Question about Bulova Watch
Trying to set date on fossil watch #691464401344
    President:
  • 2,501 Answers
The number you quoted does not look like a modl number (usually in the form AA NNNNN).
If you go to http://www.fossil.com/en_US/shop/customer_care/static/fossil-customercare.html , you will find some instructions. Choose the one that fits your watch and download the instructions.
Posted on May 10, 2010
How to set or restart the fossil automatic ME 1030? Because the problem now is when the time turn at 12 at midnight, the date din turn..
sometimes during time set, the hands are set to change date at day time.
check it your date turns during 12 noon, if yes move the hands clockwise until you set your time and date on sync.
say you want to set your watch date:10th and time:10:15am
adjust your date at 9th
then move your hands clockwise until the date turns to 10th at the 12 thats the 12 midnight.
then continue moving your hands clockwise until you reach 10:15am
Dec 14, 2010 | Fossil MultiFunction Automatic ME1030...
Philippe starck with fossil ph-2006
Fossil Contact Information Main support number 1-800-842-8621
Email support webguy@fossil.com
hope this helps
Mar 25, 2008 | Fossil Philippe Starck PH1026 Wrist Watch
I cant adjust the date for my Fossil AM4205..help!
mcdevito75 here, If your Fossil watch has a winding stem it may have 2 positions, gently place a fingernail under the crown and lift as gently as possilble, this should allow you to adjust the date without having to cycle thru the 24 hours to get to the date you want. It may take practise but that first position should be there, Set the date to 1 day before the date you need, then set the watch normally the full 24 hour cycle to get the date you want, this way the watch date will set as suppose to at about mid-night for the next days date.
Aug 28, 2010 | Watches
Fossil bq 9011349908 cannot set date and day
mcdevito75 here, There are many versions of Foosil watch, If yours has a stem (winder) it"s 2 position, to set Day pull stem out and rotate the hands till the day appears, push stem in all the way, Now slip your fingernail just under the crown and lift stem to it"s first position this will allow the date to change. You can also visit Fossil Watch online at Fossil Watches.com or visit a small watch repair shop in your area for adjustment help.
Jun 27, 2010 | Bulova Watch
My me1020 came without instructions and i do not know how to set the date, min nor theday please help
Actually there is no instruction manual for ME1020 available on Fossil website except for how to replace the battery. When you try to match ME1020 model with the available diagrams, there is no match (4 eyes). To set the time, pull the crown out to the second position. Now set the min/hour hands. Date hand is linked to it so keep rotating the crown till the date is set is set correctly. Now remaining is the day setting. Notice that the day changes every 24 hour mark on the 24 Hour sub-dial, so cross this mark to change the day. Go reverse & again cross the 24 hour mark to get the next day. Repeat this till you get the correct day setting. Now your day is also set along with date & time!
Feb 14, 2010 | Fossil ME1020 watch
Changing the date on a fossil watch- how do you do it?
Which Fossil do you own?
Analog Date Watch:
Date Setting
  1. Pull the crown out to position 2.
  2. Turn the crown either clockwise or counter-clockwise and set the date for the previous day. The direction that moves the date varies on different watch models.
Analog Automatic:
Time and Date Setting
  1. Pull crown out to position 2 and rotate clockwise to set time.
  2. Pull crown out to position 3; date will advance automatically. To set to required date, continue to rotate crown between positions 2 and 3.
  3. Push crown back to position 1.
Analog Digital:
Time and Calendar Setting
  1. Press and hold pusher A for 2 seconds to enter setting mode. Year will begin flashing.
  2. Press pusher A to select year, month, date, hour, minute, second, and then exit setting mode.
  3. Press pusher B to adjust digit.
  4. Press and hold pusher B to adjust digit automatically.
  5. If no pushers are operated for 30 seconds, setting will be returned to Normal Time Display.
These are the three most common Fossils. If yours isn't here please let me know which model you have and I'll get you the instructions.
Hope this helps.
Dec 12, 2009 | Fossil Watches
SETTING (DIGITAL) DAY/DATE ON THE FOSSIL JR9387
Follow this link and download proper instructions:
http://www.fossil.com/webapp/wcs/stores/servlet/StaticView?langId=-1&storeId=12052&catalogId=10052&page=Instructions&nav=custCareNav
Rate me, please.
Mar 24, 2009 | Fossil JR9388 Watch
Setting the day on my watch
Try this: pull out the winding crown to the first click and change the date. Memorize which way the crown turns to do that. Now turn the crown in opposite direction and the day should adjust.
This solution wrks for most of the makes.
If this doesb't work - submit the make, model and all the writings on watch caseback.
Mar 14, 2009 | Fossil BQ9183 Wrist Watch
Setting time & date on Philippe Starck Fossile watch ph1080
hold the left, bottom button (marked ....) for a few seconds....then press the top right button (marked with 1 dot) to change between the hour, minute, date etc. use the bottom right button to advance the flashing number, and when finished setting time and date, use the bottom left button to stop the numbers flashing and return the watch to normal. hope this helps, this is also how to change the date for the other question asker (works on 2 other starck/fossil watches i have and i assume the controls are the same).
Aug 08, 2008 | Fossil Philippe Starck PH1035 Wrist Watch
Bulova Watch Logo
67 people viewed this question
Top Bulova Watches Experts
Geoff
Ansel Alberto
Ansel Alberto
Are you a Bulova Watch Expert? Answer questions, earn points and help others
