Question about Dell UltraSharp 2208WFP 22" Widescreen LCD Monitor
I have a Dell 2208WFP Monitor. When it poweres up it stays on a couple of seconds and the display goes off, If the power is cycled same thing. Has problem connected to VGA or HDMI. I replaced the inverter PS, no help.
  • 11,361 Answers
The problem can be the lamp assemblies also, it will be hard to verify unless you have test lamps to find out if it is the lamps or the inverter problem, that is one of the first thing I check first if the board has no sign of damage. I save a lot of lamp assemblies for testing purpose.
http://s807.photobucket.com/albums/yy352/budm/Inverter%20test%20lamps/
http://s807.photobucket.com/albums/yy352/budm/Bad%20backlight%20lamp/
Inverter tester: http://lcdparts.net/IT01.aspx
Posted on May 11, 2010
Dell monitor screen suddenly went white. Can it be fixed?
I have a strong suspicion that you have burned a capacitor or two on the monitor. You will need to bring this in to have it serviced as it will require the monitor to be opened up and new capacitors replaced/resoldered.
Mar 18, 2017 | Dell Model 2208WFP - 22 Inch Widescreen...
2208wfpt flickering, not staying on
The problem is in the power supply/inverter board, there are more than likely one or more bad capacitors that open, "sometimes bulges at top" the other concern is one of the inverter transformers may be bad, or a failing backlight behind the display.
Apr 22, 2012 | Dell UltraSharp 2208WFP 22" Widescreen LCD...
2208wfpt
The problem is caused by one or more capacitors that have opened in the power supply/inverter board, sometimes they show a bulge at the top making it easier to spot.
The Dell AS 501 monitor display comes and goes off in seconds. If I switch off and on again, the display comes back and goes off again in less than a second. I repeat this as many times the same monitor...
This sounds like the power inverter is failed.. It's what pumps up the power for the light in the monitor.
You could try unplug the sound bar from the back of monitor if you have the sound bar installed. Just a maybe..
To fix the inverter (replace) is usually better to buy newmonitor unless you do it your self.
The defective LCD Backlight inverter will cause the following symptoms:
  • No Display, but Power Indicate light stay on green (Or Blue).
  • Screen flash on and off and the power indicate light stays on green (or Blue).
  • Dim Display
Go here to start looking if you want to try yourself. http://www.lcdparts.net/DI3D.aspx
Dec 27, 2010 | Dell Computers & Internet
DELL 2208WFP LCD-Comes on normally, but almost immediately goes dark You can see something on the screen if you look closely. Turn it off and back on you see it then dark. any help?
I believe the power led button is still on while the screen goes dark, if yes, it means the picture board of your monitor is bad that is why it appears for a second and goes dark after that
Since the power led button is on, It means the picture board on your monitor is faulty that is why it appears for a second and goes dark.
The best thing for you to do now is to take the monitor to a local repairer or any service center within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself in other to complicate issues.
Take care.
May 01, 2010 | Dell UltraSharp 2208WFP 22" Widescreen LCD...
Dell 1707FPt monitor doesn't display
Make sure you have the plug in tight or maybe your need a new monitor
Jan 13, 2010 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Dell E153FPd Power stays on but video goes off after 2 seconds.
3 ideas here. bad connections on the coils inside. the inverter board has gone bad, or bad capacitors on the power board or inverter board. all of witch should be serviced by a qualified service center.
Jul 21, 2009 | Dell E173FP 17" LCD Monitor
Dell E173FPC Monitor stays black and the Power switch cycles
You need to disasemble and check for dry or burn capacitors first then check for the transistors near the inversors.Good luck
Apr 03, 2009 | Dell E173FPc 17" TFT LCD Flat Panel...
Dell Monitor won't stay on
When it goes black, does the power buton stay green or is it orange? If it's orange, the power supply/inverter is your main culprit. If the power button stays green, it sounds like the backlight for the display is bad. Either way, unless you have parts for the same monitor laying around to swap out, you're due for a new monitor. The good news- with the economy in the tank, you can search online and find some reputable vendors selling nicely sized screens for less than $100! Heck, I've even seen a 22" for $129 (once but it was there).
Sep 23, 2008 | Dell E177FP LCD Monitor
Dell UltraSharp 2208WFP 22" Widescreen LCD Monitor Logo
2,003 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
