Question about Sanyo EM-Z2000S Microwave Oven
Loose Light? My light in the microwave doesn't work. It stopped working soon after I bought it. On occassion it will turn on when I tap it. I think it is loose but don't know how to tighten it. Please help.
MOST MICROWAVE OVENS TODAY HAVE TO HAVE THE OUTER SLEEVE REMOVED TO ACCESS THE SIGHT BULB.
THIS IS DONE BY REMOVING ALL THE SCREWS ALONG THE BACK EDGE OF THE SLEEVE AND PULLING UP AND
BACKWARDS ON THE SLEEVE. SOMETIMES THE BULB ISN'T LOOSE BUT THE FILAMENT IS DANGLING IN THE LIGHT BULB AND OCCASIONALLY MAKES CONTACT WHEN IT IS BUMPED. THE BULB WOULD NEED REPLACED.
Posted on Mar 28, 2008
GE OVER THE RANGE MICROWAVE DOES NOT STOP WORKING
You probably have a shorted cook relay.
We regularly repair this problem with our $39.95 service, or you can order a new circuit board from the Pros here, our favorite supplier.
Nov 27, 2012 | GE SpaceMaker Microwave Ovens
Not heating
If the door sensor thinks the door is ajar, it prevents the microwave from heating as a safety precaution.
I found with my old microwave that tapping on the closed door, right at the latch, with a little bit of force would convince the sensor the door was really closed.
Apr 11, 2008 | Sharp R-930AK Convection/Microwave Oven
Microwave oven doesn't work but light turns on
It sounds as though you have a defective electronic control pad.
May 03, 2012 | Frigidaire Microwave Ovens
My model nn-p295wf microwave stopped working ,all power just stopped, about a year ago. I took it to a repair shop and they replaced the DIODE and the fuse, then it worked again. Afew weeks ago it happened...
Replace the magnetron, safety fuse and diode as a set and check the door interlock switches.
That should get it working for another year or so.
Don't forget microwave mains fuses are special sand filled and semisurge type.
Nov 16, 2010 | Panasonic NN-P295SF Microwave Oven
My sharp microwave just stopped working. It
IT IS POSIBLE TO HAVE A BURNED FUSE ON THEI Main boARD OF THE OVEN
Feb 14, 2010 | Sharp R-1480 Microwave Oven
I have a Magic Chef over-the-range microwave (MCO160UB), and recently the turntable and internal light stopped working while it runs. Light and fan underneath both work, and the internal light works when...
well an educated guess would be a short or loose connection in a common thats shared between the two that could rattle loose when it so chooses.. without a wiring diagram it would be hard to guess more specifically where without laying hands upon it.. and for that you'd have to lower it to the countertop level and dismantle to test.. it could always turn out to be a bad board also, but thats usually a done deal and doesn't repair itself then break again..
best of luck,
ttfn
Oct 25, 2009 | Magic Microwave Ovens
All the light blew out, the electric still works, but the oven won't heat food
Hi, my living room light has stopped working, When i turned it on one of the little bulbs went pop and light stopped working although all electric and other lights still work. I tried the bulb in a different light and it still works as well?? I also took light off to check for loose wiring etc but all seems to be fine. Can you help? Thanks!
Oct 04, 2009 | Whirlpool Accuwave Microwave Oven
Kenmore 721 microwave fan turns on by itself
I have the exact same problem with my Kenmore Microwave model 721 that we bought in October of 2005. The Fan will just randomly turn itself on even when we are not cooking. It has been doing this for the last few months and is starting to become more frequent. There is no way to turn it off except to unplug it for several hours.
Was there a recall for this defect ?
Apr 25, 2009 | Kenmore Microwave Ovens
GE microwave won't turn off
Just checked the GE website. Had the same problem with my 5 year old microwave. GE website says to close and open the door quickly three times. First time I did this it didn't work. Second time I closed the door with some significant force and reopened it more quickly. Worked. Unplugged the microwave, plugged it back in, still fine.
Mar 21, 2009 | Microwave Ovens
Microwave is not working - no power
The key was that you mentioned it was purchased less than a year ago.
Glad it worked out for you.
Jan 06, 2009 | Microwave Ovens
Sanyo EM-Z2000S Microwave Oven Logo
75 people viewed this question
Top Sanyo Microwave Ovens Experts
William Miller
William Miller
Gerry Harvey
Gerry Harvey
EugenesDIYDen
EugenesDIYDen
Are you a Sanyo Microwave Oven Expert? Answer questions, earn points and help others
