Question about Bose TriPort Consumer Headphones
The connector piece ripped off
Where could i go to get wire repaired? the piece dat connects to appliances got ripped off by mistake.i jus have the wire wit open ends.can i fix this?
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 17 Answers
It may look crapy but take apart conector and replace the wires in it with longer wires and wire nut the to pieces together
Posted on May 13, 2010
Take it to an electronics store, or if you know how to solder go that route
Posted on Jun 03, 2010
Vax vacuum cleaner. Lead pulled out too far and now it won't switch on. Lead is retracting o.k.
Check the fuse in the plug 1st, but you may have ripped the wire/s from inside the hover out of there connector. If you are able to, you may be able to take the hoover apart and reconnect the wires, if you feel this is something you are not happy with doing you may be able to take it to a repair shop! If its still under warranty you may be able to take it back and get it replaced?
Feb 23, 2015 | VAX Appliances Vacuums
Light stays on 2010 citroen C4 driver airbag
there are airbag connectors under the front seats. I have had an experience with another car and found faulty connectors, Because it is happening all the time, I would start looking at the Drivers side first. Maybe change the connector or add a piece of wire around the connector. Not the switch in the seat, jus the wire connectors,
May 19, 2014 | 2010 Citroen C4 1.4
My rear defrost will not work but the light works, whats the problem
Visually inspect the heating grid attached to the inside of the rear window for breaks in the horizontal lines. Any break in the filaments in the grid will cause a partial failure of the defroster, leaving a portion of the window fogged or obscured.
  • 2 Use a test light or voltmeter to detect breaks in the filaments that aren't visible to the ***** eye. Touch one lead of the light or voltmeter to a grounded metal part of the car and the other lead to a spot on the heating grid. If the light doesn't light or the voltmeter doesn't register a reading, that indicates a break in the filament.
  • 3 Place a piece of tape on each side of the break. Align one piece just above the filament, the other piece just below it, leaving a thin space through which the filament passes.
  • 4 Apply the filament repair liquid with its applicator onto each break you've identified. Be sure to thoroughly cover the broken spot. Allow the repair to fully cure per the instructions on the bottle, then carefully remove the pieces of tape so they don't rip the filament repair.
  • 5 Inspect the the vertical lines on the heating grid if you've discovered that the entire heating grid fails to work. Any break in the vertical lines will cause complete grid failure. These can be can be repaired in the same way as the horizontal lines. Check to ensure that the metal power tabs on each side of the grid are securely fastened to the vertical lines, as a break here will also prevent the entire grid from heating.
  • 6 Reattach the metal power tabs to the heating grid as needed by removing the tab from its connector and repairing it using the epoxy found in the heating tab repair kit. Be sure to allow the full curing time indicated on the kit before reinserting the tab into the connector to ensure that the circuit isn't broken.
  • 7 Check the power switch and wiring to the rear window defogger if there are no breaks in the heating grid and both of the metal power tabs are securely connected to the grid. Replace the switch and/or wiring as necessary.
  • Oct 16, 2011 | 2000 Ford Taurus
    Broken connector
    a new connector must be soldered in tuner if it was ripped out and did not break the pc board that it was attached to
    if it was on a switcher u could replace the unit or solder in new connector
    Sep 01, 2009 | Philips Televison & Video
    Zanussi zx99/5 not working ,lights still working but freezer defrosting and fridge getting warmer
    sounds like the thermostat inside the fridge has gone.
    The information I have provided is a guide and is not directly related to the make and model of the appliance brand you have but seems to cover the majority of household fridge freezers I have come accross. There is a dial inside the fridge usually up on the right side wall of the fridg where the light is. It is usual for the thermostat unit to be inside the plastic housing behind the dial. It is easy to replace the thermostat because I have done it myself and it worked. I am not an expert so if I can do it then anybody could. the unit is usually a standard replacement unit which costs roughly £20.00 available from fridge freezer repair shops. I got my replacement from Sale Appliances, Victoria Avenue, Southend-on-Sea, Essex. The unit comes with the thermometer type wire which fixes to the back of the fridge - inside that is- already attatched to it and all you need to do is remove the screw holding the housing in place (unplug from mains first of course), remove bulb, prise off the plastic housing to reveal thermostat unit, take some detailed pictures of how the wires are attatched or take detailed notes and diagrams, pull off the eelectical connectors (may need a pair of pliers to help, but must be gentle so as not to rip wires out of the connectors), put in new thermostat and rewire as it was before. You will not have to literally rewire the thing but simply slide the wired connectors onto the correct place. The connections are numbered both on the old unit as well as the new unit. Dont worry if the connectors on the rear of the new unit is different to the old one so long as you connect the wires to the same number it wont matter where that connector is located e.g. number two always fixes to the number two marked on the unit, number 3 to numbr 3 etc.
    Aug 08, 2009 | Zanussi ZX99 / 5 Bottom Freezer...
    I use to jus plug in ma zen a computer and it would jus install itself now it doesnt do dat.
    You need to try and update the drivers for you Zen.
    The drivers that it came with maybe out dated.
    Apr 22, 2009 | Creative Labs Zen Micro MP3 Player
    Attach new antenna wire to tuner (Funai TV VCR combo )
    If you take off the tuner cover you should see where another wire was attached to the PCB as there will be a small hole with nothing connected and a piece of wire at board level or broken level with the Printed curcuit board. If you dont see it then the best thing for you to do is to send the tuner to a tuner repair place like PTS tuner service and they have a flat rate to overhaul tuners and assy's or see how inexpensive a new tuner assy is. Its available at pts electronics for 49.95 along with many many more items like rebuilt printed curcuit boards ect ect ..www.ptscorp.com Good mluck
    May 04, 2006 | Funai F3813D 13 in. Combo
    Open Questions:
    Bose TriPort Consumer Headphones Logo
    267 people viewed this question
    Top Bose Audio Players & Recorders Experts
    Invebo
    Level 1 Expert
    Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
