Question about Linksys WRT120N Router
Cannot conenct wirelessly to linksys wrt120n router
I have my linksys router set on static ip..but it always does this.. even on the automatic setting
..the wireless on my laptop always goes off and deosn't want to connect back. and its very fustrating...
  • 52 Answers
Reset the router
Posted on May 10, 2010
I'm using TP-LINK TD-W8101G ADSL Modem Router to connect internet, I'm trying to connect it with Linksys WRT120N Router Wirelessly. I want to use WRT120N as access point to extend TP-LINK...
Unfortunately, you can't use two routers together in that manner. You must have a device in between them such as a switch or bridge or you'll have to disable the DHCP server settings in the second router. The second router then pretty much becomes a switch you may then use all the ports on the second router with the exception of the WAN port it must remain unoccupied. However, if you need wireless connectivity in another location far away from your main router then your only solution would be to indeed purchase an actual access point/bridge device
Sep 06, 2011 | Linksys WRT120N Router
I have a Cisco WRT120N wireless router. The wireless internet access goes away when I turn off my laptop. When I turn the laptop back on, no more access. The only way to get it back is to pull the...
Have you tried the laptop on another wireless network? It should release and renew it automatically when you reboot the laptop without having to reset the router. And it sounds like the router itself is glitzed. But i would try using the laptop wireless on another router somewhere and also try connecting some other wireless device to the router to analyze the problem. You could also try setting the laptop's ip to a fixed ip number instead of obtain automatically (it must be in the same range as the router - first three numbers needs to be same as the router's) and see if it's the dhcp that is the problem.
A few years ago there were a lot of glitzy linksys routers ...
Mar 18, 2011 | Linksys WRT120N Router
Cannot get wirelss connection through my WRT160N wireless router. Was working and now not. I can get internet connection through the LAN ports so I know that the router is working with a fixed cable
by default ip address of linksys is 192.168.1.1
to star config you need to be connected with ethernet cord rj-45
or conenct via wireless by conencting to linksys on wireless
admin user: blank
admin pws: admin
*choose a protocol on your linksys router on internect conenction type:
check isp protocol :
dhcp: needs serail number of mac address
it picks up automatic
pppoe: needs username and pws from isp
*the ip address has to be diferent from the isp modem:
isp modem 192.168.1.1 linksys 192.168.1.1 incorrect
isp modem 192.168.1.1 linksys 192.168.2.1 correct
change the ip on lan settings on your router
*wireless: ssid by default is linksys
ssid: linksys
wep : none
to setup wireless
access the wireless basic
change the ssid to any network name
enable the wireless password
choose wireless security
enable wep key 10 digit hex pws
make shure you saved settings on every setting
May 04, 2010 | Linksys WRT160N Wireless Router
I pushed the reset button on my router and now I have no protection from others with my wireless, how can i protect that?
admin user: blank
admin pws: admin
ssid: linksys
wep : none
to setup wireless
May 04, 2010 | Linksys Wireless-G Broadband Router
Need cd for downloading program
Assuming you are trying to install a router.... routers do not use drivers or software. CD's provided with Routers are generally used to walk you through the installation/setup process. Most Linksys routers are default accessible at 192.168.1.1 via your browser. the default username is admin and the password is usually admin. If this does not work, try resetting the router by pressing the rest button located on the back of the unit (small hole) with a paperclip. hold the button in for about 1 minute and then release it... If you are unlucky enough to have a unit with a flashing power lite, this is a dead unit and is not repairable. Look up your model for more specific instructions on www.linksys.com under the support section.
Apr 12, 2010 | Linksys Wireless-G Broadband Router
Trying to set up LInksys WPS54G, connected as
admin user: blank
admin pws: admin
ssid: linksys
wep : none
to setup wireless
make shure you saved settings on every settings
Feb 12, 2010 | HP LaserJet 1320n Printer
WRT400N LELA software not working
admin user: blank
admin pws: admin
ssid: linksys
wep : none
to setup wireless
Sep 23, 2009 | Linksys WRT400N Router
Wireless router install on cable modem w/static ip address set
Connect a computer to linksys lan port 1-4, point browser to linksys http://192.168.1.1 under Setup->Basic Setup->Internet Settings choose "Static IP" and fill in the fields below... the field for gateway should be set to the static ip of your cable modem. the field for netmask should probably be 255.255.255.0. It may help to turn on DHCP for local network so that lan hosts can get their ip's from the linksys.
May 15, 2008 | Linksys WRT55AG Router
Linksys WRT120N Router Logo
579 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
