Question about Frigidaire ATF6000ES Front Load Washer
Washer will not spin
My Fridgidaire washer will not spin . I does every other function
  • sandyfgomez May 11, 2010
    Was it making a grinding noise when it was working?
    President:
  • 1,382 Answers
Hi, If it doesnt spin, check to see if the motor is running, then proceed as follows:
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Thank you !
Posted on May 11, 2010
My fridgidaire front loading washer just recently stopped working on the spin cycle, it doesn't even work on the spin/drain cycle.
More than likely a bad door switch, as it won't go into the spin if the board doesn't like the reading it gets from teh switch. They fail quite often. Part number is 131763202
Apr 04, 2010 | Frigidaire ATF6000ES Front Load Washer
My fridgidaire frontloader wont do a spin cycle
A lot of times it is the strainer clogged at the pump. That has happened to mine. Hope that helps.
Sep 06, 2009 | Frigidaire Affinity ATF7000E Front Load...
Front load Fridgidaire ftfb4000fs1 won't spin
This is a fault that resides within the motor control board. you will need to replace this failed module asap if possible. it has failed.
Jun 15, 2009 | Frigidaire ATF6000ES Front Load Washer
Won't spin.
wont spin because the unit is not drainning water...wont spin with water in it must drain first...check drain hose for kink,,,check waste pipe for blockage...and than check pump...onthejob
Dec 15, 2008 | Frigidaire Affinity ATF7000E Front Load...
Fridgidaire FTF2140ES0 Front Load Washing Machine Vibration
Try going to GVIINC.net - there product definately works.
Nov 16, 2008 | Maytag EPIC MFW9700S Front Load Washer
14 cycle front load washer fridgidaire
press cancel. (turns off washer)
press start/pause (wake up)
hold cancel and start/pause 10sec
last error code will come up.
E47 door lock error
check wires connections to the door lock..
replace door lock..
hope it helps
Aug 08, 2008 | Frigidaire ATF6000ES Front Load Washer
My fridgidaire washer fillw with water and agitates but it will not spin or drain.
YOUR LID SWITCH IS BAD,POP THE TOP FIND THE WIRE JACK TO SWITCH CUT BOTH OUTSIDE WIRES,WIRE NUT THEM TOGETHER,MADE SURE YOU UNPLUG MACHINE FIRST,YOUR MACHINE WILL NOW WORK BUT WHEN YOU LIFT THE LID ON FILL OR SPIN IT WILL NOT TURN OFF,SO KEEP YOUR HANDS OUT OF THERE,THE LIP SWITCH CONTROLS FILL AND SPIN,THANKS-MIKE
May 29, 2008 | Frigidaire FEX831CS Top Load Stacked...
Frigidaire ATF6000ES Front Load Washer Logo
153 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
