X2gen monitor black
X2gen monitor went black - no picture. It is less than a year old. Another monitor works on same computer
  • 180 Answers
Its power failure . Its either the PS section or horizontal output section that can power to shut down.
Posted on Apr 21, 2008
SOURCE:
X2gen computer monitor model MW19A. After about 1 hr. or longer it finally comes to life.
How old is it? If it's less than a year old from when you bought it, it should still be covered under warranty.
Oct 11, 2013 | Computers & Internet
My 19 inch x2gen mw19r monitor just went black its still on but wont display a picture so now im using my old tube monitor want to fix the x2gen
titter101, You left out telling us the "DATE of MANUFACTURE" for your unit. You will need to use CRT unit while researching info on x2gen mw19r unit. If unit out of warranty, then you or qualified technician will need to do the investigation and repair of unit. Read the fixya profiles of "budmrtn" , "buddymc" , "12fixlouie" to see if a DIY repair will work for you. 12fixlouie
Aug 16, 2010 | Computers & Internet
X2 MW19R is ticking and no display?
It sounds like you have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of the monitor. If you are good at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you can't do the repair we offer a repair service, contact us for more details or if you have any questions.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Aug 13, 2009 | X2Gen MG19MY 19" LCD Monitor
X2Gen monitor goes black off and on during use
It sounds like you have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of the monitor. If you are good at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service contact us for details.
Buddy
Corporate Computer
www.ccl-la.com
Jul 21, 2009 | Computers & Internet
Mw22u monitor has white screen.
Manufacturer out of business. Local repair shops want more $ to fix than the cost of a new one.
Solution --- Trash old and replace with new display.
Mar 25, 2009 | X2Gen MW22U Monitor
Black screen. Power light binking from dim to bright
I have exact same problem but mine happened to 2 of my x2gen monitors at the same time,really strange.
One was purchased 01/07 and the second 04/07
Took my PC in, no problems
Took one of the x2gen in,was told monitor is bad
How could both monitors go bad at the same time???????
Mar 20, 2009 | X2Gen MW22U Monitor
22" X2gen Screen Gone Black
Hi...there,
Well...You're out of lucks! Only mfg. carried this parts... But you can try to repaired it, by replaced a few busted capacitors... Good lucks!
Oct 30, 2008 | X2Gen MG19MY 19" LCD Monitor
Black screen
Hey...Benji,
It's seems your backlight inverter are burnt out...Get a new one..or repaired old one by yourself.
Here how it done...need to replaced a new capacitors. Good lucks!
Aug 19, 2008 | X2Gen MG19MY 19" LCD Monitor
Open Questions:
Computers & Internet Logo
443 people viewed this question
Ekse
Alun Cox
