this solution.
I am sure I am correct.
Posted on Jun 19, 2010
Hello, my computer froze so after a few minutes, I took the power cable off and the battery out. I tried to turn it on after putting th ebattery in and I can see the lights but the screen is black. The...
Remove the screen and check at the hinged area (where the screen meets the keyboard) for any broken or damaged wire/s . I've experienced this on my wife's Toshiba only a week ago.
Aug 30, 2013 | Acer Aspire 5742 Notebook
1 have a 6 year-old Mitsubishi model WS-48511 series 1080 rear projection TV that now won't turn on. A few days ago we shut the TV off, and now when i plug it in the blinking green power light...
This is called the blinking green light of death-----only one of two things can cause this problem.
First: remove front speaker grill (IT PULLS OFF) AND remove inspection plate behind it; look for the two bundles of wires coming down and to the right from the front keyboard of the set.
Unplug both plugs you find (different and marked so you cannot mix them up-----the idea is to take the front keyboard out of circuit-----set will still function with remote as receiver is behind front screen)
Try (after 70 seconds) to turn on with remote
If it comes on---defective reset button on front keyboard----use set only with remote or remove and remove actual reset switch---it is located behind and part of frame for screen----entire front screen would have to be removed to get at it.
Second: if disconnection of the front keyboard does not help, the DM unit is bad.
As you look from back of set it is large metal box at extreme left side.
The blinking light is the unit trying to "Boot" up-----these have a problem where caps and a few other parts in that unit fail-----kits on the net are available----Mitsubishi no longer sells or services these units but PTS Electronics does repair them.
Let me know if you have questions and try disconnection of the front keyboard FIRST.
REGARDS, SD TECH
Jan 20, 2012 | Mitsubishi WS-55613 55" Rear Projection...
BLANK SCREEN HP DV 9000
Run system restore to factory default.
Start the system and hold down the f11 key till you hear a beep. Then follow the onscreen instructions.
Good luck.
Aug 23, 2009 | HP Pavilion dv9000z Notebook
HP dv6000 Lights up but that's it.
Re : When i press the power button, the lights all light up, the cd rom drive spins for a second and that's it. No fan, No Post, Blank Screen. After a few seconds, it shuts off and then turns back on.
That is generic hardware fault, any faulty device can cause the problem.
The motherboard must be started with a minimal set of devices to troubleshoot.
Start motherboard with only CPU, power adapter connected (faulty battery can cause the problem), heathsink, display and one memory stick. Keep unplugged HD, optical units, keyboard, minipci cards etc.
If problem persists, eventually test the motherboard using a post card(PCI & ISA PC Diagnostic POST CARD MOTHERBOARD TEST CARD) to ensure that new motherboard is not faulty, and then if cpu has not been replaced with the motherboard, replace CPU.
Jul 18, 2009 | HP Pavilion dv6000t Notebook
HAVE HP PAVILION DV 9000 LAPTOP , WHEN I SWICHED ON MY LAPTOP IS ON BUT SCREEN IS NOT WORKING AND EVERY ONE MINUTER LAPTOP GETS AUTOMATICALY RESET. SO PLEASE GIVE ME REPLY WHAT IS THE PROBLEM?
I have had this same problem with a HP DV2000 and the problem is not the contrast light. What it is, is that the laptop thinks that the screen is been shut down that is why the light does not come on. The best way to solve this is to remove your keyboard first.
You can remove the keyboard by removing exactly 7 screws from your laptop back, there are 5 screws located under your battery and other two that are in the location of your RAM'S.
Just open them up and then you will notice that the key board pops out abit then just simply take it up and then just below the keyboard, on the same line where HP brand logo is on your machine there are two small clip types of pind, that you can remove and put back.
There is a clip that is hidden abit under the metal plate, so just try and remove that clip from its place using a needle or any long and thin object.
That will make the laptop not have the problem. But once you remove that the laptop constantly will think that the screen is open even if you close it. then after like a week or two you can put it back and all shall be fine if not then just remove it and keep it out.
You can then set your power options to shut down the screen light every 2 minutes or something like that so as to avoid the backlight being switched on all the time.
Hope this solves your problem.
May 28, 2009 | HP Pavilion dv9000z Notebook
Pavilion dv 1000 won't reboot, stand by nor turn off
I had this kinda problem solved on a Acer 5920 LAptop. The webcam driver was the culprit. Remove the cam driver for the same, the windows driver will take over and then i guess it will work fine. I figure its a driver issue or a TSR program not quitting. If this fails try uninstalling recently addes program or driver.
Jan 05, 2009 | HP Pavilion dv1000 Notebook
Hp dv9000 will not start up. blue lights are go
you get a black screen right, nothing at all then no bios, no logo, nothing at all?
Do you get any beep codes and if so in what order?
did you try different ram?
First try to plug your laptop to an external monitor. If it works, you screen is bad, if it doesn't you probably need a new motherboard.
Dec 23, 2008 | HP Pavilion dv9000z Notebook
Sudden shutdown / will not power up
try check your BIOS.Upon turning ON your laptop, press down the DEL button of your keyboard then check settings of your power.it maybe activated the standby mode by certain time.
Jan 17, 2008 | HP Pavilion ze2000 Notebook
Hp Laptop problem
conect a external monitor to see if there is any image or if it is the same maybe the memory or prosesor damage
Dec 30, 2007 | Computers & Internet
HP Pavilion dv9000z Notebook Logo
132 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
