Question about HP Color LaserJet 3500 Printer
My HP Color Laserjet 3600n had a paper jam. The
My HP Color Laserjet 3600n had a paper jam. The paper jam occurred when two hard stock sheets of paper were pulled at the same time. They were over half way pulled through. We manually pulled out the sheets. Now we have an error message stating "Jam inside front door" with an error code of 13.20.00. We do not see anything that is not supposed to be there.
  • 52 Answers
Your best method of troubleshooting is the manual sensor test as this is a generic paper jam error.
on your sensor tests:
0 = off
1 = on
A = TOP OF PAGE SENSOR
B = PAPER LOOP SENSOR
C = N/A
D = FUSER PAPER SENSOR
E = DELIVERY-TRAY PAPER-FULL SENSOR
F = FUSER PRESSURE-RELEASE SENSOR
G = MEDIA SENSOR
H = N/A
I = MP TRAY SENSOR
J = CASSETTE SENSOR
K = DOOR OPEN DETECTION SWITCH
L = DEVELOPING ESTRANGEMENT SENSOR - CLR
M = DEVELOPING ESTRANGEMENT SENSOR - BLK
N = MP TRAY MEDIA POSITION SENSOR
A-F are paper path sensors - you can toggle them and watch if they change from 0 to 1. If they do, the problem is not in that area.
G can have states from 0-7 each one representing a different type of paper - shouldn't have anything to do with jamming.
hope this helps. probably a tiny piece of paper or toner somewhere. could also be a torsion spring out of position on a flag.
Posted on May 10, 2010
An error code of 13.20.00.
Posted on Aug 25, 2010
No writing on the right side of the sheet with black and color faded out on same side with color
if i read this correctly both color and black are missing from one side?
this is most likely a problem with the belt.
if it was just 1 color or black it would be that toner/drum cartridge or the laser associated with it.
http://www.precisionroller.com/belts-for-hp-color-laserjet-3600/details_45933.html
for non duplex
and
http://www.precisionroller.com/belts-for-hp-color-laserjet-3600/details_45935.html
for duplex model
Jan 19, 2011 | HP LaserJet 3600n Printer
PAPER JAM - HOW DO I REMOVE SHEET OF JAMMED PAPER
The 2600s have a door in the back that can be removed to gain access to any sheets that may have become jammed. The front panel opens in two stages, the second requiring a button press on the side to gain access. Using gentle pressure and left-to-right motions you can slowly pry the trapped page from the rollers (make sure the printer is off before you begin) Some amount of disassembly may be required if the page becomes torn, but refrain from using sharp objects to pry the paper free. If you are unable to find the jammed sheet, remove the paper drawer and check the feed rollers.
Nov 25, 2010 | HP Color LaserJet 2600n Printer
Printer jam
Make sure tray 1 is set for "auto-sense/full sensing".
Make sure the feed rollers are clean or just replace them
May 06, 2010 | HP Color LaserJet Enterprise CP4025dn ...
Hp color laserjet 3600. It keeps telling me that
if you have used another printer on the same port # or local port. plug the cable into the 3600 and refresh the port. if its an ethernet port print th io sheet and make sure its holding its settings.
Oct 18, 2009 | HP LaserJet 3600n Printer
Hp color LaserJet 3700 jams 70# uncoated letterhead stock
Hi manitou344:
Here is some info that might help you.
Table 1-8. Tray 1 paper sizes1
Media Dimensions Weight or thickness Capacity
Minimum size paper 76 by 127 mm
(3 by 5 in)
60 to 163 g/m2
(16 to 43 lb bond)
100 sheets
(75 g/m2; 20 lb bond)
Maximum size paper 216 by 356 mm
(8.5 by 14 in)
60 to 163 g/m2
(16 to 43 lb bond)
100 sheets
Minimum size glossy
paper
76 by 127 mm
(3 by 5 in)
75 to 120 g/m2
(20 to 32 lb bond)
Maximum stack
height: 12 mm (0.47 in)
Maximum size glossy
paper
216 by 356 mm
(8.5 by 14 in)
75 to 120 g/m2
(20 to 32 lb bond)
Maximum stack
Minimum size
transparencies2
76 by 127 mm
(3 by 5 in)
0.12 to 0.13 mm thick
(4.7 to 5 mils thick)
50 sheets
Maximum size
transparencies2
216 by 356 mm
(8.5 by 14 in)
50 sheets
Minimum size
envelopes
76 by 127 mm
(3 by 5 in)
60 to 90 g/m2
(16 to 24 lb bond)
10 sheets
Maximum size
envelopes
216 by 356 mm
(8.5 by 14 in)
60 to 90 g/m2
(16 to 24 lb bond)
10 sheets
Minimum size label 76 by 127 mm
(3 by 5 in)
75 to 163 g/m2
(20 to 43 lb bond)
50 sheets
Maximum size label 216 by 356 mm
(8.5 by 14 in)
75 to 163 g/m2
(20 to 43 lb bond)
50 sheets
Minimum size
cardstock
76 by 127 mm
(3 by 5 in)
135 to 216 g/m2
(43 to 43 lb bond)
50 sheets
Maximum size
cardstock
216 by 356 mm
(8.5 by 14 in)
135 to 216 g/m2
(43 to 43 lb bond)
50 sheets
This printer can
detect transparencies that were not designed for use with HP Color LaserJet printers.
Jun 30, 2009 | HP Office Equipment & Supplies
Frequent paper jam
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 10, 2009 | HP LaserJet 2550L Printer
HP LaserJet 5550DTN jams at transfer unit
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Jan 06, 2009 | HP LaserJet 5500dtn Color Printer
HP laserjet 5000N - Paper jam under the cartridge every time try to print
Jan 03, 2009 | HP LaserJet 5000n Printer
Jaming
Dec 30, 2008 | HP LaserJet 3600n Printer
HP Color LaserJet 3500 Printer Logo
2,634 people viewed this question
Seeker5211
Seeker5211
