Question about Garmin StreetPilot c340 GPS Receiver
Garmin 340 street pilot
Screen lights up and says Street pilot and then goes black. This unit was working fine and then just stopped. I can't get it to go beyond the first opening screen. Does this have anything to do with a fuse that might be blown. We are in Norfolk on our way up to NY from FL. and are left adrift without our GPS. Thanks.
    Genius:
  • 3,422 Answers
You don't need to change the fuse.The battery is completely dead.Sometimes it does not charge properly with the adapter. Just hook up the unit to your computer with the USB wire that came with it and it should be fully charged after 10 hours.
Goodluck,
Please don't forget to rate the solution.
Posted on Mar 29, 2008
  • 19,396 Answers
Remove the battery out and put back in after 5 minutes to reset it.
, check also that the in car power cable is working, and the Garmin is not drained. Tru to connect it to power outlet if you have an adapter
  • Ginko
    Ginko Mar 29, 2008
    Also check that the card inside your Garmin is well in place by pulling it out and placing it back
How do I change the batter in a Garmin Street
Hi! You may need to change the fuse periodically, which is at the tip of the adopter! regarding battery, you may need to contact waste disposal section for disposing the unit since it contains lithium. Don't consider much presence of high amount heat and direct sun rays at new battery for longer duration and have fine
Dec 21, 2009 | Garmin StreetPilot C330 GPS Receiver
Garmin street pilot c330 goes on and then goes off
Try to charge the unit for 4 hrs by using a wall adapter and then try power on it again and if still the same after you full charge the unit try to contact the manufacturer check if there is a latest firmware update for the unit.
Jun 09, 2009 | Garmin StreetPilot C330 GPS Receiver
My garmin 340 suddenly stopped working
Ummmmm "Low battery"....... not too hard to figure out. You need to charge it for several hours. If the battery is low it WILL go out on you and during that time, the battery may recover enough to come on briefly then go off again. Please charge your battery!
- Jim
Sep 13, 2008 | GPS
Garmin street pilot c340 battery appeared low, used USB cable to hook up pilot with my computer but device doesn't appear to turn on, computer cannot locate device on Drivers, can I rechare steet pilot...
I followed the instructions of the Online manual for the Garmin Street Pilot c-340, I removed the faceplate of the Street Pilot and then using my thumb pressed down on the reset button. I then pressed the power on button on the side of the device- the screen lit up, I then plugged one end of the USB cable into my computer and the other end into the device. The information on the screen of the device indicated the Lithium Battery was charging properly.
Jul 14, 2008 | Garmin GPS
Garmin Street Pilot III map source data card not accessible
Garmin has issues with the newer (ROHS Compliant) cards, so If you recently bought this card get a replacement from garmin.
I had these issues too with a 256 MB, garmin replace the card with 2 128MB cards, worked fine after that.
Mar 26, 2008 | Garmin Streetpilot ColorMap GPS Receiver
I cannot even tunr on my brand new fresh out of the box street pilot 340? Any ideas?
there is a red button on the side of the unit, hold that and the unit will come on.
Nov 28, 2007 | Garmin StreetPilot c340 GPS Receiver
Garmin 340 streetpilot won't even turn on?
I had the same issue with mine during a trip. Probably needs to be reset. See page 31 of the users manual on Resetting your c340. Once I did this it worked fine.
http://www8.garmin.com/manuals/StreetPilotc340_OwnersManual.pdf
Garmin StreetPilot c340 GPS Receiver Logo
107 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
