Question about Lexmark Wheelwriter 3500 Typewriter
Code 120 I have a lexmark wheelwriter 3500 typewriter. Now it is showing a square box with a diagonal line across it and 121 code. I tried shutting off off and on and removing the internal AA batteries to reset typewriter, but it did not help.. Any suggestion.. please email your assistance to: [email protected] Your help is much appreciated.. Thank you
  • 1 more comment
  • bmansurku Mar 28, 2008
    I need help soon to finish my work. thanks
  • mjones460 Nov 13, 2008
    The code says 121, I unpluged it, turned it off, put new batteries in it, sprayed the debris and tried the code, L, 001. Does not work for me. Any other suggestions?
  • dbowers52 Feb 05, 2009
    error 121
  • Lexmark Master
  • 3,594 Answers
If none of those things helped you need a printwheel sensor call a tech.
DickyO
Posted on Nov 24, 2008
Tou can try pressing and holding the code key, press and hold the "L" key, release code type 001, release "L" key. Your keyboard may be bad this will select USA keyboard.
Good luck
DickyO
Posted on Mar 29, 2008
SOURCE:
In my tipewriter appears a square with a diagonal inside and the number 121 and it doesn´t works. What can I do?
You need a keyboard. I'll exchange it with a rebuilt one for 75.00 including shipping.
DickyO
216-241-0027
Sep 03, 2010 | IBM Wheelwriter 30 Typewriter
I have an IBM Wheelwriter 3500 by Lexmark. The icon in the window shows a box with an upper left to lower right slash with the number 121. It turns on, beeps and will not allow anything to work. Help!
Error Code 121 means the keyboard is not recognized, check the connectors from the keyboard to be sure they are plugged in properly.
Try this turn it off remove the batteries, wait 30 sec. turn on all settings will go to default, memory will be cleared for any fault code stored.
Tell us news.
Aug 26, 2010 | Office Equipment & Supplies
Will not advance or return to left margin.
215 is a pwintwheel not being detected. Try re installing the P/W look for debris in that area, if you have a compressed air source blow out that area. If these fail tou will need a P/W sensor, LED or both.
DickyO
Apr 06, 2010 | Lexmark Wheelwriter 3500 Typewriter
IBM WHEELWRITER 30 SERIES II
I believe a 215 code is a bad printwheel sensor. You need a tech.
DickyO
Mar 05, 2009 | IBM Wheelwriter 30 Typewriter
IBM WheelWriter 30 Series II
The 121 indicates a keyboard problem, See my tip under ww1000 also check the two flat connectors from the KB to the PC mboard.
DickyO
Jan 15, 2009 | IBM Wheelwriter 30 Typewriter
IBM Wheelwriter 30 Series II Typewriter 6787
The book says turn the T/W off wait 30 seconds and restart, if condition returns call for service. However you might try removing the batteries and unplugging the machine waiting a few minutes and restarting. CAUTION ALL THE MEMORY WILL BE LOST!
DicktO
Jul 16, 2008 | IBM Wheelwriter 30 Typewriter
IBM WheelWriter 3500
Try pressing and holding code key while pressing "L" release "L"
and type 001 release the code key. If this solves the trouble but it comes back on the next power up the keyboard is bad.
DickyO
Mar 25, 2008 | Lexmark Wheelwriter 3500 Typewriter
Wheelwriter 3500 error code
This is memory cleared. Change the batteries, be sure to clean the battery contacts especally if they were corroded.
Dicky O
Oct 25, 2007 | Lexmark Wheelwriter 3500 Typewriter
The wheelwriter 3500, don´t write, only (_ 121), what´s that? what can i do?
You may have the wrong keyboard selected. Try holding down the code key while pressing the L(lang) key.Release the L key and continue holding down the code key while you type the keyboard code number. USA keyboard is 001.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Feb 27, 2007 | Lexmark Wheelwriter 3500 Typewriter
Lexmark Wheelwriter 3500 Typewriter Logo
119 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Ekse
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
