Question about Homelite Mighty Lite Lawn Trimmer
HOMELITE EXPAND IT 26VT WON'T RUN
I WAS GIVEN A TRIMMER THAT WON'T RUN. I THINK HE HAS HAD THE CHOKE RUN WHEEL OFF AND LOST SOME PARTS. I HAD THE MOTOR START WITH FLUID. SOME GAS IS GETTING TO THE SPARK PLUG BECAUSE ITS WET AFTER PULLING CORD A FEW TIMES. DOES ANYONE KNOW WHAT MY PROBLEM SOLUTION IS??
LARRY
    Sniper:
  • 53 Answers
Well if you are missing parts?...No. How could anyone from where we sit. But the fact that it starts with starting fluid is a great sign however. First off, Fresh gas/oil mix is A MUST! No getting around that. OK first, when you pull the throttle (Give 'er gas) does the little lever at the carburetor move back and forth at all? if yes, then what happens when you hit the primer bulb? Does it push/**** fuel from the tank? (My homelite spits fuel out to the ground when I prime the bulb, most spit it back to the fuel tank however) See if priming it moves fuel. You should see a trail of bubbles in the fuel tubing. You have to see if you are getting fuel at all first. Then does it maintain the prime? If not? Then the primer bulb will usually remain empty. A good prime should always show a half full or 100% full bulb at all times. Let me know what we got so far.
Posted on May 10, 2010
How do I install trimmer line?To a Homelite Lite 26vt trimmer. Can i download a manual?
The detailed instructions, plus diagrams are in your manual. You can go here to view it. You will need Adobe Reader installed on your computer. This is the closest I could get to your model.
http://lawnandgarden.manualsonline.com/mdownloads/7d2e081d-9dc3-4ad6-b637-f6f946e2283e.pdf
Feb 13, 2011 | Homelite Mighty Lite Lawn Trimmer
Expand it zr15520 pruner attachment oil resavor clear cover has crack in held down with 4 screws do know were i can get this part pso4545 this number is under the cover when removed thx
I think Homelite Expand It and Ryobi use the same pruner attatchment. I found this one on a Homelite Parts site under Ryobi. Your part looks to be number 20 in the breakdown. I hope this helps.
http://tinyurl.com/2au56eo
Dec 11, 2010 | Homelite Expand - It 10" Pruner Attachment
I was given a homelite mighty lite 26VT and I can not figure out how to remove the spool to insert the string.
There is a threaded cap on the spool that can get very tight, but a pair of Channel-loc pliers usually does the trick to remove the cap. Getting the string to feed consistently is a trick that I have not figured out how to do...
Aug 26, 2010 | Homelite Mighty Lite Lawn Trimmer
Homelite model UT21566 string trimmer runs only on full choke and at lower RPM. I have disassembled and cleaned carburetor but that did not fix problem. Steve
Your carb high and low settings may need tweaking if it's not a fuel or muffler issue. I believe needles are made only to be adjusted by a technician. If you want to try adjusting it yourself, google and you tube your to see how.
May 03, 2010 | Homelite Carburetor Trimmer Blower...
Homelite gas trimmer will not run without half choke and throttle
You need to disassemble the carb. and spray with carb. cleaner. If you need tips on how to do this, just let me know. You may need a new carb. kit as well, but we won't know that until you first perform the first step, or if the carb. parts are more than 3 years old. If they are, then go ahead and buy the carb. kit and replace the parts.
Jim
Jun 01, 2009 | Homelite Mighty Lite Lawn Trimmer
Homelite Mighty Lite Lawn Trimmer  Logo
441 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
